JD 212 deck pulleys for sale? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-26-2010, 09:45 AM   post #1 of 5
goldhunter_2
Senior MTF Member
goldhunter_2's Avatar
MTF Member # 45366
Default JD 212 deck pulleys for sale?
any one have some good used 212 deck pulleys for sale and how much shipped to 34953? (measure 4.5" diameter)
some of you may remember I recently had to replace my drive pulley on my JD 212 and while the deck was off I had the brite idea to rebuild the spindles, well I don't think they have ever been off I cut the bolt with a torch and tried my best to disassemble the spindles and finial took to a machine shop who eventually got them off with some difficulty . during this process the pulleys got bent up pretty bad, One has to be replaced the 2nd needs to be replaced and if I had to the 3rd mite be able to be used.
I tried buying one off ebay and it fits the shaft but is a smaller overall diameter (3.5") witch I don't think I can use as it would change the ratio on that one blade
on a positive note, my spindles are all rebuilt with new bearings polished shafts cleaned threads, new keys and lock rings and have new bolts holding them down to the deck . The drive pulley also worked great as I cleaned out a little wooded area behind my house and dragged tree limbs all weekend with the little 212 tractor
__________________
212 John Deere
L110 automatic John Deere
goldhunter_2 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-30-2010, 01:28 AM   post #2 of 5
goldhunter_2
Senior MTF Member
MTF Member # 45366
Default Re: JD 212 deck pulleys for sale?
Humm no reply's
maybe I can find some another way then just searching JD 212 parts , does anyone know witch other mower decks use the 4.5" diameter with 3/4" shaft deck pulleys ?
__________________
212 John Deere
Old 10-30-2010, 01:39 AM   post #3 of 5
Marcintosh
Senior MTF Member
Marcintosh's Avatar
Location: CT, on the sun drenched shores of Long Island Sound
MTF Member # 39360
Images: 5
How about Tractor Supply or a good Hardware store? These can't be that special . . . can they?
I'd move off the JD parts manual and have at it
Marcintosh is offline   Reply With Quote Quick reply to this message
Old 10-30-2010, 01:56 AM   post #4 of 5
goldhunter_2
Senior MTF Member
MTF Member # 45366
well when I was trying to persuade them off I didn't think that they would be hard to replace but...........
I have tried local hardware, parts stores, tractor supply, miller bearing , Ace, and JD dealer but no one carry's in stock JD dealer and miller bearing can order if need be but I would like to recycle good used parts if possible.
I found these case garden tractor pulleys on ebay and the diameter and shafts are correct I am wondering if they are the same thickness/height as the JD pulleys and would work ?
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
__________________
212 John Deere
Sponsored Links
Advertisement
Old 10-30-2010, 12:52 PM   post #5 of 5
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
You might try looking for a trashed deck for cheap.
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
