GT235 Tuff Torq K71 Transmission Fluid - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-10-2010, 12:46 PM   post #16 of 35
farmer69
Proud Member of the 1K Club
MTF Member # 27775
Default Re: GT235 Tuff Torq K71 Transmission Fluid
I,ve always used what JD recommends. For about the last 35 years and 4 mowers and no trani problems.
farmer69 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-10-2010, 12:55 PM   post #17 of 35
MTD snow plow
Murray tractor owner
MTD snow plow's Avatar
MTF Member # 40721
Images: 8
Garage
I've always used Pennzoil (High quality) or Bradpenn (Make it right here in PA 20 miles from me! With 100% pennsylvania crude) Never ever had sludge with them. the people you saw probably never changed the oil! You are putting engine oil in a Hydro trans-axle made to run on hydrolic oil.
__________________
Cub Cadet 72, mower deck, soon plow and sleeve hitch
MTD 995 hydrostatic-hydro lift, 54" snowplow, 3 point Hitch, 50" deck, Tire Chains, 10" plow, box-blade
1997 Murray 15.5 Hp 42"
Honda HRA214 self-propeled mower
2010 Stihl FS-45 trimmer
Ariens Snowblower H70
IH (Cub) cadet 282 Hydro
Lawn-Boy 6262 commercial, BBC, Mulch/side discharge
Lawn-Boy Selfpropeled bagging mower(Forget the model)
MTD snow plow is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 01:43 PM   post #18 of 35
goldenpond
MTF Member
goldenpond's Avatar
MTF Member # 31600
I think the distinction between hydraulic fluid and engine oil isn't very much.
1. I mentioned my friend's car that runs a common motor oil that is shared by both the engine and the transmission
2. Engines have hydraulics in them, such as the lifters, so the engine oil is also performing a hydraulic function
3. Many hydros, especially cheaper ones, use engine oil as their recommended oil.
4. Synthentic oils probably offered expanded ability, performing the duties of a engine oil and offering the hydraulic abilities of a hydraulic fluid.
5. If Tuff Torq suggests a 5W-50 lubricant in their hydros, and to my knowledge, there isn't a single tranny-only hydraulic fluid made, then they must be talking about using an oil made for engines, not for trannies. Another responder said a TT tech told him to use the Castrol 5W-50 which must be the engine oil.
Maybe it is time to write my own mail to TT and ask them if their recommendation also encompasses the Mobil 1 and possibly other products I am not aware of.
Thanks again!
goldenpond is offline   Reply With Quote Quick reply to this message
Old 08-10-2010, 01:57 PM   post #19 of 35
goldenpond
MTF Member
goldenpond's Avatar
MTF Member # 31600
I think the information on the TT web site says it all:
K71A, B, C, P J20C Hy-Gard High Viscosity J20C Hy-Gard High Viscosity 4.60
K71E, G, H, J, L 5w50 Synthetic Motor Oil - Part# 1115 10w30 API Class Motor Oil 4.60
1. they are specifying a MOTOR OIL in all instances, not a hydraulic fluid
2. The former K71 recommended fluid was plain old 10W-30 motor oil (can't tell in how I did it, but the second suggestion was the former suggestion, the first one is the currently suggested fluid)
3. The K71s sold to JD they suggest JD fluid (probably under duress).
4. All other K71s suggest 5W-50 synthetic MOTOR OIL.
Do you really think there is a difference between the various K71 trannies sold by JD and to everyone else? Not much difference than TV manufacturers adding a special knob or button on a TV so they can call it a different model number so people can't price compare between the major audio/video stores vs. wholesale stores.
Old 08-10-2010, 10:05 PM   post #20 of 35
cgreencorn1
Senior MTF Member
cgreencorn1's Avatar
MTF Member # 43821
Images: 5
Here is some more info on TT. K71 is not listed but K72 is, might help.
http://www.tufftorq.com/level4.asp?ID=5
http://www.tufftorq.com/level3.asp?ID=1
__________________
2010 X500 W 48" Deck Gator blades & HDAP's
JD 44" Blower
JD 10P Dump Cart
AgriFab 42" Sweeper, 40" Dethatcher, 15 Gallon Sprayer, Cultivator, Landscape Rake
Craftsman Sleeve Hitch with JB Electric Upgrade
Brinly Hardy 38" Box Blade
Halogen Headlights
30" Mechanical Tiller
Previous Machines
2007 LA140
42" Lightning Blower
1987 RX75
cgreencorn1 is offline   Reply With Quote Quick reply to this message
Old 08-11-2010, 12:38 AM   post #21 of 35
61woody
Senior MTF Member
61woody's Avatar
MTF Member # 48163
As long as you use anything that is JD rated you are OK with warranty. After that you can use whatever you want and if it is what the tranny manufacture recommends i'd go for it. As for Deere putting their label on some elses oil that what they do. It's blended right in town here by a company you probably never heard of.
In the dept I work in we use over 2900 gals of high guard every day.
61woody is offline   Reply With Quote Quick reply to this message
Old 08-11-2010, 10:33 AM   post #22 of 35
cgreencorn1
Senior MTF Member
MTF Member # 43821
Images: 5
Quote:
Originally Posted by stladrill View Post
Castrol make 5w50 synthetic
This is what I put in my transaxle.
stladrill did you notice any difference using the 5w50 synthetic. My previous machine LA140 had very loud trany noise in the winter until it warmed up. Stored in a unheated barn. I will be changing the trany oil in my new machine X500 and was hoping it would help reduce the trany noise.
