1952 Ford 8N value - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-27-2010, 12:07 PM   post #1 of 20
rwairforce
Senior MTF Member
MTF Member # 606
Default 1952 Ford 8N value
Guys, I have no idea about current day value of something such as this. Does having 12 speeds make that much difference? It's a tractor not a race car. Please give me your over all opinion regarding the price for the tractor and attachments...
Thank you very much. http://columbus.craigslist.org/grd/1921956370.html
Randy
One other thing, how much would this weigh with the cutter hanging on back? I'm thinking about what size of trailer I would need if I wanted to start cutting small fields etc.
__________________
Randy
Cubs: 71, 73, 127, 149, 1440, 2186, GT1554, and 1864
John Deere 110 round fender
Sears: GTV16
rwairforce is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-27-2010, 12:16 PM   post #2 of 20
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Default Re: 1952 Ford 8N value
Here are some going prices around the country..CLICK HERE..
I have never hauled one, but a neighbor has used his 16' tandem utility trail bumper pull with no problem.
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Old 08-27-2010, 12:24 PM   post #3 of 20
rwairforce
Senior MTF Member
MTF Member # 606
Thanks Ken.
Looks like there all over the place on the value meter.
Is that 12 speed trans something to avoid or is it ok, I'm thinking realiable when I say ok.
__________________
Randy
Sears: GTV16
Old 08-27-2010, 12:29 PM   post #4 of 20
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Quote:
Originally Posted by rwairforce View Post
Thanks Ken.
Mine has an 8 speed..It comes in handy at times..
__________________
Old 08-27-2010, 12:35 PM   post #5 of 20
Steve (Magnolia, TX)
Retired - Veteran Mod
Steve (Magnolia, TX)'s Avatar
MTF Member # 251
Images: 13
Garage
...Is that 12 speed trans something to avoid or is it ok, I'm thinking realiable when I say ok.
I don't have an auxillary transmission in my 8N (and a 12-speed is the standard 4-speed transmission... with an over/under drive auxillary tranmission added in) so I can't speak "authoritatively" to it, but...
From what I've heard... the transmissions are quite reliable... as long as they are shifted by a lever rather than a cable (and I don't recall if there was ever an over/under with a cable shift or not)... and the only "unreliable" part of the cable shift was that after 50 or 60 years of use (and abuse?) the cable had a tendancy to rust through and break... and they were "challenging" (to say the least) to find replacments for.
Steve (Magnolia, TX) is offline   Reply With Quote Quick reply to this message
Old 08-27-2010, 12:38 PM   post #6 of 20
rwairforce
Senior MTF Member
MTF Member # 606
Thanks Steve.
Finding parts is always a concern when looking at something so old. It's the same age as me but I could probably find parts for myself easier....but way more costly.
__________________
Randy
Sears: GTV16
Old 08-27-2010, 12:38 PM   post #7 of 20
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Steve, mine is the cable..
__________________
Old 08-27-2010, 12:39 PM   post #8 of 20
MTF Member # 251
Images: 13
Garage
Well... actually, the standard parts for the 8N are EASY to find... and pretty affordable (for the most part) too.
Now... add-ons (like the auxillary transmissions) and your "not commonly replaced" parts (such as castings, etc) are a bit harder to come by...
Old 08-27-2010, 12:45 PM   post #9 of 20
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
My Hi/Lo cable.
Sherman 12 speed.
__________________
Old 08-27-2010, 12:53 PM   post #10 of 20
rwairforce
Senior MTF Member
MTF Member # 606
Great, so that cable runs down inside the case, making it a big job to replace.
The seller mentions the PTO upgrade, is that still a standard size? I don't want to be limited to only special implements that can be attached.
Thanks a lot guys.
This little guy is interesting to me because I used to rake hay when I was 16 and it was just cool. It was the first spread frontend tractor I had driven and I felt safer on it than our IH Super C.
Would it be a good tractor to mow say a 5 to 10 acre field?
__________________
Randy
Sears: GTV16
Old 08-27-2010, 01:00 PM   post #11 of 20
MTF Member # 251
Images: 13
Garage
Thanks a lot guys.
PTO upgrade. Kinda depends on who's telling you, as to what he's referring to.
I would call a PTO upgrade a replacement shaft... making it the SAE standard 1 3/8" (stock was 1 1/8")... making it easier to attach implements... although you WILL want to ensure that you've got an ORC (OverRunning Clutch) installed... speaking of which... this *may* be the 'upgrade' that the seller is referring to.
As to mowing... this tractor is ideal for mowing 5 - 10 acres. I just mowed about 10 acres of hay with mine (and my John Deere #5 Power Mower) on Sunday... then raked all that hay on Wednesday.
Old 08-27-2010, 01:04 PM   post #12 of 20
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
The only PTO attachments that I have ever used were the mower and post hole digger. Thats about all that is used today.
__________________
Old 08-27-2010, 01:10 PM   post #13 of 20
rwairforce
Senior MTF Member
MTF Member # 606
Thanks guys....
He does mention "new upgraded 1 3/8 pto shaft with new pto overrider clutch"
In his ad.
Is there anything else I should look for on this tractor? Any typical failure items that I should inspect?
Thanks again.
__________________
Randy
Sears: GTV16
Old 08-27-2010, 01:10 PM   post #14 of 20
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
I finish mow my 10 acres weekly. Does a great job. If you have a lot of trees, shrubs, etc it makes it a little tougher.
__________________
Bob
Old 'n Cheap
Bad part of being older...you can remember when things that now cost $10 were only 50 cents
46 2n - waitin on me to do something to it.
47 2n - my relaxin tractor.
64 4000 - w/7 ft finish mower, scoop and bushhog.
ryork is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-27-2010, 01:15 PM   post #15 of 20
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Thanks again.
READ THIS
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
