Transaxle locked up - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-01-2010, 10:36 AM   post #1 of 5
phatsupratt
MTF Junior Poster
MTF Member # 45424
Default Transaxle locked up
I have a 6-7 year old Craftsman LT3000 with a 6-speed 206-545c transaxle. After hours of mowing, I stopped to move something and when I let the brake out, the tractor jumped, then completely locked up. Wheels wouldn't turn and the gear shift was locked in gear, could not shift.
I took the transaxle apart and found 2nd gear in 3 pieces. Purchased a new gear, put it all back together and took it for a test drive. I was able to shift fine for the first minute but then the same problem came back. Locked in gear, can't move. I'm thinking the broken gear was a result of something else wrong which obviously I didn't fix.
Anyone have this issue and what did you do to fix it? Any suggestions? I'd rather save $250 and fix the one I have!
Thanks a lot,
Mark
phatsupratt is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-01-2010, 10:38 AM   post #2 of 5
nate the ford guy
Senior MTF Member
nate the ford guy's Avatar
MTF Member # 35996
Default Re: Transaxle locked up
what were you pulling with it......?
__________________
theres one saying to live by. NEVER ARGUE WITH AN IDIOT, YOU WILL JUST LOWER YOUR SELF TO THERE LEVEL AND THEY WILL BEAT YOU WITH EXPERIENCE EVERY TIME.
nate the ford guy is offline   Reply With Quote Quick reply to this message
Old 06-01-2010, 11:12 AM   post #3 of 5
phatsupratt
MTF Junior Poster
MTF Member # 45424
Nothing, just mowing. The only thing I ever pull is a lawnsweeper in the spring and fall.
Old 06-01-2010, 01:26 PM   post #4 of 5
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
A broken detent spring can let the shift forks slide over where they shouldn't go,and lock the tranny in one gear,or possibly let two gears engauge at the same time,that'll lock it up tight..did the shifter "click" into each gear,or was it feeling loose or no "click"?..if so the detent spring or ball for that gears fork might have failed..be sure to look for and clean out any busted peices in the case good too!..one BB sized ball between 2 gears can raise all kinds of ell!..
__________________
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-01-2010, 02:40 PM   post #5 of 5
phatsupratt
MTF Junior Poster
MTF Member # 45424
the spring and BB were look fine and were in place when I took it apart. During my brief test after re-assembly, the gears were definitely clicking.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
