| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
| Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board |
Thread Tools | Display Modes |
#1 |
MTF Junior Poster
MTF Member # 46679
Friends and family said this would'nt work...LOL
Well, I got tired of messing with the carb every season on my craftsman. So I walked over to my Oldsmobile Van and poped a fuel injector out of the fuel rail along with the wires. Drill and tap the intake of the lawn mower and installed the GM Injector. Now the carb works as a thottle body. I then wrote code for an Arduino micro controler to run the injector and monitor sensors(like an ECU on a car). Here is a picture of the workbench prior to the install. ![]() I used a ULN2003 IC Chip to drive the injector, and a pot to change the pulse width. The mower started on the first try and after 3 code adjustments it would idle smoothly using 5ms injector pulses with 20ms between each pulse. I tied a pot to the govner to monitor throttle position. When the governor moves addind air, the Adruino micro controller responds by increasing the pulse width keeping the fuel mixture correct. ![]() To start the mower I set the pulse width to 5ms with the pot on my control panel. Thats the amount needed for idle condition. When I want to mow or engage the mower deck I turn the pulse width up to 11 or 12ms and raise the throtle lever to full throtle this opens my throtle body(old carb) about 10%. From here the governor and the code below handle everything else. If the engine goes under load the governor kicks in and opens the throtle body turning the pot connected to the governor, so if the governor pot reads 980 I subtract that from 1000 and add it to the value of my fuel trim pot, now we have 1000-980+11 = 31ms injector pulse. Then the engine RPM's recover and the govner pulls back to 1000. I really need to do a youtube video of this cutting the lawn. Best of all ----> Next year my mower will start up and run I will be putting togather a schematic soon.. The pump is a Mr. Gasket 7 psi. Before installing the injector I played with the pulse width by watching the spray patern on a piece of paper. My findings were that lots of small squirts are much better then longer ones, 2ms pulses are hardly visable and 100ms pulses are like pulling the trigger on a windex bottle. ![]() Well, This project is working 100%. The control panel is mounted, wires are all cleaned up and encased. Today I mowed the lawn/weeds with my fuel injected mower. It has never ran better or had the power that it has now. The seat out of my old van welded on makes for a smooth ride. I also added (3) switches on the control panel, Arduino Power ON/OFF, Fuel Pump ON/OFF and Injector ON/Off ![]() ![]()
| Sponsored Links | |||
Advertisement | |||
#2 |
3K Poster!!!!
MTF Member # 31735
If you could make a kit that would allow a computer dunce like me to put that system on a single or two cylinder engine I'd suspect you'd sell them like hot dogs at a ball game.
One of the better ideas and builds I've seen in awhile. Mike
__________________
A gun and a parachute are much the same. When you need one nothing else will really suffice. |
#3 |
3K Poster!!!!
Yes!!!!! Great project
I would be on the list for a 18HP twin in a heart beat. Carb needs major work.
__________________
1990 18.5 Craftsman (RED) 1988 18.HP 44 Craftsmans II (HULK II) 1983 Ford LGT 145 (Blue Money Pit) http://www.mytractorforum.com/showth...hlight=hulk+ii http://www.mytractorforum.com/showth...hlight=hulk+ii http://www.mytractorforum.com/showth...hlight=hulk+ii ![]() ![]() http://www.youtube.com/watch?v=j3uLRKYnr0M |
#4 |
MTF Member
MTF Member # 43090
I have done Megasquirt on a few cars and have an MSII with a wideband O2 sitting around. I was sure thinking about running my Onan twin on it. You just made it worse for me! That is really cool! Does that controller have maps on it? I wondered if you could use a switch on the engagement lever for the deck to trigger an enrichment? Just thinking...
__________________
1988 Deutz-Allis 1918 Ultima w/ 27hp. Kohler Repower 1981 Sears FF/18 Kubota 3 cyl Diesel Repower!! 1980 Sears FF/18 Briggs Repower 1982 Sears FF/20 Project 1980 Sears FF/20 Parts Tractor |
#5 |
5000 Strong & Climbing
![]() ![]() Join Date: Jun 2009
MTF Member # 28463
Excellent!!!
Now if your looking for opportunities to fine tune it on a twin, I have an Onan 20 hp. I think that you've stumbled on a ready market for this idea, and lots of possibilities for R&D on different engines to prove it out prior to marketing. I don't think that you'll have any shortage of volunteers. Please keep us informed!! ![]() Bob
#6 |
Proud Member of the 1K Club
What an awesome idea!!! I think I'm going to have to fool around with this over the summer, I have an old 5HP RER that needs some serious carb work. Maybe this would be a better(and certainly cooler) soulution.
