318 tail lights - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-11-2010, 11:51 PM   post #1 of 33
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
Default 318 tail lights
Anyone know where I can buy tail lights for a 318. I know John Deere can order them and evil bay has them for about $70 for the set. I haven't checked pricing from John Deere but evil bay price of $70 bucks seems a little steep to me.
enzminger is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-12-2010, 12:02 AM   post #2 of 33
Markcuda
Banned!
MTF Member # 13642
Smile Re: 318 tail lights
Check out this link, has to be something that you can use instead of paying 70 bucks for.
http://www.easternmarine.com/TRUCK-L...Marker-Lights/
Markcuda is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 12:04 AM   post #3 of 33
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Default Re: 318 tail lights
enzminger, I have a second seat pan and I'm considering putting it to work and I'll be needing a set for it too. If I find a good source I'll PM you, if you find one PM me!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 12:10 AM   post #4 of 33
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
Thanks. I will let you know if a find anything. I will call John Deere to see what they want just out of curiosity. I do know I will not spend $70. I will find a set of LED's if that's what original equipment will cost.
Old 09-12-2010, 12:16 AM   post #5 of 33
SWIGIN
John Deere 316 Onan
SWIGIN's Avatar
MTF Member # 41778
Images: 3
Please post here when you get a price from JD or when you find something aftermarket. I'm in need of some as well.
Thanks
__________________
1988 316 Onan P218 with 50'' deck
770 hours
4 way 54'' snow blade
Custom trailer lifter run off rock bar
Stainless grab handles
Custom graphics
Original UNCRACKED seat....lol
318 H2 swap with hydro cooler
Loaded tires (16 gallons)
318 tail lights
318 brake pedals
www.egiautowraps.com
SWIGIN is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 12:18 AM   post #6 of 33
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Give JD a shot.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 12:41 AM   post #7 of 33
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
Well, I found these in a few minutes of searching the web. They are LED's and dimensions of the light would work (according to my measuring skills).
http://www.iboats.com/LED-Oval-Boat-...view_id.164144
Old 09-12-2010, 12:49 AM   post #8 of 33
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Thanks! Might order a set, I don't need the 2nd pan to look that good. I'm setting it up for the cab and it'll only be on for the winter months!
__________________
Old 09-12-2010, 09:59 AM   post #9 of 33
FD611V
MTF Member # 12772
I may be all wet here, but, when you install LED lights to a regular 12 volts system and turn on the switch the 12 volts will blow the LED's in a flash of a second. You have to have resisters somewhere in between. Correct?
FD611V is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 10:41 AM   post #10 of 33
Markcuda
Banned!
MTF Member # 13642
If this is true, it is a new one on me.
Old 09-12-2010, 11:28 AM   post #11 of 33
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
I don't know. ?????
Old 09-12-2010, 11:31 AM   post #12 of 33
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
If that is true, you would think whatever is needed would be supplied (resistors??). I know guys that have put LED's on tractors and they never said anything about it.
Old 09-12-2010, 11:36 AM   post #13 of 33
pigsitter
the "AWOL member"
pigsitter's Avatar
MTF Member # 1020
Images: 1
Quote:
As long as they are designed for a 12volt system there should be no problem at all.You can buy 12volt LED clearance lights most anywhere trailer lighting is sold
__________________
My favorite song
proud to be a member since 2005 and aggravating Ken in NJ since sometime shortly thereafter
Uh Oh! someone left the gate open, pig's gone walkabout again!!
Where is everybody?
pigsitter is offline   Reply With Quote Quick reply to this message
Old 09-12-2010, 11:36 AM   post #14 of 33
FD611V
MTF Member # 12772
I tried the LED's and they blew in a split second... Read below on why. The 12 volts system on a lawn/garden tractor probably is not setup for LED lights.
http://www.offroaders.com/tech/LED.htm
LED lights are fast becoming the light source of choice in many applications. There are good reasons for this. LED lights consume about 10th the power of a standard comparable light bulb making them much more efficient. LEDs also last much longer than standard light bulbs at approximately 100,000 hours. Recent advances have produced high light output LED lights that make them more desirable as a light source over the previous generation of LEDs that most people are used to seeing. Also LED manufacturing has produced mass quantities of LEDs at a very small cost per LED making LED much more affordable.
In the vehicle the LED (light emitting diode) is commonly used as an indicator for alerting you if a circuit is powered on. However you can't simply plug an LED into your 12 volt power supply in your vehicle and expect it to work. The common LED requires only 2 volts to work so the power supplying your LED needs to be reduced from 12 volts down to 2 volts. That is accomplished by using a resistor. Note: typical LEDs require 2V for each LED however some require 4V such as for blue and white LEDs.
In the diagram to the right, the "R" is a 470 or 560 ohm resistor, either will work for the common LED requiring 2 volts. You will need to acquire one resistor per LED. Resistors can usually be purchased in the same electronics stores as the LEDs themselves.
Sponsored Links
Advertisement
Old 09-12-2010, 11:40 AM   post #15 of 33
pawber
Senior MTF Member
pawber's Avatar
MTF Member # 33692
This set works with 9 - 16volts dc. I think all of the boat & truck clearance lights are for 12v dc systems.
__________________
Paul B
09 JD X300/42X deck
02 JD 724D snowblower
had a JD 214 - 11 years
had a Bolens QT16 - 7 years (talk about a whiney transaxle)
had 2 Bolens 1050's - 21 years & 3 years
pawber is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
