GT-17 and Simplicity 7117 engine swap? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Register Home FAQ Garage MTF Gallery Search Today's Posts Mark Forums Read Store Chat Room [1]
Reply
Thread Tools Display Modes
Old 08-08-2010, 11:55 AM   post #1 of 2
Rodsterdewd
Ariens GT17
MTF Member # 19156
Default GT-17 and Simplicity 7117 engine swap?
Hi. about 2 years ago I blew a rod in my older GT-17 with the original Kohler Series I KT-17. The old SPEC# is 24195 i believe but not positive. I found a newer Series II KT-17 from a Simplicity 7117 with a SPEC# of 24343. So far, in my research, i have found this crank to be different but i don't know if this or any other difference will keep the 2 from mating up with no headaches. My other problem is that i am in one state, my machine is in another, and the motor i found is 700 miles between the 2 places. Before i commit, can someone find out or help me to find out if the 2 engines will swap? I have been searching parts books for 4 hours now and im just as confused as when i started. Thanks in advance. Rodsterdewd
__________________
My favorite color is "free"
Rodsterdewd is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-12-2010, 11:37 PM   post #2 of 2
jaynut
Senior MTF Member
jaynut's Avatar
MTF Member # 36846
Images: 16
Default Re: GT-17 and Simplicity 7117 engine swap?
be prepared to do some modifying - I just took a kohler k321 out of a john deere & put it in my ariens gt14 - had to swap oil pans, all outer covers, drill & tap holes for the front pto clutch, cut a notch for the oil dipstick, & it vibrates @ mid throttle now because the ariens engine has a gear driven counter ballance - the john deere does not - I am planning to rebuild my origional engine & would suggest you do the same - if all you did was break a rod it should be cheap to fix
jaynut is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
