Different Manufacturer Attachments for Simplicity Conquest? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-20-2010, 10:40 PM   post #1 of 20
ashishm02
MTF Member
MTF Member # 39295
Help Different Manufacturer Attachments for Simplicity Conquest?
Hi guys, I am finally getting used to my Conquest(06 model). So, I wanted to know if I bought the Subframe/Hitch from Simplicity, would I be able to hook up a Agri-fab Aerator, Dump Cart, Tiller, etc...
In fact, would I be able to hook up any other manufacturer's equipment to Simplicity's Subframe/Hitch? Is there a list out there?
I looked on Craigslist and could not find any Conquest attachments in NJ. So, I figured if I can purchase Agri-fab, I might be able to save some money.
Thanks,
John M.
ashishm02 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-20-2010, 11:18 PM   post #2 of 20
ACmowerguy
Proud Member of the 1K Club
ACmowerguy's Avatar
MTF Member # 22929
Images: 2
Default Re: Different Manufacturer Attachments for Simplicity Conquest?
Most areators, carts, and aftermarket tillers just pin onto the hole on your rear hitch. You don't need a subframe. If you're talking about a sleeve hitch, you only need that for lifting implements like 1 bottom plows, disc harrows, and boxblades, all of which are universal and fit any sleeve hitch. They can be bought at HomeDepot through special order and many other outlets as well.
__________________
SIMPLICITY- 700, 3410 3psd, 3410S, 3410H, 17GTH-L, 727, 7116H 75th anny Sovereign, '98 Landlord, '99 Landlord DLX
Allis-(2) B-10's, B12, (2) B110's, B-207, (2) B210's, B212, HB212, Homesteader 8, 416H, 710, 912H, 914S
Massey-MF12 and MF16
Sears- 1971 HT14 hydro
JD - 110, 345 w/48C, 345 w/54"
ACmowerguy is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 11:57 PM   post #3 of 20
ashishm02
MTF Member
MTF Member # 39295
Quote:
Thanks for the response. I do not have much of an idea, so just trying to understand what I would need.
What is the subframe for? Also, I could not find on Simplicity's website anything about a rear hitch for a Conquest.
Summer Attachments that I am interested in: dump cart, aerator, snow blade
Winter Attachments that I am interested in: snow blade or snow blower
So, for the summer attachments, the rear hitch should be enough?
How about for the snow blade? I guess this is where I would need a front hitch.
Sorry for so many questions, but just wanted to learn.
Thanks,
John M.
Old 05-21-2010, 02:07 AM   post #4 of 20
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
The subframe is for mounting a blade, snowblower, etc.
The rear "hitch" is just a hole in the tailpiece for towing a trailer or self-powered equipment.
The sleeve hitch is something I can't help you with, sorry.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 05-21-2010, 02:59 AM   post #5 of 20
Gray
MTF Member # 41016
I think what they are saying is that there should be already a simple rear hitch "hole" at rear of tractor down low, dead center. Mine has that too.
What's weird about mine - and wow, you think you have questions - mine has this special hitching stuff at the back and I have no idea what to do with it. It's specially designed for a bunch of attach's and a lift also.
So, your questions are good ones and are helpful for me too. Even tho I believe mine is different, I too can use similar "summer attachments", cos the simple hole hitch is there as well. My tractor is a 1977 - things have changed. I have been told mine is a three point of sorts - but it's made to match Simp attachments - I will learn this later; got other things to maintain for now.
So yes, you could grab those goodies and go.
Good to see you learning more about your tractor - I learn something every day about mine too. I have to; I have to go through it all and rebuild a deck too. Time. It all takes time.
Thanx for the thread. I am quick to say that there are no stupid questions; but I seem to find a way regardless.
And then there's some of the other comments I make.
Gray is offline   Reply With Quote Quick reply to this message
Old 05-21-2010, 03:13 AM   post #6 of 20
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
I, too, have a Conquest, and am interested in learning more about what's available for it.
Good thread, I've subscribed to it.
__________________
(Red Green)
Old 05-21-2010, 11:03 AM   post #7 of 20
TheYoshi
MTF Junior Poster
MTF Member # 42721
Can one of you guys post a pic of what you're referring to?
TheYoshi is offline   Reply With Quote Quick reply to this message
Old 05-21-2010, 01:24 PM   post #8 of 20
ashishm02
MTF Member
MTF Member # 39295
Well, some of the ones I was looking at are these:
http://www.lowes.com/pd_2719-203-45-...ductId=3029620
http://www.lowes.com/pd_73059-203-45...ductId=1194643
Old 05-21-2010, 03:33 PM   post #9 of 20
Alan Lloys
TECH Exchange Contributor!
Alan Lloys's Avatar
MTF Member # 32845
All the pull behind attachments are pretty interchangeable and are simply using the little hole on the rear tongue of the tractor. Some attachments have larger holes than others, so you may need a few different sizes of hitch pins (they are a few dollars at a tractor supply store).
Note that some attachments can put quite a bit of load on the transaxle - for instance a very large core aerator will be heavy to pull fully loaded up. The Conquest though has a heavy duty transmission and should be good for most of the things you can hook up.
