Gator trans grinds.. hard to put in gear!..is it a clutch problem?..trans problem?... - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
ATV's, RTV's and Snow Mobiles For fun or work or play
Reply
Thread Tools Display Modes
Old 05-31-2010, 03:03 PM   #1
ericwest
Senior MTF Member
MTF Member # 38975
Default Gator trans grinds.. hard to put in gear!..is it a clutch problem?..trans problem?...
I just got a used gator amt 622...with a kawasaki engine....and tuff torq transmission...a kt 30..I think.....its nearly impossible to shift into forward or reverse with the motor running....so I have to start it in gear.....it looks to have a clutch on the engine...(I am new to this but I think this is the primary clutch)..and another clutch on the transmission...(secondary clutch?)...the idle is correct...in fact maybe a little slow...but I cant shift unless the motor is almost not turning at all.....the belt between the cluthes always turns...even at idle...is that correct??....or should it disengage completely? A neighbor is telling me to push the engine back 1/4 inch...and maybe that would allow the belt to disengage...but he might be guessing.... would anyone out there know if the clutch is the problem...or the trans??...any advice would be greatly helpful!!..
thanks
Ron
ericwest is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-31-2010, 08:17 PM   #2
DeepSouth
Senior MTF Member
MTF Member # 42929
Default Re: Gator trans grinds.. hard to put in gear!..is it a clutch problem?..trans problem
Sorry I cant help you very much here, I know someone will help you out. I do know that if my quad is idling to high I cant shift into gear. Has it always done this since you got it or something that came up.
DeepSouth is offline   Reply With Quote
Old 05-31-2010, 08:41 PM   #3
ericwest
Senior MTF Member
MTF Member # 38975
yes..its been doing this since I bought it....I just got it...and the idle is speed is correct...maybe even a little slow...I am hoping maybe someone has had this problem...or knows a solution...even some information about the clutch would be helpful....for instance...is the belt suppose to be free at idle?..or does it always spin...any infor or help would be appreciated..
Old 06-01-2010, 09:04 AM   #4
saskman49
Nicky&Sterling RIP 03-08
saskman49's Avatar
MTF Member # 4038
I have a Gator TH 6x4 and it is doing almost the same thing just not as bad, but it is very hard to shift. I know the mechanics quite well up at Deere here so I think I will pay them a visit after work this afternoon.
__________________
John
JD2320 with 62D, 200 CX with 53" bucket
Speeco QH & Hydraulic top link
Deere 647 tiller
Frontier SP1060 Soil Pulverizer
Frontier BB2060 Box Blade
Land Pride 1572 Rear Blade
Allied 50" blower
Frontier pallet forks
55 Gal 3pt sprayer
Frontier middle buster
KK 3pt Bale Spear
3 section diamond drag harrows.
saskman49 is offline   Reply With Quote
Old 06-01-2010, 09:20 AM   #5
ericwest
Senior MTF Member
MTF Member # 38975
Hey Saskman...if you find out something from the deere mechanics...let me know...I would REALLY appreciate it....thanks..
Old 06-02-2010, 08:39 AM   #6
saskman49
saskman49's Avatar
MTF Member # 4038
Well,
I went to the dealer yesterday and talked to the service guys. The normal problem is the clutch buttons on the driven (secondary) clutch. They are a wear item and cost abt 10 bux from the dealer. When you take the shroud off the belt you can see these little buttons on the tip if the clutch fingers. There should be no metal to metal contact on this clutch assy or it can be damaged to the tune of 3 or 4 hundred bux. I would think taking your time you could change all 6 in abt 30 min.
__________________
John
Deere 647 tiller
Allied 50" blower
55 Gal 3pt sprayer
KK 3pt Bale Spear
Old 06-02-2010, 08:46 AM   #7
ericwest
Senior MTF Member
MTF Member # 38975
Hey Saskman...thanks for the info!!!...I will give it a try...now I have to tell you I know very little about this...but I am assuming the secondary clutch is the clutch on the trans?..right?..not the one on the engine?..I will take a look..see if I can find those buttons!..thanks again...
Old 06-02-2010, 10:47 AM   #8
saskman49
saskman49's Avatar
MTF Member # 4038
Quote:
You are correct, the one on the tranny. Good luck
__________________
John
Deere 647 tiller
Allied 50" blower
55 Gal 3pt sprayer
KK 3pt Bale Spear
Old 06-08-2010, 05:41 PM   #9
bacajr
MTF Junior Poster
MTF Member # 32887
ID:	107961hey guys, just bought what i think is a 2004 jd gator. but upon further review i do not see a seriel number where the manual says it should be. also no jd brand on the grill. the box says gator. so im not sure what to think. any help?
ive attached a picture. bought on ebay, but havent paid yet until i get further info.
ID:	107962   Click image for larger version
bacajr is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-19-2010, 02:33 PM   #10
Papa G1
MTF Junior Poster
MTF Member # 46726
looks to me like it has seen some rough use, perhaps the owner replaced the broken front plastic with a copy of the JD body. the plasctic body parts on my 6X4 are cracked, broken off in places thats my assumption, the tailgate number must be some sort of company inventory number.
Papa G1 is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
