Ford 1300 Headlights Schematic Diagram - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-02-2010, 01:30 AM   post #1 of 8
blewey
MTF Junior Poster
MTF Member # 49182
Default Ford 1300 Headlights Schematic Diagram
My headlights stopped working and I cant figure out why. The lights themselves are OK and everything else is appears to be plugged in. Niether hi or lo beams come on. Is it the switch? If I knew the color codes of wires in the harness I could check it. Is there an electrical schematic posted anywhere?
blewey is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-02-2010, 08:39 AM   post #2 of 8
donimbimbo
1981 Ford 1100 4WD
donimbimbo's Avatar
MTF Member # 18958
Default Re: Ford 1300 Headlights Schematic Diagram
There is no Hi and Low beam on my 1100. Are you sure that's the case with yours? The wiring is pretty simple on that diesel. Get the color up at the headlight. I'll pull out my schematics, I suspect there's a fuse in there some where.
__________________
Ford Mustang 1990
Ford 1100 Tractor 4WD 1981
Ford LGT14H Tractor 1988
Subaru Forester 2014 (Wife's car)
Honda 1100 Shadow Sabre 2000 (being restored)
donimbimbo is offline   Reply With Quote Quick reply to this message
Old 09-02-2010, 11:19 AM   post #3 of 8
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Dumb question, have you checked for a fuse? If both stopped at the same time then I would start looking with a volt meter to follow the voltage from the battery to the switch I bet you would find the problem. As said the wiring is pretty simple on a tractor.
__________________
JohnW is offline   Reply With Quote Quick reply to this message
Old 09-04-2010, 12:40 AM   post #4 of 8
blewey
MTF Junior Poster
MTF Member # 49182
there are 2 orange wires going to each headlight, I'll check for stripes in the morning daylight. I checked the fuses and the bulbs but the wires are hard to follow through the engine then the harness plug, everything is wrapped up in plastic tape and the colors going into the switch are dark blue or black. I cant get to the switch yet, I have to my kid out there to help do that. the switch has two positions, the manual says pull for high beams and pull some more for low beams. - anyhoo, I'll check closer for wire colors and stripes.
Old 09-05-2010, 08:42 AM   post #5 of 8
donimbimbo
1981 Ford 1100 4WD
donimbimbo's Avatar
MTF Member # 18958
Since the hood is hinged, you should also check for the ground wire. Mine has the ground wire on the right front corner of the hood, grounding it to the frame. If this got broken then your only ground for the head lights might be through the hinge.
__________________
Ford Mustang 1990
Old 09-10-2010, 07:33 AM   post #6 of 8
donimbimbo
1981 Ford 1100 4WD
donimbimbo's Avatar
MTF Member # 18958
I have a schematic for my Ford 1100 in PDF form. It should be similar to your 1300. But it's too large to upload to the forum. If you send you email address to me in a orivate message I can email it to you.
__________________
Ford Mustang 1990
Old 09-10-2010, 07:38 AM   post #7 of 8
donimbimbo
1981 Ford 1100 4WD
donimbimbo's Avatar
MTF Member # 18958
OK here it is as a JPEG file.
__________________
Ford Mustang 1990
Sponsored Links
Advertisement
Old 09-12-2010, 02:07 PM   post #8 of 8
blewey
MTF Junior Poster
MTF Member # 49182
Quote:
thanks donimbimbo, this will help me a lot. it looks very similar to what I have, only a couple of differences but at least now I know what to start checking for. one difference of note is that the schematic shows one red wire to the headlights, I have 4 orange wires...but otherwise all the components and switches are similar to this layout .
Bill
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
