adding lights? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Register Home FAQ Garage MTF Gallery Search Today's Posts Mark Forums Read Store Chat Room [1]
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 08-17-2010, 09:36 PM   post #1 of 32
JakeBlues652
Senior MTF Member
JakeBlues652's Avatar
MTF Member # 32094
Images: 2
Default adding lights?
ive been toying with the idea of making a GT specifically designed for plowing snow in the winter months. you gotta have the duals if your gonna buld one for plowing itself. then i decided, well, when im plowing at night, so i dont get nailed, and for looks, you need to add a couple of lights.
just so happens, i got the northen tool catalog today! what timing?! after dinner i took a browse through the trailer lights. i found some nice ones. i narrowed it down to this one: http://www.northerntool.com/shop/too...4535_200324535
it says it operates from 9-16 volts. if i ran two of these, on an older cub cadet with the starter/genarator type system, i would need another power source wouldnt i? i figured id need some sort of alternator to keep up with the power demand. so lets figure i do need an alt. i could hook it up to the PTO and turn it on when the lights were on right? then i could just wire the alt into the battery and tie the lights into the battery with a switch on the dash.
with these lights being ones with an optional turn signal, is there a possible way to wire them to they are flashers sometimes and just solid others? i would need some kind of relay wouldnt i?
throw in your suggestions. im open to ideas of any kind.
sorry for the dumb questions..im new at this wiring stuff
__________________
Proud Owner and operator of:
1985 John Deere 212
2010 Polaris Sportsman 500 H.O.
1999 Chevy Silverado 2500 6.0
1967 Chevy C/10 4x4 5.0 with a 3" lift and 35's
2000 Chevy S-10 with the MASSIVE 2.2
I'll keep my guns, freedom, and money.
You can keep the 'change.'
-Hank Williams Jr.
JakeBlues652 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-17-2010, 10:00 PM   post #2 of 32
jason4567
Proud Member of the 1K Club
jason4567's Avatar
MTF Member # 30557
Garage
Default Re: adding lights?
That page doesn't mention how much amperage those draw, so it is hard to say. I think that you would get away with it. As far as the blinker function, I don't know. I have never wired something like that. I had a Bolens 1050 that actually had 2 of the starter generators mounted on it to supply more power. The second one was wired completely independent from the first.
Jason
__________________
Bolens
Tube Frame: 600, 800 (2), 900 (2) 1000, 1050 (4), 1225, 1254 (2), 1256, G14, H14
Large Frame: 1250 (5), 2086
Others
Bolens RAM, Bolens FS-11, Copar Panzer, Sears SS12, Sears Custom 6, Gravely LI, L8, L, Comm.10a, Farmall Cub
jason4567 is offline   Reply With Quote Quick reply to this message
Old 08-17-2010, 10:05 PM   post #3 of 32
89YT12
2000 Posts and climbing!!!
89YT12's Avatar
MTF Member # 35873
Images: 9
Garage
the amp draw on dim is under 1 amp, they are LED you could power them off of a garage door opener battery if you wanted, thats how little amps they take,same goes for bright
you can wire in a flasher to get them to flash, but you have to get a eletronic flasher not a thermal, just the 2 blade one will work
__________________
Jason "J"
89YT12 is online now   Reply With Quote Quick reply to this message
Old 08-17-2010, 10:18 PM   post #4 of 32
HydroHarold
10,000 +posts!
MTF Member # 82
Images: 1
Quote:
... you gotta have the duals if your gonna buld one for plowing itself.
I'd forego that one right away and save the money for LED lighting and a set of chains. Duals are great for traction in the dirt but not so hot in snow/ice. Singles w/proper weight and chains will serve you far better this Winter.'
Funny, I was just looking at the page below for lights before I logged on here:
http://vehiclelight.com/clli.html
Might be an alternative...
HydroHarold is offline   Reply With Quote Quick reply to this message
Old 08-17-2010, 10:28 PM   post #5 of 32
89YT12
89YT12's Avatar
MTF Member # 35873
Images: 9
Garage
ohhh chicken lights
__________________
Jason "J"
Old 08-17-2010, 10:28 PM   post #6 of 32
jason4567
jason4567's Avatar
MTF Member # 30557
Garage
I agree. Dual allow for wider weight distribution which means less pressing down on a small area which ultimately means less traction (at least that's how it was explained to me). You are best off with relatively narrow tires and plenty of weight.
