| Home | MTF Gallery | Add To Favorites! | Set MTF As Your Homepage | FAQ | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| My Place Pics and stories about your home and property |
Thread Tools | Display Modes |
#1 |
Administrator
![]() Join Date: Mar 2005
MTF Member # 1
im getting my septic tank pumped out today. i dug it out last week prior to doing my knee.
weve been here going on 8 years and never emptied it its just the 2 of us here, and ive had no problems... but i thought i better do it now instead of waiting till i had 'issues' how often do you guys with septic tanks have them emptied? |
#2 |
7K+ Poster!
![]() ![]() Join Date: Mar 2005
MTF Member # 41
Never. We use a treatment called: Septi-Zone. It uses natural bacteria to accomplish the same. You just flush a bag down once a month.
Cheers JDFANATIC JD2210 |
#3 |
2000 Posts and climbing!!!
MTF Member # 770
Around here, there are several that have been in the ground 35 years and no problems. Do the enzyme thing and you SHOULDN'T have any problems!
#4 |
Super Mod / Admin
MTF Member # 5
I know there is two schools on this...one that recommends that you pump them out regularly and one that says "a properly maintained septic system should never be pumped"...I'm with the second school. Haven't done a thing to this septic in 10 years. A properly maintained septic should break the solids down to a dispersable effluent.
I don't think pumping it out hurts, I just don't believe it's necessary.
__________________
Randy G Register in your state HERE Judge a man by his questions rather than his answers. '96 Ford New Holland 1715 '03 Craftsman GT5000 '03 Murray Ultra Wide Body 4656 '83 Simplicity 7112 6-Speed '78 Case 990 David Brown '78 Simplicity Sovereign 7018H |
#5 |
Grampa Mod
![]() ![]() Join Date: Aug 2005
MTF Member # 633
I've been at my current residence for 9 years and haven't had anything done. The house before this one was 15 years and no problems there either. A guy that I hire to put in Septics and drain fields on my houses told me that he dumps in 2 bushels of horse sh^t in every new tank and never has any problems....course I am skeptical on that one.
Just put in a new septic and drain at my son's new build, there is a typical tank with 2 vaults that then goes into a third "white water tank" from there it is pumped into his raised mound ($$$$$ Wow) and the installer said that every once in a while when it needs to be pumped......I'm thinking with all those bells and whistles and 600 yards of sand there shouldn't be a need to ever pump it, but who knows...... |
#6 |
Super Mod / Admin
MTF Member # 5
I have never used the enzymes either...I just look out in the back on a snowy day and the big bare patch of grass I see tells me my tank has plenty of bacteria heating things up.
__________________
#7 |
MTF Member # 770
Yup - you know what they say - "It's always greener over the septic tank"!
#8 |
MTF Member # 43
We have a gray water tank - 250 gallons and a black water tank 500 gallons.
The gray water tank was put in mid 1970's. It had never been dug up. I dug it up last fall and had it pumped along with the black water tank. The black water tank had about 5 years on it since last pumped. The septic guy quoted us $70.00 for blackwater pumpout and $10.00 additional for graywater pumpout. He had to chop and spray and chop and spray at that gray water tank to break it up and suck it out. It was nearly a solid. What a damn mess. The black water tank ended up having a broken bafle plate. I rebuilt it using a PVC T that I glued together. If it wasn't for the broken cement baffle inside, the blackwater tank was doing ok. The layer of decaying solids was doing what it should. The guy got all done after all the extra work he had to do and still only asked for the $80.00 that he had quoted. I gave him $130.00. He thanked me and gladly accepted it. I guess what I learned from that experience was it's good to at least check on things once in a while. For us, a mid-winter digup would be a major project. The snow doesn't melt clear of our tank. It's not even in a good spot to get back there and clear snow in an emergency mid-winter crisis. I'd rather have it pumped every 4 years or so for piece of mind. |
#9 |
Camaniac
MTF Member # 63
I had one of mine pumped last year. It had not been done for at least 15. It was so solid we had to pump back out of the truck to reuse the liquid it had already sucked up. I was told to start using rid-x or something to get things "cooking" again. Another note....using powdered laundry soap causes a crust on the tank walls...in some cases up to 9 inches thick at the top.
__________________
1956 Cub Lo-Boy JD LA175 JD LT133 JD RX73 Sears 16/6 Tell the truth, there's less to remember! |
#10 |
7K+ Poster!
MTF Member # 41
In my above post, I should have added a disclaimer: assuming that the septic system is properly designed and installed.. I wouldn't want someone to just use the Septi-Zone and with an improperly designed or built system have a failure because of my advice.
#11 |
Old Fart
MTF Member # 49
My septic system was installed in 1982 (1000 gal tank) and there have been no problems. We use "RID-X" once a month on a day when we'll be away for the day.
Be careful when ya pump your septic tank. If they clean it completely, they or you will need to put something in it to restart the cooking process. Any enzyme will do as will horse manure as mentioned above or even a dead rabbit or squirrel. As a point of interest, the plumber in our town raises rabbits in the back of his shop and when he puts in a new septic tank, he kills one, slices it open, and dumps it in the new tank.
__________________
ED ![]() NEVER FORGET "The Battling Bastards of Bataan" !!! We owe them much. MTD Yard Machines "GOLD" Craftsman GT5000 **** MTF 5 Year Sponsor **** Sears "Chevron Tires" SKU # 71-24167 (Two AG tires mounted on steel rims with valve stems). |
#12 | |
MTF Member # 43
Quote:
I'll have to check this out with PETA (People Eating Tasty Animals) first, but I'm sure a person could raise rabbits cheaper, then just cut up and flush one / month to keep things working properly in the old poop slow cooker. |
#13 |
MTF Junior Poster
MTF Member # 193
The tight line between the septic tank and the leach field collapsed due to some idiot using styrene pipe without careful backfill. Anyway, when I opened the tank to replace the tight line, the outlet elbow was floating in the liquor. THe system was out taking right off the surface. This could have been a disaster for the leach field. Notwithstanding that the system's been in 25 years and perks just fine, a replacement system in this are must be sand filtration with pumps, alarms, etc. and big dollars.
I can't believe that all the solids like toilet paper, etc. break down to sizes that ought to go into the leach field. I hope they stay in the tank. That said, its been probably eight years since I pumped the 1500 gallon tank. Guess I'm due.
__________________
'04 Husqvarna GTH2548 |
#14 |
Proud Member of the 1K Club
we pump ours yearly never really thought about it just seems to be what everyone around does cost nothing we have land right beside town and we don't charge for a place to dump all the suckings from septic tanks in town, about 30 houses
#15 |
Mayor of Funkytown!!!
I had the ours pumped when we bought the house, probably didn't need it as it was only 5 yrs old when we bought it. But, what the heck. The wifey wants a garbage disposal and I told her we shouldn't with a septic tank, but in reality I was too lazy to install one. Does anyone use a disposal with septic tank?
__________________
Jeff The reason most people don't recognize opportunity when it knocks, is because opportunity is almost always dressed in work clothes. '04 JD GT235 |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
