How many hours on an oil change? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-09-2010, 10:17 AM   post #1 of 17
c5rulz
Proud Member of the 1K Club
c5rulz's Avatar
MTF Member # 8460
Default How many hours on an oil change?
The other thread on the 50 hour service interval got me thinking. The manual says engine oil "every 200 hours or yearly".
I am surprised how few hours I put on the 2305 since I use it year round for snow removal. I did the 50 hour service last spring and now have about 140 hours on it. I am probably going to change the engine oil and @ 150 hours. I can't see doing it at 90 hours as that is way sooner than the other parameter John Deere reccomends.
BTW, I am considering switching to synthetic oil since it isn't much more expensive than JD oil.
Thoughts gentlemen?
__________________
John Deere 2305, 62" deck, &47" snowblower.
SS1023B PTO driven spreader
John Deer GT235 48" with powerflow bagger
Husqvarna 562XPG w/ 20" Tech Lite bar
Husqvarna 550XPG
Husqvarna 346 XP Ported
Husqvarna 372XPG
Husqvarna 357XP
Husqvarna 288XP Lite ported
Dolmar 7900
Echo CS300T
Stihl 028 super, rebuilt and ported
Echo PPT-266 pole saw
Speeco 28 ton splitter
Silvey 510
Oregon 511AX
Tecomec for rakers
Stihl straight shaft trimmer W/ cutting blades
c5rulz is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-09-2010, 10:21 AM   post #2 of 17
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Default Re: How many hours on an oil change?
Once per year regardless of hours would be my absolute minimum. You need to get out the moisture which inevitably enters the crank case.
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 10:31 AM   post #3 of 17
BigD
Central Kentucky
BigD's Avatar
MTF Member # 5055
Images: 9
I've been changing the oil at 100 hours and the filter at 200 hours. Still using the Dino type oils since I was told its the diesel soot contamination in the oil that needs to be removed by periodic oil changes.
__________________
Pete,
JD 2320, FEL,62D MMM, 4 ' Box Blade, 6' rear blade, 4' tiller and 17' Gator Trailer
BigD is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 10:33 AM   post #4 of 17
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
I've changed the oil/filter in all my Deere's at 50 hrs and continue to do so on my 2210. I know it's way below the recommendation, but I feel more comfortable . . . and the cost, negligible.
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 12:31 PM   post #5 of 17
c5rulz
c5rulz's Avatar
MTF Member # 8460
Quote:
I understand the condensation thing, but mine sits in a heated garage and normally runs at least an hour every time it is used.
__________________
Husqvarna 550XPG
Husqvarna 372XPG
Husqvarna 357XP
Dolmar 7900
Echo CS300T
Silvey 510
Oregon 511AX
Tecomec for rakers
Old 06-09-2010, 12:36 PM   post #6 of 17
Master Control
Gone to be with the Lord
Master Control's Avatar
MTF Member # 11501
Images: 1
Quote:
Preach it brother JDFan! You can't service them enough ... or often enough!!
Have a great day,
Joe
__________________
I'm as old as my tongue and a little older than my teeth, and that's the truth.
International Harvester 424D Utility (1964)
John Deere 2305 MFWD
200CX w/49" bucket
John Deere 4005 MFWD
300CX w/61" bucket
John Deere Z510A w/48" 7-Iron deck
John Deere Z920A w/48" 7-Iron MOD deck
John Deere JS46 Walk Behind 22" mower
John Deere 54C Mower (2305)
John Deere 647 Tiller
John Deere 673 Tiller
John Deere Ballast Box
John Deere PHD300 Post Hole Digger w/stand
John Deere PHA109 Post Hole Auger 9"
John Deere MX6 Rotary Cutter
Agrex XA500 Spreader
Artillian Pallet Forks
Bush Hog SBX72 Box Blade
ECHO Bear Cat 5540 Chipper/Shredder w/optional blower, chute and cap
Fred Cain S-2 Subsoiler
Frontier LP1184 Land Plane
Home-made "Peanut Weeder"
Husqvarna 7021F Walk Behind 21" mower
International Harvester 309A Moldboard Plow 3-16
Leinbach 81-16 Moldboard Plow 1-16
Leinbach GB48 Garden Bedder
Leinbach RR-8 Landscape Rake
Stihl FS 110 R Trimmer
Stihl BR 600 Magnum Backpack Blower
Over 90
[Ken N Tx gave me this moniker on 28 Aug 2010.]
