John Deere 400 hydrostatic transmission ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 10-03-2010, 07:30 PM   post #1 of 4
Mark Adams
Senior MTF Member
Mark Adams's Avatar
MTF Member # 34798
Default John Deere 400 hydrostatic transmission ?
Hi All
Is there some one who could help me out.
I would like to use a John Deere 400 hydrostatic drive transmission on something that I am building. I see them on E-bay.
Most are run with a 20 hp.
#1 What is the rotation going into the hydra. drive? ( From the motor ) Is it C.W. ???
#2 What RPM's do the hydrostatic run at?
#3 There are 3 hose conections on the hydra. drive, what do they go to?
#4 Dose the oil in the rear end mix with the oil in the hydrostatic drive?
#5 This is a big one, If the speed going into the hydrostatic was 1000 RPM,s what would the RPM,s coming out be? What is the ratio?
Thank you for your help
Mark
Mark Adams is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-04-2010, 03:25 AM   post #2 of 4
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
Default Re: John Deere 400 hydrostatic transmission ?
Quote:
Originally Posted by Mark Adams View Post
Hi All
Optional, depending on which end of the engine is driving it. Adjustment for rotation is done by turning the charge pump housing 180*.
Max is 4000. In GT's usually 3300 - 3600 RPM.
One line from the rear end to supply the hydro and 2 from the hydro for implement lift hydraulics.
The oil in the rear end is the oil for the hydro. The rear end is the reservoir.
1000 RPM. Ratio is 1:1. The reduction is all done in the rear end.
Mark
My information is specific to Sundstrand Series 15 hydro units. I'm pretty sure that it is accurate for comparable Eaton units as well.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is online now   Reply With Quote Quick reply to this message
Old 10-04-2010, 11:29 AM   post #3 of 4
Chagrin
Proud Member of the 1K Club
MTF Member # 11011
Quote:
Eaton 11's are 2:1 for input/output.
One top port is intake from reservoir, second is to auxiliary hydraulics/filter/cooler, return from filter is to the side port, and finally the return to the reservoir is around the output shaft. Correct me if I'm wrong; just expecting that the OP is going to ask.
Chagrin is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-04-2010, 07:59 PM   post #4 of 4
Mark Adams
Senior MTF Member
Mark Adams's Avatar
MTF Member # 34798
Thank You Gentlemen.
I have used the #11 Eaton hydrostatic transmissions in the past and the ratio was 1.8 to 1.
The info that you have given me will help. I think that I will go with a Eaton and not the John Deere hydro..
I was thinking of changing the Eaton hydro. that I put in my tractor. Its real loud and heats up fast. I think that the hydro. has seen beter days.
I was thinking that I would try the John Deere hydro., but the ratio is the problem.
Thank again
Mark
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
