need help: how to hot wire/bypass solenoid - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-17-2010, 11:37 PM   post #1 of 14
ojnmedia
MTF Junior Poster
MTF Member # 46092
Default need help: how to hot wire/bypass solenoid
I have an Craftsman LT 1000
Okay, I went out, got half the yard done stopped to answer a phone call and when I went to restart the mower, "CLICK!" Nothing happened.
Tonight I replaced the battery, CLICK!
Someone told me to take jumper cables and run one from the + side of the battery to the starter terminal post that had the red cable coming off. He said this should make the engine spin. As soon as I connected it, sparks flew everywhere and the split second it was making contact, the motor did infact spin... and the key was NOT in the ignition switch! It scared the #$%^ out of me. I was not prepared for that. So, since the yard is half mowed I'd like to be able to get the mower started while my starter solenoid is on order.
Can someone tell me a STEP by STEP guide on how to get this thing fired up and stay running? Does the key need to be in the ignition and in "on" position?
I
ojnmedia is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-18-2010, 12:11 AM   post #2 of 14
ss12
3K Poster!!!!
ss12's Avatar
MTF Member # 32891
Default Re: need help: how to hot wire/bypass solenoid
just what you did, with the key on. and sparks are normal.
__________________
our house is protected by the good lord and a gun, you might meet em both if you come unwelcomed
ss12 is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 12:15 AM   post #3 of 14
ojnmedia
MTF Junior Poster
MTF Member # 46092
Will it stay running? I mean do I disconnect the cable once it's running? And when the key is turned off, the mower will stop correct?
Thanks!
Old 09-18-2010, 12:19 AM   post #4 of 14
ss12
3K Poster!!!!
ss12's Avatar
MTF Member # 32891
yes, once it starts, unhook the cable. and it will run and drive as usual. all your doing is making it crank, then start. after that, your in normal running mode
__________________
Old 09-18-2010, 12:35 AM   post #5 of 14
ojnmedia
MTF Junior Poster
MTF Member # 46092
great! thanks! I just wanted to make sure because the key wasn't in the ignition when I tapped it the first time.
I was like...
Old 09-18-2010, 12:44 AM   post #6 of 14
ss12
3K Poster!!!!
ss12's Avatar
MTF Member # 32891
your making the starter turn, bypassing the selinoid. thats whats supposed to happen. now get to mowing!
__________________
Old 09-18-2010, 12:45 AM   post #7 of 14
john9001
Senior MTF Member
john9001's Avatar
MTF Member # 45837
Images: 1
do it the safe easy no sparks way, they make a switch just for that, it has a handle with a push button on top and two long wires with alligator clips, mechanics use them to "bump" engines over. The auto parts store will know what you mean. Of course you could just replace the solenoid.
john9001 is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 12:49 AM   post #8 of 14
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
First make sure your PTO is off, the brake is on, and there is weight in the seat.
I bought a new battery and solenoid once to discover my PTO switch was still on.
But jumping from the battery to starter terminals can also be done with a sacrificial screwdriver. It may get hot enough to weld itself to one of the terminals.
Much safer and less dramatic, you can apply 12 volts to the switch terminal of the solenoid with a jumper wire or starter bump switch as mentioned.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 12:51 AM   post #9 of 14
ss12
3K Poster!!!!
ss12's Avatar
MTF Member # 32891
Quote:
thats if the selinoid was good. if he used the bump switch, from positive to starter, the magic smoke would come out of the wires and switch, also likely his hand.
__________________
Old 09-18-2010, 07:03 AM   post #10 of 14
Mike Milburn
Senior MTF Member
MTF Member # 30999
+ D-Dog said make sure it's in neutral, if it does start it'll take off on you since you're bypassing all safety switches.....Mike
__________________
1984 1966 Bolens 19H Kohler
198? 1666 Bolens 17H Kohler
2007 204 Jinma 20 HP 4WD Tractor
Koyker 140 Loader
BH6600 Backhoe
Howse 5ft. Backblade
Mike Milburn is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 07:15 AM   post #11 of 14
junk_jivin38
Senior MTF Member
junk_jivin38's Avatar
MTF Member # 12935
it may be easier to bump the terminal at the starter,dont be timid with the jumper,sooner it makes solid contact,the less sparks it will make,so press it right against the terminal...also,check ALL your grounds...unbolt them,scuff with sandpaper,and reattach...do the same with the solenoid terminals(unhook battery first)...and inspect all wiring for chafing or pinching,unplug all plug-in connectors and check for corrosion,etc...and check any fuses...im not sure which did the trick,but this process worked on my sabre...good luck
junk_jivin38 is offline   Reply With Quote Quick reply to this message
Old 09-18-2010, 07:21 AM   post #12 of 14
junk_jivin38
Senior MTF Member
MTF Member # 12935
oops...was thinking you said you were bumping the solenoid,but after rereading,i see you were bumping at the starter
please ignore my ignorance
Old 09-18-2010, 07:45 AM   post #13 of 14
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-18-2010, 05:08 PM   post #14 of 14
GA_Boy
Senior MTF Member
MTF Member # 47275
I have one of those button type with aligator clips, however, the wires on mine are 12ga and not designed to go from battery to starter for cranking. Mine is designed to go from B+ (Big post cable from solenoid to battery)to crank side of solenoid (Small post from ignition switch.) and that activates the solenoid to allow full amperage to start the mower.
If you have large enough wires on the button it would work fine going from Battery direct to starter stud.
I have the same problem on one of my mowers intermitently and I haven't troubleshot the find the problem. Could be several things to include ignition switch, solenoid of one of several safety switches.
Marvin
GA_Boy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
