Having probs with 16hp Vanguard - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 08-16-2010, 05:03 PM   post #1 of 7
Vanguard100
MTF Junior Poster
MTF Member # 44799
Default Having probs with 16hp Vanguard
I have had ongoing problems with a B&S Vanguard engines.
It starts fine and runs OK until it is under the slightest load then it loses power every 20 seconds or so. At the point it loses power there is a brief puff of black smoke from the exhaust.
Valves clearances have been checked, carb stripped off and cleaned as thoroughly as I could. Air filter and oil changed. BTW the engine has done 200 hours
Spark seems OK.
I have noticed that there is some oil in the filter housing that is coming from the breather area (this was very clean oil).
I have not checked compression yet but am suspecting head gasket (hopefully not rings)
I also wondered if the flywheel key was slightly sheared putting the timing out. The engine is loose so it should be easy to check, do i need to remove the flywheel?
Also i dropped the float needle valve and bought a new one, why are there 2 in the packet (1 a steel colour the other brass colour) I used the brass one is that correct, they are slightly diferent lengths.
Any thoughts?
Vanguard100 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-16-2010, 05:10 PM   post #2 of 7
roughrider
Proud Member of the 1K Club
roughrider's Avatar
MTF Member # 45937
Default Re: Having probs with 16hp Vanguard
it could be the head gasket ...To check the fly wheel key on a brigs is undo the big nut and remove the hard ware you will see the key it should be lined up perfectly ....dose it pop threw the carb or back fire
roughrider is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 06:09 PM   post #3 of 7
Vanguard100
MTF Junior Poster
MTF Member # 44799
thanks
No it does not pop, it does appears to sometimes (maybe 1 in 3) backfire but only when it is switched off. Or at least there is sometimes a fairly loud bang.
By the way the breather tube that goes into the air filter housing does not appear to have any oil at all in it or on the surfaces.
Old 08-16-2010, 07:10 PM   post #4 of 7
WRENCHBENDER88
MTF Junior Poster
WRENCHBENDER88's Avatar
MTF Member # 49010
I'd suspect after a backfire event that on one more of the push rods might be bent or out of the lifter all together. Look closely at the rockers to for cracks, I've seen it a lot in singles and twins with aluminum pushrods. Also, I'd would check the fuel solenoid in the bottom of the carb if equipped, if dirty or acting up (wiring) it will allow for the backfire to occur.
WRENCHBENDER88 is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 07:11 PM   post #5 of 7
gda882002
MTF Member
MTF Member # 44641
if its a puff of black smoke thats fuel ,pull the carb take it apart and clean everything install a new fuel filter and maybe some dry gas in the tank
Greg
gda882002 is offline   Reply With Quote Quick reply to this message
Old 08-16-2010, 07:21 PM   post #6 of 7
WRENCHBENDER88
MTF Junior Poster
MTF Member # 49010
Whew Re: Having probs with 16hp Vanguard
You might also just be your own worst enemy
If it didn't have the brass needle originally different lengths do make a difference, the carb may be just flooding. I'm just sayin'.
Sponsored Links
Advertisement
Old 08-16-2010, 08:14 PM   post #7 of 7
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Black smoke means it's running rich. You need to check your float level. Perhaps you put the wrong needle in, and the fuel level is too high in the bowl.
Is there a main mixture adjustment? Perhaps you just need to lean it out a bit.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
