Cat-0 or Cat-1, 3-Point for 445?? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-01-2010, 06:02 PM   post #1 of 23
Wasper
Senior MTF Member
Wasper's Avatar
MTF Member # 42421
Question Cat-0 or Cat-1, 3-Point for 445??
Like the title asks, what would you buy.
I see that ebay offers category 0 3-point hitches for about $359 + $25 in shipping for a JD 445. Now, I see offered category 1 3-point hitches being offered for a 445 for $400 + $24 shipping.
Which would you recommend?
The cat-1 has more impliments when I searched.. But costs more. .. do you think cat-1 to big for a garden tractor like a 445?? Or is the cheaper cat-0 a better sized hitch for a 445?
Thoughts?
(btw.. ordered a JB Sr. about 30 minutes ago too )
Wasper is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-01-2010, 09:04 PM   post #2 of 23
yardwork
Senior MTF Member
yardwork's Avatar
MTF Member # 20413
Default Re: Cat-0 or Cat-1, 3-Point for 445??
I have a cat 0 on my 318 and I think I'd like to have a 1. Implements are more available like you said, especially used. You have more machine than I do and I would try cat 1 implements.
As for sourcing I'd go with a Ruegg. From what I understand he's making conversion kits. He uses his ebay store as well as his website. He was a bit hard to reach but his products are great.
__________________
1985 JD 318 aka "Overkill"
yardwork is online now   Reply With Quote Quick reply to this message
Old 06-01-2010, 09:09 PM   post #3 of 23
coldone
Proud Member of the 1K Club
coldone's Avatar
MTF Member # 24068
Images: 3
Not a deere guy but i have an MF1855 with a Cat 0. A cat 1 would be better if it could handle it.
coldone is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 09:10 PM   post #4 of 23
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Yep, Bill has me wanting to upgrade to his convertible hitch. Gotta see if he'll take a trade-in on his cat 0.
You definitely have a tractor capable of handling both cat-0 and cat-1 attachments, plus the 445 has a 540RPM PTO available.
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 09:32 PM   post #5 of 23
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I'd go with the Cat 1 hitch. I'd make sure that I knew the upper limit of the rear hydraulics as some Cat 1 implements can exceed a GT's capabilities.
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 06-01-2010, 11:07 PM   post #6 of 23
jwill1776
Senior MTF Member
jwill1776's Avatar
MTF Member # 33215
I have a Ruegg Cat 0 / Cat 1 Combo hitch on a 425 works great, highly recommended. Spend the extra few bucks.
__________________
John Deere 425 – 54” Deck
Ruegg Cat 0 / Cat 1 Combo 3-Point Hitch
Brinly Cultivator
Brinly 12" Single Bottom Plow
Brinly 60" Rear Blade
jwill1776 is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 07:44 PM   post #7 of 23
Wasper
Senior MTF Member
Wasper's Avatar
MTF Member # 42421
Hi,
I was asking because I know that originally the 445 calls for a Cat-0 type hitch.. so I didn't know if it was ok for cat-1.
So you guys are saying cat-1 is ok?... Also, how much bigger is a cat-1 type hitch? (space is limited in my shed).
Quote:
Hi,
Can you tell me more about this "combo" hitch? It sounds like the best of both worlds and would be something I would be interested in. Where would you get one of these dual-purpose 3-point hitches.
Old 06-03-2010, 11:36 PM   post #8 of 23
jwill1776
Senior MTF Member
jwill1776's Avatar
MTF Member # 33215
Quote:
Originally Posted by Wasper View Post
Hi,
Hi,
Call Bill Ruegg (Info Below)
Ruegg MFG LLC
13955 Elton St.
Navarre, Ohio 44662
330-418-5617
rueggrollers@hotmail.com
Your right it is the best of both worlds. Space will not be an issue as it is basically the same size as the Cat 0 hitch. The major difference is that the ball ends on the lift arms take Cat 1 pins and the arms can adjust outward far enough to accommodate Cat 1 spacing. If you want to run Cat 0 implements then you place bushings over the smaller Cat 0 pins to fill the space between the Cat 1 ball ends. It’s a really slick design, took maybe 45 mins to install.
The only words of caution I’ll say is that just because an implement says its Cat 1 it doesn’t necessarily mean you can run it on your 445. You’ll be limited by the lifting capacity of the three point and the wheel traction produced by your GT. It will do plenty of work but by know means is it a full size tractor with a Cat 1 hitch.
__________________
Brinly Cultivator
Old 06-03-2010, 11:40 PM   post #9 of 23
jwill1776
Senior MTF Member
jwill1776's Avatar
MTF Member # 33215
Forgot to mention that Ruegg has a new looking website, just Google “Ruegg Hitch Kits”. The combo hitch for your 445 basically looks like the hitch he has listed for the X series. He doesn’t list the combo hitch on the website, just call or email him and ask for it.
__________________
Brinly Cultivator
Old 06-03-2010, 11:54 PM   post #10 of 23
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
I've lifted 700lbs with my Ruegg cat 0
His hitches are awesome.
Old 06-04-2010, 12:36 PM   post #11 of 23
Wasper
Senior MTF Member
Wasper's Avatar
MTF Member # 42421
Thanks for the information and the contact info . I sent him an email, I will await his response!
Old 06-07-2010, 05:18 PM   post #12 of 23
Wasper
Senior MTF Member
Wasper's Avatar
MTF Member # 42421
Quick Update.
I talked to Bill and I ordered the cat0/cat1 combo hitch. I'll update again after I get it in and installed.. of course I'll add pictures and a review.
Thanks again
Wasper
Old 12-08-2010, 01:19 PM   post #13 of 23
kcwebguy
Senior MTF Member
kcwebguy's Avatar
MTF Member # 52883
Do you mind saying what you paid for the combo unit?
kcwebguy is offline   Reply With Quote Quick reply to this message
Old 12-08-2010, 04:17 PM   post #14 of 23
425Forever
Senior MTF Member
425Forever's Avatar
MTF Member # 52718
I bought a 42" hydraulic tiller last week and don't have a 3pth on my 425 yet. I am in Ohio, so I am going to drive out to his place on Friday and pick up a Cat 0 3pth. Glad to hear that everyone has good things to say about his hitch, looking forward to getting it.
__________________
2012 x729 - 48" deck, 3pt hitch, front fenders
1992 JD 425 AWS - Gone but not forgotten
42" Hydraulic Tiller
MC519 cart and Powerflow
Dump scoop
'65 model 80 cart with narrow wheels
Several old Wheel Horses
425Forever is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-08-2010, 04:25 PM   post #15 of 23
kcwebguy
Senior MTF Member
kcwebguy's Avatar
MTF Member # 52883
I am jealous. Did you get it new or did you find a used one? What is the model number of the unit?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
