Subaru Robin or Honda? Need some advise - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 10-20-2010, 04:12 PM   post #1 of 10
pincorpete
Senior MTF Member
pincorpete's Avatar
MTF Member # 4040
Default Subaru Robin or Honda? Need some advise
I'm going to be buying an v-twin engine soon to repower one of my Gravely riding tractors and need some advice from people who are knowledgeable with Subaru-Robin and Honda engines. I've got all the Gravely specific info sorted out, so now I'm just looking for more information on the expected life, reliability and operator reviews for these particular engine brands. Parts availability and cost information would also be a plus too.
I'm looking at the Robin EH72 and the Honda GX670 or possible the GX690. I've done some research on the build quality of both the Honda GX690 and the Robin EH72 and both seem to be built pretty well. I haven't found much about the internals of the GX670, but maybe I'm not looking in the right spot. Some of the features of the GX690 are: forged steel crank, fs rods, hemi heads, cast iron sleeved cylinders and a 3 year warranty. It should be noted that the GX690 uses removable cylinders that seperate from the block, where as the Robin uses the more conventional die cast "all-in-one" aluminum block and cast iron sleeved cylinders. Both the Honda's use a 2-BBL carburetor as opposed to the Robin which uses a single barrel, but I wouldn't think that really attributes to the reliability or longevity of the basic engine. As for the Robin, the EH72 features an over-sized ball bearing on the PTO side, forged steel crank, replaceable bearing on the flywheel side, and a 3 year warranty. So, while there are some similarities between the two, there are some differences that were noted.
I've had some experience with Honda's line of 13HP water-cooled inline twins that were used on their riding mowers, as well as the small 4HP lawnmower engines and they have proven to be fairly reliable, but I have no knowledge or experience with the Subaru-Robin engines or the Honda air-cooled v-twins. I've heard that Honda's line of v-twins isn't as good as their single cylinder engines, but I'm not sure how true that is. Can anyone comment on the Subaru-Robin and the Honda v-twin engines? If you've used them or own them, how do they compare? Any problems or issues that you've come across?
Thanks in advance for any input.
__________________
, Pete
pincorpete is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-20-2010, 04:25 PM   post #2 of 10
cosmo74
Senior MTF Member
MTF Member # 35869
Default Re: Subaru Robin or Honda? Need some advise
robin are supose to be exelent I know it is not the same but I had a robin line trimmer and it lasted 26 years of heavy use i think the robin also has a oil cooler
cosmo74 is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 04:46 PM   post #3 of 10
pincorpete
Senior MTF Member
pincorpete's Avatar
MTF Member # 4040
Yeah, I think both the EH72 and the GX670 come standard with oil coolers which is definitely a plus since a cooler engine leads to longer life. However, I don't think Honda's GX690 or any of the other variants in their new line of vtwins come with a cooler. Not sure why they did away with that. Thanks for your input
__________________
, Pete
Old 10-20-2010, 04:48 PM   post #4 of 10
MTD snow plow
Murray tractor owner
MTD snow plow's Avatar
MTF Member # 40721
Images: 8
Garage
Honda's have a spin-on oil filter as well. Plus ball-bearing crank support.
__________________
Cub Cadet 72, mower deck, soon plow and sleeve hitch
MTD 995 hydrostatic-hydro lift, 54" snowplow, 3 point Hitch, 50" deck, Tire Chains, 10" plow, box-blade
1997 Murray 15.5 Hp 42"
Honda HRA214 self-propeled mower
2010 Stihl FS-45 trimmer
Ariens Snowblower H70
IH (Cub) cadet 282 Hydro
Lawn-Boy 6262 commercial, BBC, Mulch/side discharge
Lawn-Boy Selfpropeled bagging mower(Forget the model)
MTD snow plow is offline   Reply With Quote Quick reply to this message
Old 10-20-2010, 05:17 PM   post #5 of 10
pincorpete
Senior MTF Member
pincorpete's Avatar
MTF Member # 4040
Yep, all three engines have oil filters which is great. I'm glad you brought that up. I was looking at the Honda parts diagram for the GX670 and the GX690 because I was curious to see how the crank was supported, but I'll be darned if I could find a listing or picture for those crank bearings. From the pictures, it looks like the crank is supported on either end by the crankcase, which I'm assuming (again, from the pictures) has a bushing pressed into the both ends. Couldn't find a listing or a really good picture for the bearing or bushing (whatever they use). Again, I was really just curious and that was the reason why I was looking at the parts diagram, but if anyone knows, I'd be interested to know how they support the crank on the Honda vtwin.
__________________
, Pete
Old 10-20-2010, 06:04 PM   post #6 of 10
markusedma
Senior MTF Member
MTF Member # 30825
Both good engines... Subaru parts are harder to come by and more expensive..(in my area so might be different for you). Also more people seem to have more knowledge on working on Honda engines. I'm fairly sure that the Honda does have dual ball bearings for the crank but not %100. Besides... I'm not entirely convinced that ball bearings are all that much better when you have a full pressure lubrication system.... Car engines don't use ball bearings after all.... My preference would be a Honda.. So either way you should look at which one gives you the better "bang for the buck" and what you feel more comfortable with...
__________________
3x Honda 4514, 2x Honda HT3813
2X JD L130, LX178
Roper YT16 Hydro,
Kubota G4200hst
Kubota B7100D
2X Kubota G5200HST
Cub Cadet 2518
Sears craftsman DGT6000
markusedma is online now   Reply With Quote Quick reply to this message
Old 10-21-2010, 08:06 AM   post #7 of 10
DTLMG
Master Service Technician
MTF Member # 42277
Images: 2
From the shop.... You should expect 1500 to 2000 hrs from these engines. Robin parts are hard to get and very pricey as someone already said. As a technician in one of Wisconsins largest dealers I see very few Robin engines on commercial equipt. Kawasaki is the preferred choice of our commercial customers.
Parts are pricy for both the Honda and the Robin. If I was contemplating this purchase I would find out where the Robin and Honda engine distributor was located and give them a call to ask any questions you may have. I dont know of any "known" problems on either engine you should be worried about.
HTH
__________________
DTLMG
Make sure your red wire goes to positive, and your black to ground
Master Senior Service Technician
30+yrs in Outdoor Power Equip Industry
DTLMG is offline   Reply With Quote Quick reply to this message
Old 10-21-2010, 08:08 AM   post #8 of 10
MTD snow plow
MTF Member # 40721
Images: 8
Garage
The only way to get parts for a subaru robin is to order them at a subaru dealer, you can order honda at the honda lawn equitment dealer.
__________________
Old 10-21-2010, 03:54 PM   post #9 of 10
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
i am a honda lover. our two cars are a 96 odyssey with 190k on it that runs awesome and drives 40mi every day and a 95 accord with 130k that goes everywhere. oh, and my 2nd mower (first is in avatar) is a 99 honda lt. Honda all the way!!
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-24-2010, 09:55 PM   post #10 of 10
pincorpete
Senior MTF Member
pincorpete's Avatar
MTF Member # 4040
Thanks all for your input. I decided to go with the Honda GX690
__________________
, Pete
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
