1964 Ford 4000 steering - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-31-2010, 07:47 PM   post #1 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Default 1964 Ford 4000 steering
My 64 4000 (old style 4 cylinder gas) has power steering that does not work. There is also a lot of play in the steering wheel. The steering is loose enough that it looks like a drunken sailor is pulling my finish mower (no offense to any drunken sailors out there).
If the combined problems of steering gear and power steering pump turn out to be exceptionally expensive is it simple enough to just buy and install a manual steering gear and housing. Will it fit up to the drag links? Most of my mowing is straight line and power steering is nice, but not necessary.
The power steering on the tractor is the type that has a power cylinder attached to each drag link.
Thanks
ryork
46 2n
47 2n
64 4000
ryork is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-31-2010, 10:35 PM   post #2 of 16
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Default Re: 1964 Ford 4000 steering
A manual unit will bolt up just fine.
__________________
JohnW is online now   Reply With Quote Quick reply to this message
Old 05-31-2010, 10:50 PM   post #3 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Thanks John,
From what info I pieced together out of the manual I thought it would probably work, but the list of things I've thought would work over the years, that didn't, is pretty long.
Bob (ryork)
46 2n
47 2n
64 4000
Old 06-01-2010, 06:27 PM   post #4 of 16
souNdguy
Proud Member of the 1K Club
souNdguy's Avatar
MTF Member # 94
Quote:
Originally Posted by ryork View Post
Thanks John,
Bob (ryork)
46 2n
47 2n
64 4000
considering it's only power assist steering.. the box you have now will work fine with or without the hyds.. just have to get it tight.
wheels thet rise and fall mean thrust bearings are out.
when you turn the wheel if there is for/aft movement of the steering sectors before they start to rotate, then the sector bushings are loose.. this usually means seals are loose too.. and she's out of lube.
I've removed the leftovers of PS from a 951 and ran her as manual with -0- issues.
the rc's have a slightly different box than the utility models.. but the concept is the same
post back.
soundguy
souNdguy is offline   Reply With Quote Quick reply to this message
Old 06-02-2010, 12:05 AM   post #5 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Thanks soundguy
I just went out to the shed and checked. There is no up and down movement in the steering wheel. I can move the steering wheel from the 10:30 position to the 2:30 position before there is any movement in the pitman arms. It is pretty dark in the shed, but I did not notice any fore/aft movement before they rotated. The draglink ends ends are pretty sloppy and this adds to the problem.
I just got the tractor a few weeks back and did not get my mower deck until this week so have not used it much. The 84 inch Land Pride sure makes cutting these ten acres less of a job.
The steering wheel movement from the 10:30 to 2:30 position does not include the slop in the draglink.
Bob
__________________
Bob
Old 'n Cheap
Bad part of being older...you can remember when things that now cost $10 were only 50 cents
46 2n - waitin on me to do something to it.
47 2n - my relaxin tractor.
64 4000 - w/7 ft finish mower, scoop and bushhog.
Old 06-02-2010, 01:32 PM   post #6 of 16
souNdguy
souNdguy's Avatar
MTF Member # 94
Thanks soundguy
Bob
you have to check the up/down movemen while turning the wheel.. generally they unscrew a bit, then the draglinks move.
if no movement like that.. thenthe slop is likely inthe draglink ends, and sector backlash.. for which there areadjuster studs.
soundguy
Old 06-02-2010, 04:02 PM   post #7 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Just checked'
There is about 1/4 inch of movement up when I turn the wheel from right to left.
__________________
Bob
Old 'n Cheap
Old 06-03-2010, 01:27 PM   post #8 of 16
souNdguy
souNdguy's Avatar
MTF Member # 94
Just checked'
bad upper thrust bearing!
soundguy
Old 06-03-2010, 03:29 PM   post #9 of 16
souNdguy
souNdguy's Avatar
MTF Member # 94
Just checked'
bad upper thrust bearing..
soundguy
Old 06-03-2010, 11:32 PM   post #10 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
I get the chance I will take it apart and give that a try. I'll have to get the bearing and have eveything ready so I can get it back together in time to mow.
I'm about to get my 47 back together. Just put brakes and seals on it. Those little spring/pin shoe retainers can be a bear. I've got one that is trying to eat me alive.
Thamks for the help.
__________________
Bob
Old 'n Cheap
Old 06-07-2010, 01:15 PM   post #11 of 16
souNdguy
souNdguy's Avatar
MTF Member # 94
keep us posted. yup.. breaks and really.. axle seals are just no fun at all.
soundguy
Old 06-08-2010, 12:14 AM   post #12 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
Got the 2n together and bush hogged about 1/2 acre I had been using for a sheep pen. The grass was even with the hood in places and gave the 2n a pretty good workout. It is a 4 ft cutter. It was good to be able to stop on the slope in the pen. I like brakes.
I used the 4000 again today to finish mow about 7 acres. It used 1/2 a tank of gas. That about a gallon an acre. The 7 foot swath beats the old 50 and 60 inch riders. Total gas use is about the same. 4000 is just more comfortable and less time to mow. When it gets a little hotter so the grass does not need mowing every 4 or 5 days I will replace that upper thrust bearing and take a look at the power steering and see what it will take to fix that.
__________________
Bob
Old 'n Cheap
Old 06-08-2010, 10:32 AM   post #13 of 16
souNdguy
souNdguy's Avatar
MTF Member # 94
I love my 4000 it's a 63 model, 4spd gasser with a sherman combo, rowcrop chassie with factory wide front.
right now my small mower is a 740, NF, and a 5' hog.
soundguy
Old 06-11-2010, 12:16 AM   post #14 of 16
ryork
Old 'n Cheap
ryork's Avatar
MTF Member # 45292
Images: 9
Garage
OK souNdguy..I give up. What's an NF? Probably something I should know, but I'm drawing a blank. I'm still pretty new to tractors and equipment. I'm more familiar with motorcycles and I've got an old 39 Pontiac and a 38 Nash, but can't recall running across an NF.
__________________
Bob
Old 'n Cheap
Sponsored Links
Advertisement
Old 06-11-2010, 09:53 AM   post #15 of 16
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
NF = narrow front
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