__________________
JD 44" Blower
JD 10P Dump Cart
Halogen Headlights
Previous Machines
2007 LA140
1987 RX75
Old 08-11-2010, 10:57 AM   post #23 of 35
wfbarto
Senior MTF Member
wfbarto's Avatar
MTF Member # 24306
Okay....curiosity killed the cat, but I would like to know what is the Hygard "blended" from....in other words what are the components? What is the name of the company that does the blending? Also where do you work that uses 2900 gals per day of Hygard?
wfbarto is offline   Reply With Quote Quick reply to this message
Old 08-11-2010, 12:17 PM   post #24 of 35
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Quote:
Yes when I change the oil the first time on the K46, here is my quote from the thread I did about the oil change.
Quote:
And now the road test, first remark less noisy and better response on the pedal (forward and reverse)
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is offline   Reply With Quote Quick reply to this message
Old 08-11-2010, 03:40 PM   post #25 of 35
goldenpond
MTF Member
goldenpond's Avatar
MTF Member # 31600
Thanks for the info which says what I said I wrote TT and got a reply. Here it is:
"You are correct 5W-50 Synthetic would be our preferred choice. We have the 5W-50 full Synthetic Oil available for $7.99 a liter, but if you prefer to
buy it locally then Mobil 1 should be fine. Please let me know if you have
questions."
They wouldn't say whose product they are selling, but unless it is a custom blend, I can only find two products on the market so far, the Mobil 1 and the Syntec, neither of which have I found locally yet.
__________________
Golden Pond Farm - Tractors
Ford 861 - HD loader, 3' and 6' buckets
60" rough cut deck, 6' rear blade, post
hole digger, seed drill, wagon, etc.
JD 140
JD 300
JD GT235
Toro 266-H
Old 09-19-2010, 12:11 PM   post #26 of 35
goldenpond
MTF Member
goldenpond's Avatar
MTF Member # 31600
Wanted to report that I found that a company called Lube Tech is the local (possibly regional and national) distributor for Mobil 1. I was able to order a case through their local office and I just picked it up the other day. Although dealing right with the distributor, the 5W-50 was almost double the almost same oil at Wally World, just a different weight. I heard Wally World in Canada sells 5W-50 but don't remember them saying what they pay for it.
Will get back to you when I have done the tranny fluid change.
__________________
JD 140
JD 300
JD GT235
Toro 266-H
Old 04-27-2011, 09:23 PM   post #27 of 35
4rcFed
Senior MTF Member
4rcFed's Avatar
MTF Member # 57818
Since I just got my GT235, I wanted to change all fluids and filters. I do not have a service or owners manual, but I just called a local dealer and told them what I was after. For the transaxle, I received:
Low Viscosity, Hy-GARD Transmission oil (#TY22035).
I guess that is what the tractor calls for??? Can anyone confirm that? I'll be draining and refilling it this weekend. Don't want to damage that bad boy!!
__________________
2000 JD GT235 18Hp B&S, 48" deck
1979 JD 2240 145 Loader
Bolens 1250 In need of a restoration
4rcFed is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 10:17 PM   post #28 of 35
DeereRider
Senior MTF Member
DeereRider's Avatar
MTF Member # 55538
I just changed the oil in my K46 a few days ago and I used 5W50 Castrol Syntec. I bought it at an Auto Zone in PA on the NY border.
I did notice that after the oil change it was a little quieter, couldn't really tell a difference in performance or responsivness.
__________________
2012 X500, 48" Edge Deck, 44" Snow Blower, 48" Plow Blade, De-thatcher, 42" Lawn Sweeper, 4 John Deere Suitcase weights, wheel weights, chains and HDAP's
2007 X300 with 245 hours, 42" deck SOLD
30" Mechanical Tiller SOLD
DeereRider is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 10:19 PM   post #29 of 35
Rifboy
MTF Member
Rifboy's Avatar
MTF Member # 42478
Lots if interesting reading here and some valid points. I have spent my life repairing and maintaining automobiles, mostly european but a fair number of American and Japanese too. I have seen more than a few instances of well meaning mechanics cause a lot of damage by "engineering" a change in a specified fluid. Sometimes that fluid you are changing is great for the item you are focusing on but not so great for something else. What I'm trying to say is that in the case of my own X534 the power steering and deck lift use the same oil as the hydro. Is Synthetic 5W-50 the correct oil for these systems too? I don't know so I went with what the manufacturer wanted. I'd rather be safe than sorry and I can always change more often if I am worried about the oil breaking down.... If I had a tractor that didn't have these additional systems I'd go with the TT recommended synthetic oil, but the lack of first hand knowledge about the synthetic in these makes me feel safer with the JD recommended oil...
Just my 2 cents worth...
Rifboy
__________________
2010 John Deere X-534
48" deck
48" front blade (aka snow plow!)
38" box scraper w/electric lift
7 bushel power flow bagger
10P utility cart
2010 John Deere js46 mower
various Stihl trimmers, blower, saw etc.
Rifboy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-27-2011, 10:29 PM   post #30 of 35
Engine_Tech
MTF Member # 46741
Ever think that TT recommends 5w-50 syn as it's CHEAPER for them than JD Hy-Gard would be and is more readily available for most of their customers? Plus, it doesn't tick off any other OEM's that don't have their own specific hydraulic oil like JD does (think Husqvarna).
And by the way...Hy-Gard is an oil "designed specifically for hydros". Ever wonder what is run in a JD hydro bulldozer? Also, the IVT transmissions (infinately variable trans) in some of the Ag tractors have a hydro component to them. Again, they use Hy-Gard. Thus...Hy-Gard is specifically designed for hydro applications. Good enough for my $100,000 Ag tractor transmission, it's good enough for my L&G tractor.
Just sayin'
Engine_Tech is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