Master Control is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 02:07 PM   post #7 of 17
jsb2b
Senior MTF Member
jsb2b's Avatar
MTF Member # 6894
I do my oil and filter every spring for the mowing season and only oil in the fall for the plowing season. I have 170 hours since purchased in Sept 2005. Did the 50 hour service in July of 2006. Low useage. Probably overkill on the maintenance but it's a cheap investment every year.
__________________
JD 2305, JD 62C MMM, JD 54" QH Blade, JD JS-63C
jsb2b is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 02:34 PM   post #8 of 17
BLIND REF
MTF Concierge
BLIND REF's Avatar
MTF Member # 8658
Garage
I am switching to synthetic oil (Amsoil)this time around.
__________________
John Deere 2305 TLB, 62MMM
BLIND REF is online now   Reply With Quote Quick reply to this message
Old 06-09-2010, 09:36 PM   post #9 of 17
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
I plan on keeping mine a long long time slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 09:38 PM   post #10 of 17
89YT12
2000 Posts and climbing!!!
89YT12's Avatar
MTF Member # 35873
Images: 9
Garage
its not green but every 50 with castrol 30w and a dab of lucas
__________________
Jason "J"
89YT12 is online now   Reply With Quote Quick reply to this message
Old 06-09-2010, 09:56 PM   post #11 of 17
refueler
Senior MTF Member
refueler's Avatar
MTF Member # 22046
I change the oil and filter in my 4110 every 50 hrs. I'm sure its overkill but its not much money and the oil looks dirty so I change it.
refueler is offline   Reply With Quote Quick reply to this message
Old 06-10-2010, 12:39 AM   post #12 of 17
Upper5Percent
5000 Strong & Climbing
Upper5Percent's Avatar
MTF Member # 8602
Quote:
Water is one of the most destructive contaminants in most all lubricants. It attacks additives, induces base oil oxidation and interferes with oil film production. Low levels of water contamination are normal in engine oils. High levels of water ingression merit attention and are rarely correctable by performing an oil change. The following are some additional notes on water contamination:
*Long idling in wintertime causes water condensation in crankcase, which leads to loss of base number and corrosive attack on surfaces, oxidation of the oil, etc.
*Emulsified water can mop up dead additives, soot, oxidation products and sludge. When mobilized by flowing oil, these globular pools of sludge can knock out filters and restrict oil flow to bearings, pistons and the valve deck.
*Water sharply increases the corrosive potential of common acids found in motor oil.
__________________
Paul in VT
The answer is 42
Upper5Percent is online now   Reply With Quote Quick reply to this message
Old 06-10-2010, 10:21 AM   post #13 of 17
c5rulz
c5rulz's Avatar
MTF Member # 8460
But doesn't having a heated garage for winter use and running an hour each use minimize condensation accumulation? FWIW, I generally won't idle the motor under 1500 rpm unless engaging the PTO.
__________________
Husqvarna 550XPG
Husqvarna 372XPG
Husqvarna 357XP
Dolmar 7900
Echo CS300T
Silvey 510
Oregon 511AX
Tecomec for rakers
Old 06-10-2010, 02:25 PM   post #14 of 17
johnnydel29
MTF Member
MTF Member # 7231
Once a year for me, regarless of hours. I also go ahead and change all filters (inner, outer air & fuel), except transmission filter. Been doing it this way since '05 and it has been working out well.
johnnydel29 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-10-2010, 03:25 PM   post #15 of 17
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Nice equipment in your signature, btw.
Because of such an investment, it seems a bit odd to me that you are wanting to be stingy with the oil.
I posted a thread a while ago about bad oil looking good. In short, I had changed hydrostatic fluid which looked perfect, contained no apparent moisture, and in an unscientific flow test, flowed exactly the same as new.
However when I fired the tractor up, everything about the transmission was better. No more moaning, groaning, higher top speed, faster action on the lift, etc.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
