Hydrostatic / Automatic info needed (buying new) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-16-2010, 08:55 AM   post #1 of 5
humble314
MTF Junior Poster
MTF Member # 47802
Default Hydrostatic / Automatic info needed (buying new)
I currently own the following;
- Craftsman 15.5 HP IC
- 42" cut
- Hydrostatic (automatic) Hydro Gear (310-0500)
- 1998 M/Y
- 917.258081
The manual for my current riding mower states, "hydrostatic (automatic)" as written. Are the terms hydrostatic & automatic synonymous? Here is why I ask .....
I am looking at buying a 2009 M/Y Craftsman LT2000, 19.5 HP, 42" cut with the "automatic" drive. The Sears item number is 28908 (see photo attached).
I called and spoke with a Sears lawn and garden salesperson. He rambled on that the automatic has a series of pulleys that automatically adjust to provide the speed change. I know a belt and pulley drive the rear unit, the explanation did not mechanically make sense. What are the differences?
So I am wondering, does anyone have knowledge of the drive unit that is in this mower I am looking at buying? Such as manufacture, type of drive unit.
Also how could I identify the type of drive unit it has. Where to look and what a series of numbers or description would I look for.
Thanks all
Humble314
its all about the pi
humble314 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-16-2010, 11:19 AM   post #2 of 5
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Default Re: Hydrostatic / Automatic info needed (buying new)
A hydrostatic transmission uses a variable displacement hydraulic pump and a hydraulic motor to vary your speeds. Speeds can be adjusted by a hand lever, or foot pedals that vary speeds, much like a car accelerator, hence the term "automatic". The engine speed stays constant, but the ground speed changes as you push either the forward or reverse pedals harder. Most of these use a belt to transfer power from the engine to the transmission and act as a clutch to disconnect the transmission from the engine.
A variable pulley drive used mechanical means to vary the pulley diameters to vary your speeds. I don't know much else about these. I don't think there are any hydraulics involved.
You need to match the abilities of the transmission to your intended use. A "weaker" one is fine for a level, small lot, where you just mow and do light duty work. If you intend to climb hills, pull a dirt plow, etc, you need a sturdier transmission, or risk ruining a smaller unit by overworking it.
Some prefer a straight geared transmission for reliability and strength, others prefer the convenience of a hydro.
"You pays your money, and takes your choice."
I can't help you with the specifics of that machine, but I'm sure others will be able to chime in.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 12:52 AM   post #3 of 5
humble314
MTF Junior Poster
MTF Member # 47802
Fcubman,
As you stated, the auto uses a varying set of pulies and a belt between them with then the primary drive belt to he crank. the hydrostatic is a true hydro. I called Hydro Gear and spoke with a tech who provided good detail as to the differences between each.
I do not want the auto. Thanks for the input.
Humble314
ID:	113220   Click image for larger version
Name:	28910 Hydro.jpg
Old 07-17-2010, 01:04 AM   post #4 of 5
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
You're welcome.
I have a hydro, and love it. I don't know how I got along all those years with a geared transmission....
__________________
(Red Green)
Sponsored Links
Advertisement
Old 07-17-2010, 01:09 AM   post #5 of 5
MTD snow plow
Murray tractor owner
MTD snow plow's Avatar
MTF Member # 40721
Images: 8
Garage
Hydrostatic has 2 pedals (1 forward 1 reverse) an automatic has a shifter from forward to neutral to reverse and 1 pedal.
__________________
Cub Cadet 72, mower deck, soon plow and sleeve hitch
MTD 995 hydrostatic-hydro lift, 54" snowplow, 3 point Hitch, 50" deck, Tire Chains, 10" plow, box-blade
1997 Murray 15.5 Hp 42"
Honda HRA214 self-propeled mower
2010 Stihl FS-45 trimmer
Ariens Snowblower H70
IH (Cub) cadet 282 Hydro
Lawn-Boy 6262 commercial, BBC, Mulch/side discharge
Lawn-Boy Selfpropeled bagging mower(Forget the model)
MTD snow plow is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
