One Blade Cutting Lower Than Other - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-12-2010, 06:01 PM   post #1 of 15
jaroslaw
MTF Junior Poster
MTF Member # 47659
Default One Blade Cutting Lower Than Other
I have a 2003 Craftsman LT1000 with 42" deck. I have leveled the deck a couple of times but it is not cutting evenly. The thing that gets me is that both blades are cutting level but one is cutting lower. A whole 21" strip is cut lower. I have put new blades on but problem persists. Is it possible that a spindle is messed up or the deck is bent?
jaroslaw is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-12-2010, 06:08 PM   post #2 of 15
john9001
Senior MTF Member
john9001's Avatar
MTF Member # 45837
Images: 1
Default Re: One Blade Cutting Lower Than Other
check your tire pressures. Then check for bad bearings in the spindles.
john9001 is offline   Reply With Quote Quick reply to this message
Old 07-12-2010, 07:41 PM   post #3 of 15
sixtyfive_ford
Senior MTF Member
sixtyfive_ford's Avatar
MTF Member # 18977
I just had to fiddle with an un-even cutting 42" deck. I lifted the entire tractor up on its hind end to get accurate measurements. The spindle on the left(discharge side) was cutting about an inch lower in the middle. From what I measured the spindle mounting spot on the deck had bent in from the tension of the belt on the top. The deck mounting spot was only bent in 1/8-1/4" of an inch but at the end of the blade it was an inch. I massaged the deck with a ball peen hammer until both blades were perfectly level.
__________________
Too many tractors to count.......
sixtyfive_ford is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 08:59 AM   post #4 of 15
zelda
Proud Member of the 1K Club
zelda's Avatar
MTF Member # 33532
Images: 14
I use washers to level my blades. 1" though would be extreme and would be time for the BFH.
__________________
149 Cub Cadet
990 Farm King
C-141 Wheel Horse (Sold)
Host of the "MTF Michigan Meet 2011"
zelda is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 10:08 AM   post #5 of 15
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Take the deck off and flip it over. Turn the two blades so the tips are close to each other and compare their height. Then one at a time, turn each blade a half turn and compare. If the height varies when you turn the blades, either the blade or blades are bent or the spindle or spindles are.
I doubt though that anything is bent an inch out of whack. What I'm guessing is that you are not levelling the deck right, that you are measuring to the lip of the deck and not to the tip of the blade. The lip of the deck is not on an even plane with the blades. The manual is poorly written in that regard.
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 10:26 AM   post #6 of 15
orange j d
My Orange Jane Deere
orange j d's Avatar
MTF Member # 37225
Images: 1
How heavy are you and what side of the tractor are you sitting on.
__________________
Sent from my FREE MTF APP PROVIDED BY MY FRIENDS AT MTF*****
Remember: Marriage is the number one cause of divorce.
orange j d is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 10:34 AM   post #7 of 15
LLigetfa
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Quote:
You may have a point I didn't consider. Maybe he mows a steep side slope too and the deck levelling off.
__________________
Old 07-13-2010, 10:49 AM   post #8 of 15
LLigetfa
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Also have to wonder how the gauge wheels are setup or if the deck even has gauge wheels. Supposedly the gauge wheels should be within 1/2 inch of the ground but some don't have that much range of adjustment. On my deck, I drilled two more holes to lower the gauge wheels for a higher cut. I also reamed out the centres and added copper bushings and grease zerks.
__________________
Old 07-17-2010, 07:25 PM   post #9 of 15
jaroslaw
MTF Junior Poster
MTF Member # 47659
Thanks for all the replies. Haven't had a chance to take the deck off again to have another look. Tire pressure is good. Blades are straight for sure. The mower does this no matter who drives it and is very consistent.
How do you level be measuring to the tip of the blade when the deck is in the way? I have been leveling according to the manual.
Old 07-17-2010, 08:06 PM   post #10 of 15
jaroslaw
MTF Junior Poster
MTF Member # 47659
OK, blade tips match with every combination. Left spindle has a very small amount of play but not enough to make a difference with the blade tips meeting.
Maybe I am leveling wrong but its funny how it seems like a whole blade width is lower.
Old 07-17-2010, 08:22 PM   post #11 of 15
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
is you deck level? check the lift linkage
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is offline   Reply With Quote Quick reply to this message
Old 07-17-2010, 08:40 PM   post #12 of 15
mla2ofus
Old Stonebreaker
MTF Member # 138
I had troubles w/ my Poulan getting the deck level. Checked the blades where they meet and was AOK. Parked it on level concrete w/ deck all the way up and used my inside calipers to check distance from tips to concrete w/ tips at the outside edges of deck. Kept adjusting levelers until I got all the same both outer and inner tips. Hopefully I've finally got it so it cuts level.
Mike
mla2ofus is online now   Reply With Quote Quick reply to this message
Old 07-17-2010, 10:37 PM   post #13 of 15
jaroslaw
MTF Junior Poster
MTF Member # 47659
Well I just finished re-leveling using blade tips and on concrete. Side-to-Side was 3/4 inch out. Front to back was 1 inch difference, I adjusted to be 1/4 inch difference. Gauge wheels were too low, I adjusted them to be 1/2 inch above concrete while in desired cutting level.
I will see how it works for my next cutting in a few days and will post results.
Thanks for all your help.
Old 07-24-2010, 11:11 PM   post #14 of 15
jaroslaw
MTF Junior Poster
MTF Member # 47659
Cuts beautifully, thanks to all for the tips.
Sponsored Links
Advertisement
Old 07-24-2010, 11:45 PM   post #15 of 15
LLigetfa
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Good to hear. Thanks for the update.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
