Gravely L repower - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-18-2010, 06:55 PM   post #1 of 24
landreo
MTF Junior Poster
MTF Member # 24185
Default Gravely L repower
I received a PM from a member months ago about a repower I had done to my Gravely L wanting more details and an update. So here it is:
Honda clone Gravely Conversion
Major Parts:
Gear 6325k5 Steel Plain Bore 14-1/2 Deg Spur Gear, 10 Pitch, 15 Teeth, 1.5" Pitch Diameter, 3/4" Bore from McMaster Carr
Hub W series weld on hub from Tractor supply or Burden Surplus center 1” shaft diameter
¾ Cold rolled steel shaft, few inches long
¼ inch plate for transmission, engine plates, and gussets
1/8 inch plate for handlebar support
Misc steel pieces
The transmission plate was cut using the transmission as a pattern. The center was marked based on the locations of the various bolt holes and a 2/1/2 inch hole drilled. The inside outline of the transmission was marked using the old transmission gasket. A ¼ inch rod was welded and bent along the inside of the markings from the transmission gasket. This ¼ inch rod simulates the lip that was on the original engine case. This lip fits tightly inside the transmission edge and keeps the clutch from coming too far towards the rear of the transmission. The transmission plate is a piece of ¼ inch plate with the necessary bolt holes, a large 2 ½ inch hole in the center and a ¼ inch high lip. A gasket has to be cut to fit.
The engine plate is just a square piece of ¼ inch plate big enough to fit on the engine face plate with the required 4 holes to mount the engine. The engine plate has the same 2 ½ inch hole cut in the center.
The engine hub is just a gear with a ¾ inch bore. The gear hub was turned to a outside diameter of 1 inch. The gear hub then has a 1 “ OD and a ¾ “ ID. The gear hub should be a tight fit into the 1” ID of the weld on hub. The ¾ inch shaft is placed inside the gear hub so it protrudes from the gear side the necessary amount. Measure the original engine but ¾ of an inch should be enough to function as a pilot shaft. Weld the shaft into place on the hub side of the gear not the gear (tooth) side of the gear. The gear now has a short shaft protruding from the one side and a 1”OD hub on the other. The weld on hub gets a taper turned on the outside to facilitate welding. Place the gear hub into the weld on hub and weld the two together. When all is done you should have a ¾ inch smooth pilot shaft with a gear and a 1” ID keyed hub to fit the engine shaft.
The engine shaft can be cut shorter if possible.
A piece of pipe will form the spacer between the engine and transmission plate. You will have to measure the length based on the length of the engine shaft and the finished gear hub assemble. Cut the pipe to the correct length so when placed together with the engine and transmission plate, the gear and pilot shaft will protrude the same amount as the original engine. Weld the pipe in place. Now you should have a weldment consisting of a transmission plate, engine plate, center pipe spacer such that the gear and engine shaft will fit through the center of the pipe and protrude the correct length. Weld in the gussets spaced so as to not interfere with placement of the engine plate bolt holes.
I wanted a strong handlebar support so drill the handlebar plate on the bottom so it will match the top 3 bolts on the transmission. Weld on 2 angle iron pieces on the left and right sides of the plate. Bolt the spacer weldment in place leaving out the top 3 bolts. Place those bolts through the handlebar plate, transmission plate, and into the transmission. Pull the handlebars to the height you want them, drill the bars and the handlebar mounting plate angle irons to anchor the handle bars. You should be able to pull the tractor around by the handlebars without any force being transmitted to the engine itself.
The whole assembly, engine and spacer, will likely be slightly longer so you will need a longer hitch plate. I used a piece of 1 inch pipe bent to fit and mount into the differential bolts like the original. I mounted the hitch ball and then made a steel cage to go over the top of the hitch ball. That cage attaches to a “U” shaped bracket that hangs from the handlebars at the rear of the engine. That bracket attached to the top of the hitch ball cage to provide support to the hitch ball through the handle bars. I wanted no weight supported by the engine.
The original setup had the transmission lubed by the engine oil pump. Prior to mounting the spacer weldment, I leveled the tractor and filled with oil until the oil level was about to run out the transmission opening. I pulled the dipstick and made a mark at that level with a marker. I estimated by looking at the transmission and the planet gears that another inch or so of oil height would be more than enough to let the gears splash lubricate. So I pulled the dipstick again and made a scratch mark one inch about the current oil level. That was my new “FULL” mark.
Gaskets for the engine mount side, locktite on the shaft and hub screw, and bolted everything together. I used an 11 hp electric start engine but have not used the electric start option, it starts easily. It has a lever for the throttle that is in perfect position to move with my toe so I have not converted to a handlebar throttle lever. It has plenty of power so I have be able to run the engine at a speed which give a similar ground speed as the original engine. Of course at 3600 rpm it would be much faster than the original but I have not needed to do that.
I have used it mostly for grass cutting and rotary plow work, 30-40 hours since conversion. Works great so far. I am very happy with the conversion. The original hood will fit but I decided to just leave it off for now. There are many ways to mount an engine to a L model Gravely but I liked the minimal machining method I have used for my conversion. Not counting the engine, the cost should be $50-$60.
ID:	113447   Click image for larger version
ID:	113448   Click image for larger version
ID:	113449   Click image for larger version
landreo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-18-2010, 06:59 PM   post #2 of 24
landreo
MTF Junior Poster
MTF Member # 24185
Default Re: Gravely L repower
More:
ID:	113451   Click image for larger version
ID:	113452   Click image for larger version
Old 07-18-2010, 09:02 PM   post #3 of 24
rscurtis
5000 Strong & Climbing
MTF Member # 25367
For a fraction of that work, you could build a beautiful L engine complete with governor and any required new OEM parts.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 07-18-2010, 11:05 PM   post #4 of 24
helixhippie
I have G.A.S.
helixhippie's Avatar
MTF Member # 23839
Images: 2
I believe I inquired & I am thrilled with your info & results.