Jason
__________________
Bolens
Others
Old 08-17-2010, 10:32 PM   post #7 of 32
89YT12
89YT12's Avatar
MTF Member # 35873
Images: 9
Garage
Quote:
Jason
yea, thats what i been told too when i was wondering why my YT has narrow tires when i was replacing them with new one ....... im used to running performance cars at a drag strip where you want wide as can be to grip, compairing a drag setup to a tractor setup with tires is like apples and oranges
BTW NICE NAME
__________________
Jason "J"
Old 08-17-2010, 10:41 PM   post #8 of 32
JakeBlues652
Senior MTF Member
MTF Member # 32094
Images: 2
am i right there?
__________________
1985 John Deere 212
-Hank Williams Jr.
Old 08-17-2010, 10:46 PM   post #9 of 32
89YT12
89YT12's Avatar
MTF Member # 35873
Images: 9
Garage
from your positive source, to your "flasher" switch, run wire to one terminal on the flasher, then one wire from the other flasher terminal to one light, branch off that wire with another one for the other light, i soder and use heatshrink
for the dim (running) mode, just leave the flasher out of the set up, i would just branch of my headlight wire, thats how i did mine
__________________
Jason "J"
Old 08-17-2010, 10:55 PM   post #10 of 32
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
you could do it with 1 switch if you use a dual pole dual throw switch.
__________________
Check out our new HOMEPAGE
davidg is offline   Reply With Quote Quick reply to this message
Old 08-17-2010, 10:58 PM   post #11 of 32
littletractorguy
The Mod from... Nowhere!
littletractorguy's Avatar
MTF Member # 36339
Images: 6
Garage
And don't forget, the VERY FIRST thing that should be hooked to the POS terminal of your battery (or to any accessory power outlet you plug these into) should be an in-line fuse holder/w a fuse of suitable amperage (I wouldn't think more than a 2 or 3 amp 12 volt fuse...) or fusible link... Safety first! Of course, if it were me, I'd be putting a switch after the fuse, before the relay, just so I could turn them off when I didn't need them....
littletractorguy is online now   Reply With Quote Quick reply to this message
Old 08-17-2010, 11:11 PM   post #12 of 32
89YT12
89YT12's Avatar
MTF Member # 35873
Images: 9
Garage
Quote:
Originally Posted by littletractorguy View Post
And don't forget should be an in-line fuse or fusible link... Safety first!
DANG how did i forget that, and im the one always doing peoples wire work, and always saying bring me a relay and a fuse holder if you want me to do it
__________________
Jason "J"
Old 08-17-2010, 11:13 PM   post #13 of 32
lynnr
Senior MTF Member
lynnr's Avatar
MTF Member # 31765
My experience - duals don't help, ags don't help. Chains?
Lights...in my part of Michigan, not too much..if you frit 'em with too much they freeze like rabbits...arms, legs and eyes...and the vehicle maintains speed and direction until they snap out of it
__________________
Just another hacker - bits and bytes by day, iron by night, trees on weekends.
lynnr is offline   Reply With Quote Quick reply to this message
Old 08-17-2010, 11:22 PM   post #14 of 32
Tencubed
3K Poster!!!!
MTF Member # 31735
Those LED lights draw a very small amount of amperage compared to the incandescent lights we have all used for years. The CC starter/generator should be giving you around 15 amps to do what you need.
The Stop/Turn/Tail lamps have two sets of elements (Diodes) in them. The tail lights are dimmer and are like the ones you see on many trucks. When the second set of elements are activated the light goes to full bright and works just like the tail and brake/turn lights on your car.
You could easily wire the tail lights to stay on as needed and activate the Turn/Brake elements as flashers just like the four way flashers to which you are accustomed.
You should have plenty of electricity from the S/G to operate half a dozen of these lights plus a couple of LED headlights with no problem.
Mike
__________________
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-18-2010, 12:22 AM   post #15 of 32
tranks
Professional amateur!
tranks's Avatar
MTF Member # 36078
Images: 19
Garage
those tail lights would be pretty cool. you could wire the tail lights on when the key is on and then have a switch and flasher relay on the brake/turn lights.
heres an electronic flasher.
http://www.amazon.com/Bussmann-BP-55.../dp/B000BXMDRY
i have two beehive type amber lights on the front and one red marker light on the back. i want to add another red marker light on the back and then make some kind of removable light pole, maybe with two work lights, one point forward and one backwards.
i think i should switch over to leds marker lights front/back before i add any works lights though. i'll probably use some 35 watt fog lights for work lights.
__________________
mike
building a steerable yard cart --- New video post #53
1971 John Deere 112--2000 New Holland LS55H
1985 John Deere 112L
tranks is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
