GT 6000 ready for snow - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-21-2010, 06:22 PM   post #1 of 15
abumpa
Senior MTF Member
abumpa's Avatar
MTF Member # 20142
Default GT 6000 ready for snow
Bought this 94 GT 6000 Hydro earlier this spring cause it looked nice and came with a snowplow. I have been plowing for the last 23 years with a 165 hydro John Deere that has been doing great. I just wanted to give the JD a little rest.
Spent some time recently making a rear blade and painting the front blade and hardware. Found some weights (JD yellow) and chains (chains not on yet) on Craig’s list that looked new to help with traction.
The blade was supposed to be complete but as you might guess there were some parts missing. Luckily I had the missing parts in some left over stuff from past projects. Had to soak the blade release cable in penetrating fluid to loosen it up, but it seems to work good now.
I am really interested in how this tractor will plow. It is heavier and has more HP than the little JD so I am expecting it to do well. Below are a couple of photos....
__________________
1964 Wheel horse 654
1987 John Deere 165
92 Craftsman GT 6000 6 speed
94 Craftsman GT 6000 Hydro
John Deere Saber 17/42 (the rake)
John Deere LT155
abumpa is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-21-2010, 06:25 PM   post #2 of 15
BushBoneYard
5000 Strong & Climbing
BushBoneYard's Avatar
MTF Member # 31379
Images: 12
Garage
Default Re: GT 6000 ready for snow
That tractor is super clean.
__________________
1977 Murray Built Sears ST 10 Yard and Garden Tractor
1984 Murray 39004 Garden Tractor
1999 Murray 46500 Lawn Tractor
2007 Husqvarna Built Craftsman YS4500
MurrayOwnersWorld.com
M.O.W. Facebook
Contact: bushboneyard[at]gmail.com
BushBoneYard is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 06:40 PM   post #3 of 15
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
what a beast! wheres the chains?
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 06:57 PM   post #4 of 15
abumpa
Senior MTF Member
abumpa's Avatar
MTF Member # 20142
Quote:
Originally Posted by Hugh-SS/16 View Post
wheres the chains?
In the garage. I decided to wait until snow gets a little closer to put on the chains. That way I can still drive the tractor all over **** without the noise from the chains.
__________________
1987 John Deere 165
John Deere LT155
Old 10-21-2010, 08:01 PM   post #5 of 15
engine2quarters
MTF Member # 24003
I've got the 'light weight' cousin of yours, the LT4000, with the same frontal plow. Mine is the 80's version, but pushes blue snow (heavy water content) that is higher than the plow blade easily. You may want to look into putting a brace from the bottom of the push brace where the plow rotates up/down back to just above the rear axle. I added this brace after I bent the tractor's frame, just above the axle, from pushing into a frozen pile.
The rear blade might not be enough rear weight for you, but if it gets a snow load on it, it might work. I'm running about 100 pounds hung off the rear, with 30 pound Sears wheel weights, and ice chains. Only got a measly 10 - 12 hp B&S engine, but it pushes.
engine2quarters is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 08:24 PM   post #6 of 15
abumpa
Senior MTF Member
abumpa's Avatar
MTF Member # 20142
Quote:
I like that idea. I did something similar to my JD165. The JD has a home made plow attachment.
Guess I figure the factory mount of the GT 6000 would be better.
I just looked at my GT 6000 front mount bracket and like the idea even more. There is a nice hole at the lower rear of the front mount bracket to bolt the brace to. Even if I only went from the bracket to a mid point on the frame it would significantly strengthen the bracket. Great Idea…thanks!!!
__________________
1987 John Deere 165
John Deere LT155
Old 10-21-2010, 08:40 PM   post #7 of 15
green814
Senior MTF Member
MTF Member # 4102
Abumpa,
Looks like you are all ready for the snow! Though maybe not as effective as your previous set-up (21" blower)! Lol
If you need more weight, fill the tires, and also look for some 25lb weights, and add those to the rear wheels as well. My '93 pushes snow like it isn't even there!
IF/when you come up with the brace set-up, please post a picture. I have considered something myself. I have even thought about making a new set of the factory brackets that E2Q is talking about, only using 1/4" steel so it is stronger.
Chris
__________________
'84 Craftsman GT18- 48" Dozer Blade
'93 Craftsman GT18 6K- 48" Dozer Blade, 42" Snowblower
'96 Craftsman GT22
'04 Toro Z500
green814 is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 08:58 PM   post #8 of 15
abumpa
Senior MTF Member
abumpa's Avatar
MTF Member # 20142
Will do Chris.
May be a few days till I get to it though. Just took a quick look tonight and at first glance it may be difficult to get a brace as far back as e2q suggests. However, I will take a better look at it later. I also noticed there are a couple of brackets already attached to the frame near mid point. These brackets are used for the mower lift mechanism and are not that strong so I will need to avoid using them.
I don’t like anything in the tires except air. I know it works but I just don’t want the bother if the tire needs service.
