trailer gate ramp - help needed - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trailers We have to pull our machines once in a while...
Reply
Thread Tools Display Modes
Old 05-19-2010, 11:27 PM   post #1 of 13
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
Default trailer gate ramp - help needed
i am building a utility trailer from an old boat trailer. I need to make a gate ramp. I'm trying to find a hinge, and i'm not sure what i'm looking for.
i recently saw a trailer whose gate ramp would fold all the way down inside the trailer for easier hauling when empty.
Any ideas on how what type of hinge I would need to get it to fold down all the way inside the tractor?
Thanks!
jakenbake is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-19-2010, 11:55 PM   post #2 of 13
Rcardo292
Tractor Junkie
Rcardo292's Avatar
MTF Member # 23558
Images: 4
Default Re: trailer gate ramp - help needed
Mine folds in like you noted ut just has a hinge pin on each side I will try to get a pic for you. my uncle has the same trailer and he modified his to be able to remove the gate for carrying brush and debris so when offf loading crap doesn't get stuck in the gate.
__________________
"I childproofed my whole house but they keep getting back in!"
Rich
Rcardo292 is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 09:02 PM   post #3 of 13
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
Could make one from pieces of pipe welded to the trailer frame and to the ramp frame, then run a piece of threaded or solid rod thur it. Secure each end with washers and cotter pins.
I don't know if they still make a long and heavy duty 'piano' hinge, but that's another possiblity.
engine2quarters is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 09:09 PM   post #4 of 13
John Snykus
3K Poster!!!!
John Snykus's Avatar
MTF Member # 9147
My trailer has ramps that slide in under the deck and I think they are great. If something larger needs to be hauled ramps are not in the way. IMHO.
__________________
Everyone should have some toys. Mine happen to be green.
John Snykus is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 09:19 PM   post #5 of 13
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
Quote:
Awesome, i'd really appreciate some up close pictures.
I'd like to be able to remove the gate as well, sometimes it just gets in the way.
Old 05-20-2010, 09:20 PM   post #6 of 13
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
ya, i'm just trying to think of where the hinge would go such that it can fold forward but there not be a big gap between the gate and the trailer.
Old 05-20-2010, 11:22 PM   post #7 of 13
lowendrider
Senior MTF Member
lowendrider's Avatar
MTF Member # 36901
Images: 1
TSC has some plain hinges...just raw steel ready to weld. Various sizes. I'm thinking about using these when I build a gate. Also, Northern tool has some nice bullet hinges with a zerk on the end. A little more expensive but still not bad.
lowendrider is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 11:34 PM   post #8 of 13
NEWT92
3K Poster!!!!
NEWT92's Avatar
MTF Member # 8405
Images: 10
Any ideas on how what type of hinge I would need to get it to fold down all the way inside the tractor? you mean trailer
Thanks!
I done my gooseneck this way. If you mount the hinges at the top of the rear of the trailer, the gate will fold down to the trailer. You have to mount the hinge part on the gate off center also. Once the gate is lowered to load, the hinges do stick up about half a inch.
Left gate slides to the right to remove, and the right side slides to the left. Once you stand them up, there is clearance to remove either side.
The hinges are a hollow pipe for the trailer/female end and a male/female end for the gate part (the male end on the gate slides into the female end on the trailer, and the female part on the gate makes the clearance for the male end to go to the trailer part. Hope that makes sense.)
NEWT92 is offline   Reply With Quote Quick reply to this message
Old 05-21-2010, 08:05 AM   post #9 of 13
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
Quote:
you mean trailer
whoops, you're right.
never thought of 2 separate ramps. thats a good idea.
got any pictures of how far up those stick when they are down?
Old 05-21-2010, 08:10 AM   post #10 of 13
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
Quote:
are those bullet hinges from northern tool removable? if so, those are nice.
Old 05-21-2010, 10:12 AM   post #11 of 13
NEWT92
3K Poster!!!!
NEWT92's Avatar
MTF Member # 8405
Images: 10
First is my 16' trailer, the gate just stands up like most. The hinge on the trailer is flush with the deck of the trailer.
Name:	P1020085 (Medium).JPG
ID:	105515   Click image for larger version
Name:	P1020090 (Medium).JPG
Old 05-21-2010, 10:17 AM   post #12 of 13
NEWT92
3K Poster!!!!
NEWT92's Avatar
MTF Member # 8405
Images: 10
On my 25' gooseneck, is the fold over type gate. The hinges stick up 3/4" above the deck. The pipe is 1 1/4".
I have 3 sets of bars to hold the gate up at different angles. I have a total of 5 different settings to choose from. All the way from down to strait up, depending on length of load on trailer.
I done the split gate on this trailer cause they are 5' ramps, doing a one piece would be a chore to raise up. For smaller trailers with 3' or 4' gates, I would go one piece IMO.
Name:	P1020032 (Medium).JPG
ID:	105517   Click image for larger version
Name:	P1020086 (Medium).JPG
ID:	105518   Click image for larger version
Name:	P1020087 (Medium).JPG
ID:	105519   Click image for larger version
Name:	P1020088 (Medium).JPG
Sponsored Links
Advertisement
Old 05-21-2010, 07:06 PM   post #13 of 13
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
wow, thanks for the pics. i like your hinges, very simple and they look sturdy.
splitting it is probably more hassle than it is worth, and it sounds like your smaller trailer gate is manageable.
thanks again for the info!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