Jason
__________________
Bolens Tube Frame: 600, 800 (2), 900 (2) 1000, 1050 (4), 1225, 1254 (2), 1256, G14, H14 Large Frame: 1250 (5), 2086 Others Bolens RAM, Bolens FS-11, Copar Panzer, Sears SS12, Sears Custom 6, Gravely LI, L8, L, Comm.10a, Farmall Cub |
#7 |
All Fired Up
MTF Member # 26869
I'm sure it is already patented.
#8 |
MTF New Poster
MTF Member # 11920
Micro Squirt works like a dream on small engines.You can control injection and ignition.A B&S 16hp opposed twin can make 20hp running E85,custom open headers,Accel coils for a Harley,8:1 compression,and a smoothed port heads.This was dyno'd before and after.I saw the dyno print out.I am not sure what throttle body or coil trigger was used.The engine was going on a racing mower.It was the 16hp B&S opposed twin used on most MTD products through the 90's.The govenor was retained to meet class rules.
__________________
TRAMPOLINE FRAME BUILDING-LINK MANIC CYCLES-MY BLOG MANIC CYCLES-MY FACEBOOK PAGE |
#9 |
MTF Junior Poster
MTF Member # 46679
Thanks for all the great comments,
I will gladly post/share the controller code and schematic. This could be adapted to any motor including twin cylinder. The driver chip has plenty of outputs for another injector. The arduino micro is cheap and easy to work with, this was my first project with it.. I would like to (someday) use the arduino with a gps and sonar(tree avoidance) modules, and program the mower to take care of the lawn without me on it.. this would also require an extra battery to run the steering servos. sounds a bit crazy.. but thats me ![]() --Joe |
#10 | |
3K Poster!!!!
Quote:
__________________
http://www.youtube.com/watch?v=mHVFE02NTgU http://www.youtube.com/watch?v=nv9Tx29-ZTQ http://www.youtube.com/watch?v=6zdO4JuKEiw http://www.youtube.com/watch?v=yJMEDJVDro0 http://www.youtube.com/watch?v=cI-O3mIzq_U Pictured:79 Mustang Pace car 5.0 4sp sold in 90. 79 Case 448 8th one made. Toro: 520xi 60"& Berco 40" blower, 266-H 48", 266-H 52", 117 GM 52", 52" wb made into pull type. Thinking outside of the box. Ingersoll 60" RH deck for sale. |
#11 |
Senior MTF Member
MTF Member # 16580
i understand the part about faulty carbs and the fact you like to tinker but you just come up a idea that would only make the repair shops more money because the average joe would have to take it in for repairs or end up having to buy a hand held scan tool at a 100 bucks to read it for problems.
our cars and trucks today are a mechanics nightmare due to this crap from the Federal Govt and EPA, think before you leap. |
#12 | |
3K Poster!!!!
Quote:
__________________
#13 |
MTF Member
MTF Member # 46215
I have been riding motorcycles since ... well, let us just say a little more than half a century. I have always done all of my own mechanical work. At the moment my wife and I own two bikes, mine is a full sized Harley and her's is a late model Harley Sportster. Her bike is carbureted and mine is the first fuel injected bike I've ever owned. I will never buy another bike with a carburetor - just plain never. Computer controllers are available for them all over the place and I'm sure the same manufacturer's will jump in the market when injection becomes commonplace on smaller engines. The controllers, which allow you to make minute adjustments to both your fuel and ignition all the way through the RPM band, are very easy to use. As for injection itself, its way simpler for the home mechanic than carburetors and when it comes to performance - and emission control - injection is far superior to carburetion
By the way, I personally thank the EPA and other Government Agencies for cleaning up the air I breath. |
#14 |
Senior MTF Member
MTF Member # 16580
oh yes computerized fuel injection is just so great, tell that to someone i know who shelled out big bucks for a new ECM for a Honda Quad or say in 15 -20 years down the road you need a ECM or fuel injector for your bike or quad and can't find one because its no longer carried or made.
this is already happening to mid-80s to early 90s cars and trucks, i would never buy a bike or quad or mower with this BS installed on it. ThomWV a peice of advice . never, never trust anything the Feds do, it will cost you in the long run. |
| Sponsored Links | |
Advertisement |
#15 |
MTF New Poster
MTF Member # 11920
My plan is to microsquirt all four of my motorcycles.Hoping to squeeze all the power out that I can.
__________________
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 3 (0 members and 3 guests) | |
| Thread Tools | |
| Display Modes | |