Thanks for writing it up & posting.
I bet it's quieter, smoother & uses much less fuel.
__________________
I'm a "Heuristic Engineer".
helixhippie is offline   Reply With Quote Quick reply to this message
Old 07-18-2010, 11:11 PM   post #5 of 24
js5020d
2000 Posts and climbing!!!
MTF Member # 3908
Thanks for sharing your conversion, great job.
js5020d is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 12:47 AM   post #6 of 24
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
Hi Landreo
Very nice job thanks for spending the time and effort to help some one.
I can't believe how quick other people are to put down some thing you are trying to help some one else who ask for it.
It makes you feel like not saying any thing on here.
Like I said great job!!!.
Thanks Bruce g
gravelymay is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 01:28 AM   post #7 of 24
Fla Don
Gravely bug bit.
MTF Member # 33720
Quote:
__________________
Current L/C count = 38.
Fla Don is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 09:11 AM   post #8 of 24
eveled
eveled's Avatar
MTF Member # 28747
Images: 8
Thanks for posting, I think it turned out great. Good luck with it. Ed
__________________
Here's to our veterans past present and future
Machine of The Month link
eveled is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 10:29 AM   post #9 of 24
jrd
3K Poster!!!!
MTF Member # 13434
Nicely done! I'm not normally a big fan of repowers, because I like the old L engine so much, but you did good on this one. Nice and simple!
A couple of questions that I couldn't quite figure out from the above: When setting up the spacer plate, did you have to do anything special to ensure alignment? I'm thinking of how you get the crank on center, as well as getting everything square. Getting it way wrong would of course prevent you from putting it together, but I'd be afraid of getting it close, but maybe misaligned by a couple degrees, which would probably work for a while before it chewed up the gears. Did you make some kind of jig, or maybe mill the piece after welding? Also, did you need to do anything special where the plate mates to the engine, to keep oil from leaking? If the case is flat, presumably just a gasket.
Again, nice job, and thanks for posting.
jrd is online now   Reply With Quote Quick reply to this message
Old 07-19-2010, 10:31 AM   post #10 of 24
Marcintosh
Senior MTF Member
Marcintosh's Avatar
Location: CT, on the sun drenched shores of Long Island Sound
MTF Member # 39360
Images: 5
This is brilliant! Thanks for sharing your work.
Marcintosh is offline   Reply With Quote Quick reply to this message
Old 12-13-2010, 04:54 PM   post #11 of 24
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
Quote:
Originally Posted by landreo View Post
More:
I liked all the work you put into your project
Here are some pictures of a gear machined from one piece.
also a spacer made from aluminum.
and using a Kohler adapter plate
ID:	134297   Click image for larger version
ID:	134298   Click image for larger version
Old 12-14-2010, 03:36 PM   post #12 of 24
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
This gear is for L model. C8 & C10
Here are some better pictures
Thanks Bruce g
ID:	134464   Click image for larger version
ID:	134465   Click image for larger version
Old 12-14-2010, 11:37 PM   post #13 of 24
GravelyNM
Senior MTF Member
MTF Member # 40179
Landreo and Gravelymay,
Wow! Superior work! Gravelymay, I saw the rest of your pics in the album section. It looks like you really have solved many of the problems. I would really like to repower an L with swiftmatic. They are hard to find in New Mexico.
Landreo, could you post more pics, please? It looks to me like you solved several problems as well. I like the idea of no stress on the engine.
I have a 1966 (J1018) Comm 10 that I "refurbished" this past spring. I like how the handle bars are mounted to the chassis. I have pics in the Gravelyclub album I think under my name.
Repowering seems to make a lot of sense to me since L engine parts are getting rarer and small engine reliability is good.
I am still looking in the occasional shed and barn for that poor neglected Gravely that no one wants (but me!). I know there has to be some around here somewhere.
You guys have really helped me to see that this can be done at a minimal cost. I look forward to that "new" project. Keep up the good work!
GravelyNM is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 12:49 AM   post #14 of 24
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
I know it cost some
But look what you can get one to do with a new engine.
I am going to start on a l model right after the first of the year.
I have 10 gears on hand right now
3 Have been spoken for they fit the L model C8, and the C10.
They are a bit higher then i wanted to pay ,
but when you have someone make something
it is always higher then you can do your self
Name:	2011 Cat  page 2 e.jpg
ID:	135502   Click image for larger version
Name:	2011 Cat  page 3 e.jpg
ID:	135503   Click image for larger version
Name:	2011 Cat  page 4 e.jpg
Sponsored Links
Advertisement
Old 06-07-2011, 10:01 PM   post #15 of 24
gravelymay
Senior MTF Member
gravelymay's Avatar
MTF Member # 20627
Quote:
Originally Posted by gravelymay View Post
I know it cost some
On the L & C models I don't have to use two at the cost of $200.00
Those 008 plates are 1.125 thick i though would have to use two in order to get my thickness.
Duh, I for got to count the thickness of the Kohler plate which is .500 thick.
any way.
The L and C models can be done with
1 Kohler adapter plate re drilled to fit the L& C transmissions
be re drilled $5.00
1 adapter plate 1.750 thick GR 046 $100.00
1 Sun Gear GR045 $150.00
1 Sun Gear Cap Bushing GR054 $20.00
oil seal $8.00
Shipping about $15.00
No muffler work would need be done
ID:	161177   Click image for larger version
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
