summer and winter diesel fuel - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-13-2010, 07:56 PM   post #1 of 8
JD GReg
Senior MTF Member
JD GReg's Avatar
MTF Member # 9298
Default summer and winter diesel fuel
We are getting closer to that time of year, where we will
be switching to winter diesel fuel.
Can a person mix the two diesel fuels without any issue.
Like, if I have 1/2 tank of summer diesel left in my
tractors, can a person just top off with winter diesel.
Or, to get rid of the summer diesel, can I blend it with
winter diesel.
Right now, I'm trying to not buy anymore diesel fuel until I
absolutely need it, but I'm sure I will have some summer diesel
left over when winter hits. Same thing will apply next spring
when I have left over winter diesel.
Greg
JD GReg is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-13-2010, 08:02 PM   post #2 of 8
picframer
Proud Member of the 1K Club
picframer's Avatar
MTF Member # 11939
Images: 7
Default Re: summer and winter diesel fuel
Yes, put some additive in with the mix and you will be fine, we go through so much we have a pup trailer that goes around filling things, we are now at 5 degrees C in the mornings and some of the tractors really don't care for what they are drinking but after a few moments they are fine, excavators don't seem to care.
__________________
A colllection of CUT's, excavators and GT's, just about every attachment going and a major amount of Stihl gear. We operate a Landscaping business.
Smiling every Day!!! Andy
picframer is offline   Reply With Quote Quick reply to this message
Old 10-13-2010, 08:05 PM   post #3 of 8
Tencubed
3K Poster!!!!
MTF Member # 31735
Last couple times we fill the tanks prior to the really cold weather we get the winter grade. Never had a problem mixing them. We do use a stabilizer and algae treatment year round. I've never heard of anyone having a problem mixing the fuels.
Mike
__________________
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 03:01 AM   post #4 of 8
Upper5Percent
5000 Strong & Climbing
Upper5Percent's Avatar
MTF Member # 8602
"Q: Is cold weather fuel "different" from summer fuel?
One TDR (http://www.turbodieselregister.com/) member works for a fuel pipeline company that blends fuels for northern climates.He posted this information to the TDR forum:
Most fuels are blended by the refinery. Our #2 has a flashpoint of 138F to 148F in the winter months and 150F to 170F in the summer. We add 1.25 gallons of Paraflow 527 per 1000bbls of each reciept. Our straight #2 diesel has a cloudpoint of -10 to-15.Our premium diesel has a extra additive package and is good to -20 to -25. Some customers from colder climates in our area will custom blend their fuel to their climate. This is done by the carrier(truck) at the rack and is usually 70/30 or 75/25. To make it short.if you live in a colder climate you are probably getting blended fuel. I use a regular diesel with 50ml of Amzoil Cetane booster in every other tank. I have not had any problems down to -30.
Our #1 diesel runs at 110F to 130'F flash and 41.0 to 44.0 gravity at 60 - all depending on the season. #1 is a hotter fuel and lighter than #2. "
On the farm we use Deere additives...so we just change our additives from the summer formulation to the winter one...
https://jdparts.deere.com/partsmkt/d...onditioner.htm
__________________
The answer is 42
Upper5Percent is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 02:47 PM   post #5 of 8
2320Guy
Senior MTF Member
2320Guy's Avatar
MTF Member # 39648
I live in a Northern Climate, and run a diesel truck (Chev 2500HD) and my 2320,..This is the first I have heard of "cold climate diesel"??? I just buy what is at the pumps. Should I be running premium in the winter on both perhaps???
__________________
Edmonton, Alberta, Canada
2014 JD 1025R
60" Mowing Deck with Mulching Kit
72" Custom FEL Snow blade for loader
JD IMatch
2320Guy is offline   Reply With Quote Quick reply to this message
Old 10-14-2010, 04:41 PM   post #6 of 8
Upper5Percent
MTF Member # 8602
Quote:
This is what I have used in all of our Duramax Diesels in the winter...
Economic cold weather protection
* Fuel Gelling Protection - pour point reduced by as much as 40F (22C), depending on base fuel
* Reduces ice formation of water in fuel
* Contains no alcohol
* Specially formulated for ultra low sulfur diesel
* Can be used with bio diesel up to B5 (5% bio content)
http://www.stanadyne.com/view.php?id=76
__________________
The answer is 42
Old 10-14-2010, 06:39 PM   post #7 of 8
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
I like FPPF Polar Power or Power Service. I've had the best luck with. Nothing worse than being gelled up in the winter. I change the fuel filter each fall and drain some of the fuel and moisture out of the tank before adding any additive for the winter. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-15-2010, 12:13 PM   post #8 of 8
saskman49
Nicky&Sterling RIP 03-08
saskman49's Avatar
MTF Member # 4038
You get winter diesel anyway. I always check as to when it comes in as I only buy my fuel at the CO-OP and they are very good about this. I would recommend you check where you buy your fuel about it as well. BTW I have never seen premium diesel fuel in these parts as even furnace oil here is dyed diesel according to the CO-OP manager at the AG center.
I run Texas Refinery DZL-PEP Artic additive in my diesel fuel year round as it is what most farmers around here have used for years.
__________________
John
JD2320 with 62D, 200 CX with 53" bucket
Speeco QH & Hydraulic top link
JD 647 tiller
JD 413 Rotary Cutter
Frontier SP1060 Soil Pulverizer
Frontier BB2060 Box Blade
Land Pride 1572 Rear Blade
Allied 50" blower
Frontier pallet forks
55 Gal 3pt sprayer
Frontier middle buster
3 section diamond drag harrows.
JD X485 with 62C deck
JD Gator TH 6x4
JD 216H 46 mower and 33 tiller
JD JS35 Mower
Stihl BG86, 017, MS250, FS90R, KM130R
Gone LT2000, JD GT235, X500, LT180, 108 and 265 also White GT1822
saskman49 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
