How do I get the clutch off? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-17-2010, 11:31 AM   post #1 of 18
JDH
MTF Junior Poster
MTF Member # 50463
Default How do I get the clutch off?
I have an STX38 and the clutch is gone in it...according to the JD dealer. I was thinking about replacing it myself and saving $200. The only way I can figure out to get to the clutch is to take the deck off, then use my chain hoist to haul the front end up in the air so the tractor is balanced on it's rear end. Then I can see what I'm doing.
I'm a strong do-it-yourselfer, but I don't work on tractors, cars, etc. so I don't have the "feel" you need for that kind of work. Does anyone have some suggestions of what to do?
I have both STX manuals, and tried to read through the clutch part but it was just too tough. Couldn't make sense of it.
JDH is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-17-2010, 12:23 PM   post #2 of 18
Keghead
Senior MTF Member
MTF Member # 37257
Default Re: How do I get the clutch off?
If the clutch on your tractor is attached the same way as clutches on larger GTs with vertical shaft engines and its not rusted on, it's a piece of cake... just remove the bolt and it'll slip off easily. I once replaced the clutch on my old 265 and it came right off with no difficulty. Last fall I had to remove the clutch on my 335 and that was a different matter... it was frozen on solid and no amount of PB Blaster would free it up. This clutch was still in good shape and I ended up destroying it getting it off.
My suggestion to you is that if you plan on keeping your tractor for a while, get some antiseize compound and apply it to the crankshaft before putting the new clutch on... it'll make it much easier to remove it later on.
__________________
2009 X728, 54C mower with mulch kit, 47" snowblower, 45 loader, 3pt hitch, United 448HD box scraper
2000 335
Keghead is offline   Reply With Quote Quick reply to this message
Old 09-17-2010, 02:22 PM   post #3 of 18
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
looking at the exploded parts diagram, just what part of your clutch is gone? It looks to me to be a mechanical pedal to idler wheel setup. No clutch plates or anything to break say the drive belt. What is it not doing, if it isn't re-engaging then likely just a weak return spring or an adjustment.
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is offline   Reply With Quote Quick reply to this message
Old 09-17-2010, 03:03 PM   post #4 of 18
JDH
MTF Junior Poster
MTF Member # 50463
It wouldn't start so I took it in to the dealer. The starting problem was that the spark plug cable wasn't completely seated. But he also found that an idler was bad and a couple bearings were bad plus the clutch was going out.
I don't have a job and since he got the mower started, I thought I'd just keep mowing with it and put off spending the money. Well, I mowed over a small, low stump I've mowed over before without any trouble, but this time the blade caught and stalled the motor.
When I got it started and back into gear, it made a really funny noise and wouldn't drive very well. Now, if the motor is off and it's in gear I can push it around. Before, being in gear would lock it if the motor was off.
The clutch part number the dealer gave me shows a completely contained unit if you search on the JD website.
What's the easiest way to remove the clutch? Do I just haul the mower vertical on my hoist like I mentioned or is there a better way? I'm assuming the stump just finished the clutch off.
Old 09-17-2010, 04:00 PM   post #5 of 18
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
OK, I'm looking at this and thinking we're talking different tractors. Here is the drivebelt/clutch diagram. Looks like pulley (#29) moves back to release (clutch) the drive. I've seen a number of posts about this setup and most recommend to lift the tractor up to work on it.
__________________
Old 09-17-2010, 04:17 PM   post #6 of 18
wolfie1959
Senior MTF Member
wolfie1959's Avatar
MTF Member # 49987
I think he may be talking about the PTO clutch. Not sure though.
__________________
2010 John Deere X530 w/54" deck and Brush guard
1976 John Deere 210 (gone but not forgotten)
1997 John Deere GT242 (1100 hrs)
1953 Ford Jubilee
2009 Chevy 2500HD with 8'6" Fisher SS EZ Vee Plow
wolfie1959 is offline   Reply With Quote Quick reply to this message
Old 09-17-2010, 04:28 PM   post #7 of 18
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I wasn't sure exactly that's why I posted the diagram, but that makes more sense! I'll have to go back through the sections to see if I can find the PTO.
__________________
Old 09-17-2010, 04:46 PM   post #8 of 18
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Here is the PTO looks like you should be able to remove and open to see if it can be fixed. Most PTO's, Part # 7,5, and 4, have a snap ring on the upper side, remove it an then you should be able open to see the field coil and magnets. I know one forum member, a machinist, had one with scratches in it and took it to work put it on a lathe and cleaned it up. Said it worked perfectly after he put it back on and gapped it!