A sleeve hitch is kind of a lower end 3 point hitch. It is used specifically for attachments that needs to be lifted off the ground and do not have wheels. This would be items like a plow, scraper blade or box blade. These are attachments that will be heavy to pull so the sleeve hitch also has a larger attachment pin to accomodate the extra strain. As mentioned above the sleeve hitch attachments are also interchangeable between brands as they all meet a set standard for attachment points.
The subframe is used for the snowblade and the snowblower. It is also sometimes called a ladder hitch as it looks like a ladder laying flat. It is made to transfer the forces from the blade to the rear axle of the tractor to avoid buckling of the frame if something hard is hit with the blade. It also helps distribute the weight over the tractor when the implements are lifted.
Sorry for the long narrative, hope this helps though.
Edit: sorry to throw 3 point hitch in there. That really only applies to older large garden tractors and newer subcompact and up tractors.
Alan Lloys is offline   Reply With Quote Quick reply to this message
Old 05-21-2010, 04:06 PM   post #10 of 20
MarkT
Senior MTF Member
MarkT's Avatar
MTF Member # 33751
I have a Conquest also. From what I have been able to determine, Simplicity does not encourage ground engaging attachements such as Moldboard Plows, cultivators, disc etc. on a Conquest. These attachments are pulled through the ground and require an extra heavy-duty transmission and good traction. They ususally attach with a special hitch. This is why they do not show a 3 PT hitch or a Sleve hitch accessory in their catalogs for the Conquest. They prefer you move up to the larger tractor (Legacy) for these tasks. You can get a rototiller and plow/dozer attachement but that is about it as far as ground engaging equipment from Simplicity. The tiller from Simplicity for the Conquest is driven by the Conquest's engine through a PTO. If you get the Simplicity tiller, you will also have to purchase the attaching and lifting rigging and PTO, belts (subframe)etc. Some after market companys such as Sears and Agrifab offer a tiller that can be towed like a dump cart because they have their own power source such a s 5hp gas engine. I think there is an open forum going on currently about the pro & cons of such a tiller attachment.
The attachments you show in your picture are simply towed behind the tractor. These types such as a lawn sweeper, aerator, or dump cart can be purchased from any manufacturer. These are attached to the rear of the tractor using pin and retaining clip that goes through the hole located at the bottom of the rear plate between the rear wheels at the back of the tractor. You will have no issues hooking these attachements up and pulling them around. You can sometimes see these attached to a tractor on display at a retailer like Lowes or Sears.
MarkT is offline   Reply With Quote Quick reply to this message
Old 05-21-2010, 04:41 PM   post #11 of 20
ACmowerguy
ACmowerguy's Avatar
MTF Member # 22929
Images: 2
If you really want to pull a garden plow you can look into buying the sleeve hitch kit for a Prestige (deluxe version of the conquest) from the Simplicity Dealer and install it on your tractor, I suspect everything will mount the same, the main difference is that the Prestige has a serviceable transmission but the trans in the conquest is rated as plow capable by its manufacturer. As for front mounted implements you will have to buy genuine Simplicity attachments from the Simplicity dealer unless you are good at making major modifications.
__________________
Old 05-21-2010, 04:47 PM   post #12 of 20
ashishm02
MTF Member
MTF Member # 39295
Quote:
Thanks for the Info Alan... So, for the winter I was thinking about the Snow blade/Snow Thrower. I live in NJ, so get like 3 to 4 storms a year. I did not want to pay over a $1000 for a snow blade, subframe, and hitch. The snow thrower is even more expensive. Do you know if we have to buy the snow blade and hitch from Simplicity or can we use an aftermarket one from another manufacture?
Does anybody have a snow blade/snow thrower on their Conquest? Would also love to hear from you...
Thanks,
John M.
Old 05-21-2010, 07:46 PM   post #13 of 20
MarkT
Senior MTF Member
MarkT's Avatar
MTF Member # 33751
You can buy an aftermarket snow blade from a company called Johnny Bucket. They make a front end scoop bucket and plow for the Conquest. Both are operated with electric motors which makes them better than the factory manual models. I believe the plow can be purchased for about $900-$1,000. But like I said, it has electric motors to move it up/down, left/right so it is better than factory. Go to "johnnyproducts.com" for the details. I have been thinking of getting the johnnybucket jr front-end bucket for my Conquest.
MarkT
Old 05-22-2010, 12:20 AM   post #14 of 20
Gray
MTF Member # 41016
John M.
I am thinking you might be able to use a used Simplicity snowblower, might require an adaptor - someone else would know more about this than me.
But a used snowblower is pretty cheap. about $150-300.
You would also want tire chains for snow - turf tires will spin.
Sponsored Links
Advertisement
Old 05-22-2010, 01:11 AM   post #15 of 20
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Quote:
Thanks,
John M.
I have a two stage snow blower, and it is truly impressive. It's 42" wide, and does the driveway in 3 passes (2 1/2 actually). It really chews through the plow-packed stuff at the end of the driveway, too.
A couple of older pictures of my machine in action:
http://www.mytractorforum.com/showthread.php?t=75638
The only disappointing thing about it is that the fun is over way too soon
Owners of the single stage have said that they are very happy with theirs, also.
__________________
(Red Green)
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
