wheelhorse 310-8 blowing fuses? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-28-2010, 10:41 AM   post #1 of 8
BOLENSBOY60
Proud Member of the 1K Club
BOLENSBOY60's Avatar
MTF Member # 37707
Default wheelhorse 310-8 blowing fuses?
good morning to all-- i have a model 310-8 kohler engine- all of a sudden i keep blowing the 5 amp fuse when i turn the key switch to the on position- ? i just cannot pin down the cause- should this fuse be energized in only the on position i would think it would only be when you turn the key to the start position- i am thinking i may need a starting switch/ any suggestions thank- you !!
BOLENSBOY60 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-28-2010, 10:53 AM   post #2 of 8
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
Default Re: wheelhorse 310-8 blowing fuses?
Sounds more like a 'dead short"--can you trace that wire? Do you have the diagram for that tractor? That can be had from TORO website..
Also--can't be much draw--with only a 5amp. fuse..
glenn
__________________
Sometimes you just have to laugh..To keep from going insane!!
Jimmy Buffett
glenn27 is offline   Reply With Quote Quick reply to this message
Old 08-28-2010, 11:04 AM   post #3 of 8
BOLENSBOY60
MTF Member # 37707
i was also thinking a 5 amp is`nt much- i do have the wiring diagram i was thinking the switch is shorting out- put a nwe switch on it and it still pops- wrong switch?
Old 08-28-2010, 11:10 AM   post #4 of 8
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
Yepper--you could install a new switch, but , basically--that's just throwing parts at something that might not be....
I would want to knmow what is going on, first..
Let me interject another idea--as this happened to my Scott's mower.
Little mites , or some insect--got down in the key hole, and made a nest (twice)--I cleaned it out best I could with an ice pick--then compressed air, then gave it a shot of CRC electronic cleaner---now I stick a little wedgie in the key hole when done mowing....
Stuff never ends...
glenn
__________________
Jimmy Buffett
Old 08-28-2010, 11:16 AM   post #5 of 8
tackit
Senior MTF Member
tackit's Avatar
MTF Member # 45632
Images: 10
check to make sure the bare parts of the switches spade wire terminals under the switch are not touching each other, they can get bent when installing a new switch too, they bend easily... is the battery holding charge?
__________________
The early bird gets the worm, but we all know it's the second mouse that gets the cheese
tackit is offline   Reply With Quote Quick reply to this message
Old 08-28-2010, 11:28 AM   post #6 of 8
BOLENSBOY60
MTF Member # 37707
thanks for the advice battery is good- it`s got to be a short in the switch?
Old 08-28-2010, 12:23 PM   post #7 of 8
gwest_ca
MTF Member # 20903
What is the long model number of your tractor? Some of the wiring diagrams Toro has posted are not correct for the 310-8. The engine spec number would help.
Garry
gwest_ca is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-28-2010, 09:47 PM   post #8 of 8
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
In the instructon booklet that came with my WH 211, it has a schematic for the 310 which shows a 5 amp fuse in the hourmeter/voltmeter circuit and a 15 amp in the solenoid/start circuit. Not 310-8 specifically.
The 5 amp would blow if the hourmeter or voltmeter is defective. Attaches to a pink wire. It's energized in the 'run' position, only.
The 15 amp would blow if the solenoid/starting circuit is defective. Attaches to a red wire.
Headlights are AC, off the engine with no fuse, right?
UNLESS, as Garry says, published 310 schematics sometimes aren't correct.
engine2quarters is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
