Backhoe hydraulic set-up? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 05-23-2010, 01:02 PM   post #1 of 5
cnchobbyrich
MTF Junior Poster
MTF Member # 24269
Default Backhoe hydraulic set-up?
Thinking of building a backhoe attachment for a Deere 425. What type of pump ,cylinders and valves should I use? Thinking of 2"-2 1/2" cylinders with 1" rods? Boom 14",Dipper 10",Bucket 12",Swing 7" and Stabilizers 8"? Don't have a clue on what spool control valve to use. Going to base my design between the Kwick-Way and Kyoker backhoes. Please give brands and models.
Thanks
cnchobbyrich is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-23-2010, 01:40 PM   post #2 of 5
simple simon
MTF Junior Poster
simple simon's Avatar
MTF Member # 43532
Default Re: Backhoe hydraulic set-up?
Hi
Dosen't J.D. 425 have a Hydraulic system of it's own?
One pump is all you need.
Spool valves are a personal preferance. I like the twin joy sticks my self, But all I had was single levers.
S.S.
simple simon is offline   Reply With Quote Quick reply to this message
Old 05-24-2010, 08:10 AM   post #3 of 5
cnchobbyrich
MTF Junior Poster
MTF Member # 24269
Quote:
Originally Posted by simple simon View Post
Hi
S.S.
425 has a pump-hydrostatic drive, not sure if it would have enough power or flow
Old 05-24-2010, 11:01 PM   post #4 of 5
Chagrin
Proud Member of the 1K Club
MTF Member # 11011
Quote:
4.65 GPM, so it's pretty close to reasonable.
Chagrin is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-26-2010, 04:33 PM   post #5 of 5
cnchobbyrich
MTF Junior Poster
MTF Member # 24269
Where do you connect into the on-board hydraulics?
At the slective control valve?I has to plugs.Would these be controled by the levers for the front and rear exsisting cylinders?
I want independent control of the backhoe,basicly a to pump, to tank type connections that a 4 spool valve can be used.
Also thought I could tee into the line between the rear axle -pump and the power sterring for the supply? Add a 4 way connection in place of the 3 way one (before radiator) for the return?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
