gas building up pressure in the tank - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-31-2010, 06:40 PM   post #1 of 22
2_Late_I_Won
Senior MTF Member
2_Late_I_Won's Avatar
MTF Member # 29025
Images: 3
Default gas building up pressure in the tank
Never had this problem before. Noticed today after mowing 2 acres. That I had a gas leak. Well come to find out it was leaking from the gas tank lid and doing ALOT of hissing. So I opened the gas cap/lid really slow and there was a bunch of pressure after I was able to take it off the gas bubbled and almost looked like it was boiling. I suck my finger in the gas and it was warm but not hot hot. I know the gas cap should have a vent hole. Where is it at? I know if it doesn't let air in as the gas goes out your tractor can die from lack of gas but I don't know what causes the pressure to build up inside the tank. I just want to get this fixed so I don't cause a fire and burn up a field let alone my tractor.
Thanks as always!!!
2_Late_I_Won is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-31-2010, 07:39 PM   post #2 of 22
raytasch
Old Guy With Old Toys
raytasch's Avatar
MTF Member # 4585
Images: 2
Default Re: gas building up pressure in the tank
There is a pin point size hole in a small dome on top of the N tank. Stock N gas caps are not vented.
__________________
ray
Ford Jubilee-- restored, pulls a finish mower once in a while
Ford 850 -- the workhorse--does it all
IH CC 122--semi retired-awaiting restoration
JD 4300HST FWDA W/Loader--- another workhorse
Sears DGS6500
raytasch is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 07:49 PM   post #3 of 22
Kirk-NJ
2000 Posts and climbing!!!
Kirk-NJ's Avatar
MTF Member # 9444
Images: 16
Looks like from your picture it is an 8n. Your 8N owners manual may show a photo of the gas tank. The N gas tank has a bubble on it that has two holes (not in line) drilled to relieve the pressure. Sometimes these holes will be rusted or painted over. You can drill out these holes but it's just as EZ to get a vented gas cap.
That said this seem to be a problem so ford dealers were offering a new cap to solve this problem.
Supposedly return your gas cap with your serial # and get a new one. Worth a shot but I won't hold my breath.
IH had a similar program. You can do it online= no problem. And it's ship to you in a couple days.
If this is not your problem then I would look at how close your gas line is to your exhaust manifold and it rubber you may want to consider changing it.
Kirk
Kirk-NJ is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 07:57 PM   post #4 of 22
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Last I read the gas cap swap had ended, go to NAPA and get a GOOD vented cap and don't look back. ALWAYS use extreme caution removing the cap if there is a chance of pressure build up, darn good way to have a fire on you as well as the tractor.
__________________
JohnW is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 10:54 PM   post #5 of 22
2_Late_I_Won
Senior MTF Member
MTF Member # 29025
Images: 3
Yeah specially with the gasoline vapors beeing more explosive than the actual fuel it's self. I think I'll just get a new cap and not worry about it. It seem really wierd though because I use this tractor almost every weekend and have never had this problem before.
Old 11-01-2010, 06:23 AM   post #6 of 22
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Quote:
Tank...
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Old 11-01-2010, 11:07 AM   post #7 of 22
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Quote:
Yeah, come under the heading of RUST HAPPENS
__________________
Old 11-01-2010, 11:31 AM   post #8 of 22
2_Late_I_Won
Senior MTF Member
MTF Member # 29025
Images: 3
So how am I supposed to put a pin through that unless I remove the hood? I think I'll just stick with getting a vented cap LOL
"rust happens" LOL
Old 11-01-2010, 11:39 AM   post #9 of 22
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
"rust happens" LOL
Yes, vented cap is the answer..
__________________
Old 11-01-2010, 11:41 AM   post #10 of 22
2_Late_I_Won
Senior MTF Member
MTF Member # 29025
Images: 3
can I just drill a small hole in the old gas cap it's self?
Old 11-01-2010, 11:46 AM   post #11 of 22
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
???? I have never tried it! ????
__________________
Old 11-01-2010, 04:29 PM   post #12 of 22
2_Late_I_Won
Senior MTF Member
MTF Member # 29025
Images: 3
or maybe I can drill about 5 or 6 small holes like pin size holes. The vapors should be able to get out and if the fuel hits it the holes should be too small to get alot out
Old 11-01-2010, 04:50 PM   post #13 of 22
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Bad idea if you are serious..get a vented cap. Vents are generally not a direct hole to the inside of a tank.
__________________
Bob
Old 'n Cheap
Bad part of being older...you can remember when things that now cost $10 were only 50 cents
46 2n - waitin on me to do something to it.
47 2n - my relaxin tractor.
64 4000 - w/7 ft finish mower, scoop and bushhog.
ryork is offline   Reply With Quote Quick reply to this message
Old 11-01-2010, 05:49 PM   post #14 of 22
2_Late_I_Won
Senior MTF Member
MTF Member # 29025
Images: 3
ok They cant be more than $12 anyways
Sponsored Links
Advertisement
Old 11-01-2010, 08:57 PM   post #15 of 22
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Last one I got at NAPA was under $10
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