I have 100 pounds of steel plates on the back of other GT 6000. In order to do that to this tractor I would have to remove the rear blade. Will wait and see if it is needed when the snow flies.
The small 2-stroke snow blower I used in the joke photo is the one I use to clean off my deck. I know that sounds spoiled (and I am) but the deck is 56 feet long.
__________________
1987 John Deere 165
John Deere LT155
Old 10-21-2010, 09:14 PM   post #9 of 15
green814
Senior MTF Member
MTF Member # 4102
Understand the air only in the tires! The 25lb work out weights I added I just drilled a couple holes, and bought new threaded rod, and bolted them up with the wheel weights. IF I ever get to it, I will make a rear blade similar to what you built!
A deck 56 ft long needs a ramp to drive the tractor up to clear! Lol
Isn't there a place that a bracket could be bolted that is actually part of the rear hitch? Where the sides of it come down & around the rear axle some.
Nothing wrong with being spoiled! But if you were REALLY spoiled the "Better Half" would clear the snow for you! Sorry, couldn't resist!
BTW, my in-laws said it was snowing today at there place (Mackinaw City)!!!! I am NOT READY for it!
Chris
__________________
'96 Craftsman GT22
'04 Toro Z500
Old 10-24-2010, 09:34 AM   post #10 of 15
abumpa
Senior MTF Member
abumpa's Avatar
MTF Member # 20142
Had some time yesterday so I made up some extra support brackets for the blade mounts as e2q suggested. Keep in mind that these brackets are constructed from “on hand” materials. That’s what I try to do before going out and buying new stuff. I like to use up the old stuff left over from other projects first if I can.
The front hitch plates where the plow mounts hang down from the front of the frame and would take all the force when the blade is pushing, or is bumped against something. As e2q suggested they do appear to need reinforcing to help prevent potential bending from blade impacts.
There is a spot on both sides of the frame a couple of feet back that has 2 holes that seemed a good place for the brace. These holes are empty on the left side but are used on the right side to mount the handle support bracket, but the brace can be mounted under this bracket.
Also the left side bracket had to be bent inboard, under the frame to allow clearance for the tire when turning left. The right side bracket could be straight and not interfere with the tire.
Here is a photo of the left side bracket. The blue arrow points to the area of the bracket that needed to be bent inboard to provide clearance for the tire when turning left. Green arrow is where the bracket mounts to the existing holes in the frame. The red arrow shows the front hitch plate that needs reinforcing. The left bracket also needed to be low enough to avoid interference with the steering arm (yellow arrow).
This is the right side bracket. Blue arrow shows the bracket. Green is where the bracket mounts to the frame under the handle support. Red is the hitch plate.
Thanks to e2q for making the suggestion. I am hoping this will help to avoid any problems with potential frame bending.
Some additional photos from the project...
__________________
1987 John Deere 165
John Deere LT155
Old 10-24-2010, 01:44 PM   post #11 of 15
Merrie-Merrie
Working to a 1K post
Merrie-Merrie's Avatar
MTF Member # 45408
Garage
Nice mod, and definately a great looking tractor
Merrie
__________________
Proud student of MTF University!!!
See My YouTube Videos Here
2003 Cub Cadet 2186 with custom built Carry-All, Front Bumper
1974 B80 Wheel Horse (Work in progress), where you may see junk... I see potential
2005 Craftsman Push mower (THE PURPLE ONE!!!)
Merrie-Merrie is offline   Reply With Quote Quick reply to this message
Old 10-24-2010, 07:10 PM   post #12 of 15
green814
Senior MTF Member
MTF Member # 4102
Looks pretty good! I know I didn't have any issues with the brackets YET, but I am also not afraid to move (or try moving) a pile of snow for more room. That is why I considered something along the same lines.
So, what is the next project? Maybe removable side wings for quicker clean up of the smaller snowfalls????? That has also been a possible project, just not enough time!!!!
Chris
__________________
'96 Craftsman GT22
'04 Toro Z500
Old 10-24-2010, 07:46 PM   post #13 of 15
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Nice set up.
I like your wheel weight.
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is offline   Reply With Quote Quick reply to this message
Old 10-25-2010, 10:48 AM   post #14 of 15
abumpa
Senior MTF Member
abumpa's Avatar
MTF Member # 20142
Quote:
Yup, every time (twice) I look for wheel weights I end up with John Deere weights. These 50 pounders I got with chains for around $100 as I recall. They look almost new.
The ones on the other GT6000 are 70 pound John Deere weights and I swiped them for only 10 bucks.
Chris, going to try and use it before doing anything else to it.
Thanks everyone for your comments.
__________________
1987 John Deere 165
John Deere LT155
Sponsored Links
Advertisement
Old 10-25-2010, 11:23 AM   post #15 of 15
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Quote:
Merrie
those pieces look like they were meant to be there! Maybe a lucrative side hobby?
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
