is using starter fluid and carb cleaner bad? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-19-2010, 10:22 PM   post #1 of 2
moose5488
MTF Junior Poster
MTF Member # 46991
Help is using starter fluid and carb cleaner bad?
Hello, i have a jd z425 mower with a 23 hp ohv briggs
a month ago i had a fuel related problem,would start, run die over and over.
i asked you guys for help and got a couple ideas. i replaced the gas,filter,
all fuel lines and clamps,the little hose going to the fuel pump from valve cover,
and then the fuel pump itself.also the spark plugs,air filters,and oil.also checked gas cap vent-ok
it started and ran great, i mowed 3 or 4 times over two weeks.it got very hot here like near 100 for over a couple of weeks. the mower and my full gas can,plastic with a lid, set in a lean too shed for a couple weeks not started. i went out yesterday and started it,it started ran alittle and died.now it will not start. i checked the entire fuel system the pump is pumping gas is getting to carb. i have spark.will start and run with starter fluid just till it burns that. i had squirted carb cleaner into the fuel tube at carb last time.i am now told by jd service men that the needle valve pin is plastic,pickup tubes are plastic and rubber o-rings in carb can be ruined by carb cleaner, also starter fluid is very bad on engine.apparently my gas is going bad quickly and gumming up my carb?it is very difficult to get too this carb engine sets down in frame,and the carb and intake manifold have to be taken off to get to the bowl screws.does anyone have any experience with this and facts about use of these fluids?Thanks
moose5488 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-19-2010, 10:27 PM   post #2 of 2
roughrider
Proud Member of the 1K Club
roughrider's Avatar
MTF Member # 45937
Default Re: is using starter fluid and carb cleaner bad?
yes carb cleaner is hard on o-rings and the plastic ..I made this mistake myself once and had to replace the o rings and gaskets ...Brake clean will do the same thing ,,,Carb cleaner is meant to be sprayed down the throat of the carb while its running to remove carbon and gunk from it ..Its not meant to be sprayed on the gaskets or o rings and plastic on the inside of the carb
roughrider is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
