2000 RPM Rear PTO Output shaft gears - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-17-2010, 09:09 PM   post #1 of 3
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Default 2000 RPM Rear PTO Output shaft gears
I've seen plenty of PTOs for the 300 series with broken output shaft. The gear, item 22, pn M86234 is NLA as most PTO owners know.
Is there any interest in one? I'm going to talk to a machine shop who can do heat treating about repair or manufacture of the shaft.
Any serious interest?
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-17-2010, 11:37 PM   post #2 of 3
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Default Re: 2000 RPM Rear PTO Output shaft gears
Come on folks, here's a chance to bring back many of the old 2000 series rear PTO's rather than scap them! The more that jump on this I'm sure the lower the cost will be!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-18-2010, 11:23 AM   post #3 of 3
hgl1
Senior MTF Member
hgl1's Avatar
MTF Member # 20597
Garage
Hey D_Dogg
I am in the same boat as you where mine has actually broken a chunk out between the two of the balls on the rear output side. I have made a bunch of inquiries and the only solution that has come up that would work for me was to purchase a shaft that goes all the way through and comes out the front side and then machine a groove for a circlip to hold it from sliding out the back and then weld on a new hub assembly on the rear side. I was quoted a little less than $200.00 for the parts and then whatever cost for machine work / welding. The 2 downsides would be that I would need to find a way to get the circlip off from under the tractor if I needed to remove it (which should not be very often) and then the PTO shaft to some implements may have to be shortened. But at least it would be useable. I am more interested in function than form however if it did look more like an unbroken original that would be good too.
Hopefully you can find a way to make it more like the original.
Keep us posted. And good luck.
hgl1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
