Cab Heaters - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-02-2010, 07:57 PM   post #1 of 10
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
Default Cab Heaters
I am wondering if anyone out there uses an electric heater for inside their cab. I have a 345 which is liquid cooled but was told it would not have enough coolant circulation for that type of heat source. So, I have been looking for some type of small electric heater for inside my cab. Would an electric heater draw too many amps? Any input or opinions would be appreciated.
enzminger is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-02-2010, 09:25 PM   post #2 of 10
rscurtis
5000 Strong & Climbing
MTF Member # 25367
Default Re: Cab Heaters
There is a lot more heat available from the engine than you'll be able to get from any electric source. A typical home space heater (1500 watts) would require 125 amps at 12 V. Where are you going to get that on a tractor? You could probably find a small coolant powered unit, but it would have to be plumbed into the engines bypass loop, not into the radiator.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 09-02-2010, 09:30 PM   post #3 of 10
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Have you checked out this post: http://www.mytractorforum.com/showthread.php?t=52500
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is offline   Reply With Quote Quick reply to this message
Old 09-02-2010, 09:32 PM   post #4 of 10
Brett-JDX748
Has anyone seen ChimChim?
Brett-JDX748's Avatar
MTF Member # 1790
Images: 1
Battery powered heaters are a joke. I had a purpose made one in my 425 cab, battery hard wired, drew 60 amps, I could fart and make more heat.
I am just finishing up a coolant powered system right now, I expect it will roast me out of the cab.
__________________
X748 Ultimate,
Diesel, 4x4, 62C MMM, SE Seat, Quick Hitch,
54" Plow, 26Gal Sprayer, Soft Cab, 10P Cart.
That knockin, ain't a loose rod, Son!
Photos
Former Fleet:
2009 Craftsman GTS5000 Excellerator - Sold
Photos
2006 John Deere 3320, FEL, Backhoe, 62 MMM - Sold
Photos
2005 Cub Cadet 6284D FEL, Backhoe , 70" rear finish mower - Bought back, LEMON
Photos
Brett-JDX748 is offline   Reply With Quote Quick reply to this message
Old 09-02-2010, 11:28 PM   post #5 of 10
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
Thanks for the info. I was told my 345 would not circulate coolant enough to use a heater core. Does anyone know if this is true or has anyone tried it in a similar sized tractor??
Old 09-02-2010, 11:33 PM   post #6 of 10
Brett-JDX748
MTF Member # 1790
Images: 1
Kawasaki VTwin? It absolutely will circulate the coolant, Deere offers heaters for tractors with Kaw twins.
__________________
X748 Ultimate,
Photos
Former Fleet:
Photos
Photos
Photos
Old 09-03-2010, 09:53 AM   post #7 of 10
Victory
Senior MTF Member
MTF Member # 6699
Images: 3
They used to sell 12V heaters for dune buggies years ago. Might want to look into that?
Would a heated seat cover do the trick? If the butts warm the rest is warm.
Victory is offline   Reply With Quote Quick reply to this message
Old 09-04-2010, 09:15 AM   post #8 of 10
deereguy58
Senior MTF Member
MTF Member # 37427
Quote:
maybe one of these will work for you.
http://www.utvpartsandaccessories.co...ab_heaters.htm
__________________
1984 318 b43g
50 inch deck
loaded tires
deereguy58 is offline   Reply With Quote Quick reply to this message
Old 09-04-2010, 09:21 AM   post #9 of 10
deereguy58
Senior MTF Member
MTF Member # 37427
here is another one.
http://www.rubicon4x4.com/product_in...ducts_id=42439
__________________
1984 318 b43g
50 inch deck
loaded tires
Sponsored Links
Advertisement
Old 09-04-2010, 09:51 AM   post #10 of 10
enzminger
MTF Member
enzminger's Avatar
MTF Member # 33553
Garage
Thanks for the links deereguy58. I like the second link heater. I went outside to the garage and looked at the engine. I am going to have to try and figure out which coolant lines to try and tap into.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
