Blades will not engage/rotate - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-22-2010, 10:39 PM   post #1 of 17
sM319
MTF Junior Poster
MTF Member # 48096
Default Blades will not engage/rotate
Hello everyone !
I was using my mower the other day and it completely shutdown.
It started back up but the deck/bladeds didn't engage.
It runs and drives fine, blades just are not engaging when I pull out the red engaging knob.
I am not really lawnmower mechanicaly inclined of knowing where to start to trouble shoot this problem.
Is it possible for someone to post a few things I should be looking for.
I am not sure but is a cable connected to this red engaging knob?
I would greatly appreciate any responses. Thanks !
Craftsman 25.0 HP Electric start 46" mower Automatic LAWN TRACTOR.Model # 917.272201 got it in yr. 2000
sM319 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-22-2010, 10:55 PM   post #2 of 17
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
Default Re: Blades will not engage/rotate
have you looked to see if the belt popped off or broke?
__________________
Check out our new HOMEPAGE
davidg is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 02:51 AM   post #3 of 17
sM319
MTF Junior Poster
MTF Member # 48096
Hello DavidG,
Yes belts are on. Just nothing is turning.
I have time to take a closer look at it here Saturday afternoon, just not sure what I should be looking for.
Old 07-24-2010, 12:21 PM   post #4 of 17
BMR528
Senior MTF Member
BMR528's Avatar
MTF Member # 36516
First thing to do in my opinion is to see if you can here the "clutch" engage. Do this by setting on the tractor, turn the key to run and pull the blade knob out.. you should here a click as the clutch engages, also when you push it in you should here it dis engage.. If you here no sounds ( and pronounce the clutch dead ) then you will have to put a voltage meter on the clutch circuit and see if voltage is present when you pull the knob..
d
BMR528 is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 12:45 PM   post #5 of 17
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Quote:
Do this without the engine running, it's easier to hear. You must be sitting in the seat so that the safety switch is made. You should hear a noticeable click as the PTO clutch engages. (This is assuming that you have an electric PTO.)
Are the fuses all good?
If you don't hear it, look underneath for broken wires going to the clutch.
What we don't know is why it stopped in the first place. The two events may be related.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 01:09 PM   post #6 of 17
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
If it has an electric clutch/PTO, check the fuse. Might be blown.
engine2quarters is offline   Reply With Quote Quick reply to this message
Old 07-24-2010, 11:52 PM   post #7 of 17
sM319
MTF Junior Poster
MTF Member # 48096
Thanks everyone I never got the chance to look at it today.
I will mon. tues or wed..
The battery is very weak I have been starting the mower with a charger, takes about 2 min and it then starts.
I have been starting it this way the last 10 times I have mowed. I was mowing and the mower just died out suddenly and when i got it started again the blades would not engage. I could pull the blade engaging knob and push it back in with no click or sound at all.
I'll check them things out again and get back with everyone sometime next wk..
I wouldn't think the battery would have anything to do with it once it's running tho.
Old 07-25-2010, 12:06 AM   post #8 of 17
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
If the battery is weak, it will pull down the voltage on the entire system. I think that may well be your problem. Before you do any troubleshooting, you need to start with a fully charged battery. Please fully charge the battery, then give it a another try. The charging systems on these machines will keep a battery in good shape charged, but do not have the fortitude to charge a dead battery, or to run accessories like the PTO if the battery is weak or defective. You might be in the market for a new battery at this point. How old is your battery?
Your charging system may have quit on you also, from the description you gave. It needs to be checked out - with a fully charged battery.
__________________
(Red Green)
Old 07-25-2010, 12:10 AM   post #9 of 17
DJ in WV
I Love All Color Tractors
DJ in WV's Avatar
MTF Member # 10462
Images: 6
Garage
I have to wonder if the tractor is charging well enough to engage the clutch. If the battery is bad, the charging system may be being worked so hard that there isn't enough current to engage the clutch.
__________________
MyTractorForum.com House Rules
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1981 Troy Bilt Horse, 7HP Kohler
1982 Gravely 8123
1983 Troy Bilt Junior
1988 JD 950, 75 Loader, 8A Backhoe
DJ in WV is offline   Reply With Quote Quick reply to this message
Old 08-05-2010, 10:39 PM   post #10 of 17
sM319
MTF Junior Poster
MTF Member # 48096
Ok sorry it took me so long to get bad but a family member had health problems.
I finally found a manual on my lawn tractor. It says if mower blades will not rotate check these possible things.
Obstruction in clutch mechanism
Worn/damaged mower drive belt
frozen idler pulley
frozen blade mandrel
An I included a pic of aboce said items to check
The engaging knob must have electrical wires running to the electric clutch pulley. Doesn't really say anything about a bad battery being the cause of it.
So I will check them things out soon.
Old 08-05-2010, 11:23 PM   post #11 of 17
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
the electric clutch takes 2-3 amps of current at 12-14 volts dc. IF the battery is low, it cannot supply this current.
a simple, and FREE, way to check is to crank the mower, then leave the battery charger on and try to engage the deck. if it engages, turn off the charger and see if the deck shuts off after a minute or two. if it does, then you know it is your battery or charge system, or both.
since nothing moves, you can rule out the last 3 items you list. and the 1st should be visible, just look close at teh clutch on the bottom of the engine.
__________________
Old 08-06-2010, 12:06 AM   post #12 of 17
jroy
Senior MTF Member
MTF Member # 43189
My fathers John Deere with electric PTO clutch will not engage if the battery is dead or weak. Replace the battery and it will fix the problem.
jroy is offline   Reply With Quote Quick reply to this message
Old 08-12-2010, 12:16 AM   post #13 of 17
sM319
MTF Junior Poster
MTF Member # 48096
OK thanks everyone. I will get a new battery and let everyone know if it helps to engage the blades.
My push mowers can't take this heat. lol
I can't take it anymore. Need my rider back !
Old 08-13-2010, 07:25 PM   post #14 of 17
Bill Kapaun
Circumflatulater
Bill Kapaun's Avatar
MTF Member # 6264
Looking at the electrical schematic, I see you have a rather oddball system compared to the typical Craftsman tractor.
L LOW battery could be the cause of your problems.
Now the odd part-
IF the seat switch isn't working OR the Operator Prescence Relay (OPR) is working, the blades won't engage either!
The OPR is a Bosch rely. It'll be a "cube" about 1.25" or so per side. It'll have pins marked 85, 86, 30, 87 & 87A.
Make sure the connections to the seat switch and OPR are good.
You can "jumper" the seat switch to make sure it is good.
The relay can be tested on the bench with an OHM meter and 12V source.
Pins 85 & 86 are the electro-magnetic "coil". Running 12V through them should result in continuity between pins 30 & 87. No current would result in continuity between pins 30 & 87A.
This relay completes the ground circuit to the electric clutch.
To do so, the seat switch must be depressed/closed (occupied) to send 12V to pin 85 of the relay to "activate" it.
Bill Kapaun is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-13-2010, 08:06 PM   post #15 of 17
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Woah up, There is a 25 - 30 Amp fuse that needs checked before replaceing the expensive battery. Blown fuse will not prevent the engine from running, but will prevent the battery to charge, and Electric clutch to operate.
My 2c
larrybl is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
