Ford 860 Steering Box - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-11-2010, 11:51 PM   post #1 of 14
Big B
MTF Junior Poster
MTF Member # 47597
Default Ford 860 Steering Box
My steering broke. When turning left the shaft just screws up and out and won't turn. I got the steering box off and taken apart. Found the remnants of 2 bearings in the bottom. Do I just need to replace the bearings and get it back together? Does anyone have a diagram of all the parts?
Thanks in advance for your help?
Brian
Big B is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-12-2010, 05:29 AM   post #2 of 14
Kirk-NJ
2000 Posts and climbing!!!
Kirk-NJ's Avatar
MTF Member # 9444
Images: 16
Default Re: Ford 860 Steering Box
If no one else post a diagram I can send you one via fax. Just PM me to let me know.
Kirk
Kirk-NJ is offline   Reply With Quote Quick reply to this message
Old 07-12-2010, 10:59 AM   post #3 of 14
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Not to detailed resolution, but it may help. You can click on the image for a larger view.
Good luck with the repair.
Name:	steering box capture.JPG
__________________
Bob
Old 'n Cheap
Bad part of being older...you can remember when things that now cost $10 were only 50 cents
46 2n - waitin on me to do something to it.
47 2n - my relaxin tractor.
64 4000 - w/7 ft finish mower, scoop and bushhog.
ryork is offline   Reply With Quote Quick reply to this message
Old 07-12-2010, 11:25 AM   post #4 of 14
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
I would replace all the bearings, bushings and seals then fill it with cornhead grease and it shold be good for another 50+ years.
__________________
JohnW is online now   Reply With Quote Quick reply to this message
Old 07-12-2010, 12:01 PM   post #5 of 14
Big B
MTF Junior Poster
MTF Member # 47597
Thanks guys. Exactly what I need. Do you know if the top bearing is all that keeps the shaft from pulling up?
Thanks
Brian
Old 07-12-2010, 05:04 PM   post #6 of 14
H-D
Senior MTF Member
MTF Member # 34425
Go easy on the lash adjusting screw in the side cover. Too loose gives a little 'play' in the wheel, too tight puts wear on the expen$ive worm & sector gears. Also, cornhead grease is called '00' by ALI (?) & is available from a Snapper dealer or online. Just an alternative.
H-D is offline   Reply With Quote Quick reply to this message
Old 07-12-2010, 11:30 PM   post #7 of 14
Big B
MTF Junior Poster
MTF Member # 47597
Quote:
Thanks for the info. The New Holland dealer looked at me cross eyed when I asked about cornhead grease.
Old 07-12-2010, 11:33 PM   post #8 of 14
Big B
MTF Junior Poster
MTF Member # 47597
Does anyone know how much grease to put in the steering box? I see the plug to fill it and it looks like it needs to be pretty full to keep the top bearing lubed. Do I just fill it all the way up?
Thanks
B
Old 07-13-2010, 07:11 AM   post #9 of 14
Kirk-NJ
Kirk-NJ's Avatar
MTF Member # 9444
Images: 16
I think your john deere dealer would have the cornhead grease. May be able to get it cheaper elsewhere.
Kirk
Old 07-13-2010, 11:17 AM   post #10 of 14
Steve (Magnolia, TX)
Retired - Veteran Mod
Steve (Magnolia, TX)'s Avatar
MTF Member # 251
Images: 13
Garage
Quote:
Thanks
B
Yeah...
Fill'er up. If it oozes out past the upper bearing (just below the steering wheel) that's probably not a "bad thing" either...
Steve (Magnolia, TX) is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 12:38 PM   post #11 of 14
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Believe it or not John Deere has about the best price on the cornhead or 00 grease around. At least it is the easiest place to get the right thing. As Steve said fill it till it comes out the top bearing, a little less than 2 tubes worth.
__________________
Old 07-14-2010, 04:18 PM   post #12 of 14
Big B
MTF Junior Poster
MTF Member # 47597
OK I have my parts. Any tips on getting this back together? Looks like it might be a little tricky getting everything lined up.
Old 07-14-2010, 04:51 PM   post #13 of 14
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Take your time, have your manual handy and be prepared to learn a few new choice words...
really it is not that bad if you take your time and pay attention, you will probably get it out of time by a tooth the first time you put it together, most do, but hey it happens to the best.
__________________
Sponsored Links
Advertisement
Old 07-23-2010, 01:47 PM   post #14 of 14
Big B
MTF Junior Poster
MTF Member # 47597
Thanks for everyone's help. I got it back together and working. I see what you mean about one tooth off. I actually put the steering box back on the tractor before getting it completely together. With the steering arms in place it made lining everything up pretty simple.
Thanks again.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