__________________
Old 09-17-2010, 06:01 PM   post #9 of 18
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
If it is the PTO clutch the easiest way to remove the bolt is with an impact wrench.
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Old 09-17-2010, 08:59 PM   post #10 of 18
Jgj5150
Proud Member of the 1K Club
Jgj5150's Avatar
MTF Member # 41313
The pto clutch has nothing to do whatsoever with the tranny or drive wheels. It is for the mowing deck only.
__________________
JD 455 Diesel
JD 332 Diesel.
JD 330 Diesel
JD 1964 110 RF (my baby, s/n 11300 restored)
JD 1965 110 x2 no engines.
JD 1966 110 RF non running
JD 1967 110 RF non running
JD 1968 110 SF non running
JD 111 non running.
JD 60 x2 non running
JD RX95 bought new by my dad in 1984
JD SX75 not running
JD 68 wore out
JD 1957 720LP
Jgj5150 is online now   Reply With Quote Quick reply to this message
Old 09-17-2010, 09:55 PM   post #11 of 18
Herd of Deeres
MTF Member # 32443
Quote:
True. But there's also no clutch per se in the driveline, just a tensioner pulley on the drive belt. Hence the confusion.
__________________
Current Herd:
1963 John Deere 110
Deerely DeParted:
Old 09-18-2010, 01:40 AM   post #12 of 18
MXZRXP
3K Poster!!!!
MXZRXP's Avatar
MTF Member # 48748
if he is talking about the pto "clutch"-
and assuming replacement with a new one, it is a simple task if it takes more than 30 mins something is wrong
I just did the STX38 recently.
Remove the mower deck
Remove the gas from the tank
Push the mower over on its side
Remove the spark plug
put some nylon rope into the spark plug hole (use a LONG piece)
rotate the shaft until the rope is compresssed
now turn the crankshaft bolt and it will come loose
disconnect wire from above deck
clutch will come right off
push wire through deck
install new, tighten bolt!
done
REMOVE NYLON ROPE BEFORE TRYING TO START
(after turning mower upright, let it sit for 10 mins or so to be sure all oil returns to the bottom of the motor)
REPAIR
the pto "clutch" is just a big electromagnet, you can test it by putting 12Vdc across the two wires. With no voltage, the two parts should spin independantly, with voltage applied the two parts are pulled together and will NOT spin seperatly)
It also has an adjustable gap to allow it to "slip" when non powered. I believe the correct gap is .012 you use those three spring loaded nuts to set the gap.
your dealer said it was gone? I would ask what GONE actually means? is an actual metal part broken??, a bushing shot?, or maybe one of the windings in the magnet bad??
often a take apart and a good cleaning and re-gapping is all that is needed!
ask if more questions-
MXZRXP is online now   Reply With Quote Quick reply to this message
Old 09-18-2010, 06:01 AM   post #13 of 18
Herd of Deeres
MTF Member # 32443
While this method may work I would not recommend it. There is a risk of valve damage when you compress the rope with the piston, particularly if you happen to be on the exhaust stroke. The OEM recommendation is to remove the top engine cover and access the flywheel bolt to hold the crankshaft from moving and counter the torque required to break the PTO bolt free. If you have access to an impact wrench neither method is necessary and you are done in about 30 seconds.
__________________
Current Herd:
1963 John Deere 110
Deerely DeParted:
Old 09-18-2010, 07:30 AM   post #14 of 18
MXZRXP
3K Poster!!!!
MXZRXP's Avatar
MTF Member # 48748
Quote:
been doing this a real long time and have NEVER seen damage, 2-stroke, 4-stroke, over and under cams, etc. while I would agree it is "possible" to do damage it is HIGHLY unlikely, but if a black cloud seems to follow you maybe try another tactic...
I would also agree if you have an impact wrench use it and if really fearful HODs sugesstion will work very well, might take two people too, but for the do it yourselfer on a budget, fill it with nylon... and never look back
Sponsored Links
Advertisement
Old 09-18-2010, 09:11 AM   post #15 of 18
Herd of Deeres
MTF Member # 32443
The black cloud seems to follow me more closely than others. Plus Mrs. Herd bought me a new impact wrench for my birthday
__________________
Current Herd:
1963 John Deere 110
Deerely DeParted:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
