Bogging down after a few laps - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-07-2010, 06:11 PM   post #1 of 19
jimolan
MTF Junior Poster
MTF Member # 45704
Default Bogging down after a few laps
I just purchased a JD 170 in great shape and have already washed, clayed, polished and waxed it. It is a beautiful tractor. I am having an issue keeping it running. It works great for the first few rounds of my lawn, but soon it bogs down and I cannot engage the PTO again without it bogging down. He lives in my neighborhood, so I got my wife to drop me off and I drove it home, about 1/4 mile or so. When I started cutting grass though it bogged down. The guy that sold it to me replaced the fuel cutoff solenoid (M122917). After that is started, but it still bogs down. It will run rough with the choke on. Any ideas on what to do??? The guy at Trigreen thought it might be the coil... I want to cut some grass.
jimolan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-07-2010, 06:24 PM   post #2 of 19
rattosh51
JD318
rattosh51's Avatar
MTF Member # 2535
Images: 2
Default Re: Bogging down after a few laps
Sounds like it needs a good carb cleaning...
__________________
Rattosh51
'85 JD318 w/54 blade, 50" deck
'90 Yamaha YT6800 48" deck
'75 JD100 34" deck
'98 Craftsman 16.5hp 42" deck
rattosh51 is offline   Reply With Quote Quick reply to this message
Old 06-07-2010, 10:25 PM   post #3 of 19
jimolan
MTF Junior Poster
MTF Member # 45704
Are you talking about an off the tractor cleaning or is there something simpler without having to dismantle the carb???
Old 06-07-2010, 10:50 PM   post #4 of 19
eddyyy302
Jersey Mechanic
MTF Member # 8395
Throw a spark checker on it and run it, when it bogs down watch the light, if the spark is not constant it is either the ignitor or the coil, both $$$. Buy them on epay and save the bucks.
Dan
eddyyy302 is online now   Reply With Quote Quick reply to this message
Old 06-07-2010, 11:30 PM   post #5 of 19
jimolan
MTF Junior Poster
MTF Member # 45704
I see the coil on the parts page at jdparts, but what about the ignitor? Does it have another name or where is it?
__________________
1990 John Deere 170 with 38" deck
Old 06-07-2010, 11:35 PM   post #6 of 19
eddyyy302
Jersey Mechanic
MTF Member # 8395
Quote:
Part #2, listed as module and listed as Igniter in the comments.
Dan
Old 06-07-2010, 11:56 PM   post #7 of 19
jimolan
MTF Junior Poster
MTF Member # 45704
Thanx, I went back and slowed down and looked more careful and found it.
__________________
Old 06-08-2010, 05:49 AM   post #8 of 19
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
Run some SeaFoam in the gas for the carb before tearing it down. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is online now   Reply With Quote Quick reply to this message
Old 06-13-2010, 01:36 PM   post #9 of 19
jimolan
MTF Junior Poster
MTF Member # 45704
Bought an inline ignition spark tester and found the coil/ignitor to be good. Then I took the carb off and gave it a good cleaning. still same issue. Then I notice that there were bubbles coming thru the fuel line that I could see in the fuel filter and I am not sure that is a good thing. I messed with that a little and thought I had a good flow of fuel going and sure enough, the mower started running real strong and I went for a few more laps and it started boggin down again. I looked at the fuel filter again and there were more bubbles. Can anyone tell me if this is not what should be occurring? Could the shut-of valve under the seat need replacing? I hope it is a fuel line issue, I could take care of that, maybe have to replace the valve... Any feedback on this is greatly appreciated. That includes the proir feedback. This is a good forum.
__________________
Old 06-13-2010, 01:48 PM   post #10 of 19
tomwom
Senior MTF Member
tomwom's Avatar
MTF Member # 6524
If you haven't already, change the fuel filter. Also make sure the tiny hole on the gas cap is not plugged, this allows air in to the fuel tank so it doesn't create a vacuum. You may also have a pin hole in the fuel line allowing air in to the line.
__________________
John Deere X300
John Deere 755
Gravely 1028
tomwom is offline   Reply With Quote Quick reply to this message
Old 06-13-2010, 02:06 PM   post #11 of 19
jimolan
MTF Junior Poster
MTF Member # 45704
so you are saying that I should not be getting air to the fuel filter, correct? I will check out the things you listed, thanx.
__________________
Old 06-13-2010, 02:50 PM   post #12 of 19
eddyyy302
Jersey Mechanic
MTF Member # 8395
Pull the fender pan off (comes off with a few bolts) and check the condition of you fuel lines, sounds as if they need to be replaced.
Dan
Old 06-13-2010, 04:40 PM   post #13 of 19
tomwom
Senior MTF Member
tomwom's Avatar
MTF Member # 6524
That's correct, air in the fuel line will make the engine miss. Start by replacing the fuel filter and checking the ventilation hole on the fuel cap.
__________________
John Deere X300
John Deere 755
Gravely 1028
Old 06-13-2010, 07:08 PM   post #14 of 19
Mower_Man42
A semi-retired senior cit
Mower_Man42's Avatar
MTF Member # 114
Images: 3
Hows the battery is good if it low it will make the PTO not engage.
__________________
_________________________________
1985 Lawn Boy commercial Model 8453
1991 Toro Re-cycler 3 speed model 20218
2005 John Deere G110/54" deck
2008 Cyclone Rake Command Pro
1981 Wheel Horse C-85 with snow plow
1969 Case 444 PK with 44" mower deck
2009 Honda HRX hydro Drive 21" Versamow system.
2006 Scag Wildcat 52" cut 25hp Kawasaki
Mower_Man42 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-13-2010, 09:37 PM   post #15 of 19
JSmith
MTF Member
MTF Member # 23689
Lots of good suggestions but I notice you say the engine "boggs" down after engaging the blades. Could there be an issue with the deck? Bad bearing on one of the spindles or belt catching somewhere? Does the engine and trans run ok without the blades engaged?
JSmith is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
