Points not Opening on a Kohler K321 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-16-2010, 06:49 PM   post #1 of 7
Maplekid
Senior MTF Member
MTF Member # 30178
Help Points not Opening on a Kohler K321
My cub 149 with a kohler K321 wasnt running right and didnt have any power so I checked the points. I took the cover off and turned the ignitoin to get them open and they didnt open. I opened them with my hand and they look fine. Tryed it again and still they wouldnt move. The rod that pushes them didnt move. So i held them open and turned the key and the rod moved. It will only move with me holding the points open. What is wrong and how hard of a fix is it?
__________________
102 and 147 projects (FOR SALE PM ME)
Massey Ferguson 231S, Ferguson to35, John Deer M
Maplekid is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-16-2010, 06:53 PM   post #2 of 7
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
Default Re: Points not Opening on a Kohler K321
Take the points assembly off and check if the rod is in one piece......Then, if it is, turn the engine by hand and hold the rod in and see if it goes in and out when you turn engine.
__________________
That National Mower guy
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
poncho62 is offline   Reply With Quote Quick reply to this message
Old 05-16-2010, 06:56 PM   post #3 of 7
Maplekid
Senior MTF Member
MTF Member # 30178
The rod is in one peice. I will go out to the barn and check if it goes in and out when i turn it by hand. Thanks.
__________________
Old 05-16-2010, 07:02 PM   post #4 of 7
RBedell
Proud Member of the 1K Club
RBedell's Avatar
MTF Member # 463
AFAIK....The original Push Rods were made of Aluminum with a steel tip. The replacement Push Rods are all steel. It might need replacing.
__________________
CC models: 100, 105, 129, 1450, & 784
Only Cub Cadets
Buy: Made in the USA
RBedell is offline   Reply With Quote Quick reply to this message
Old 05-16-2010, 07:36 PM   post #5 of 7
Maplekid
Senior MTF Member
MTF Member # 30178
Quote:
How hard is it to replace? I think thats what it needs. How do you replace it?
I turned it over by hand and it didnt move at all. Thanks Farmboy
__________________
Old 05-16-2010, 10:53 PM   post #6 of 7
RBedell
RBedell's Avatar
MTF Member # 463
Remove the points and you should see a small portion of the Push Rod sticking through the block. Grab some needle nose pliers and pull it out. Reverse your steps, set the point gap or time it with a light. We should be good to go.
__________________
Only Cub Cadets
Sponsored Links
Advertisement
Old 05-17-2010, 07:38 PM   post #7 of 7
Maplekid
Senior MTF Member
MTF Member # 30178
Thanks I got it out and got a new one and a few gaskets I needed. It took me over a hlaf our at the local mower shop. They are idiots when it comes to anything more than 10 years old. The old guy that works in the back came out finaly and he found it in 5 minutes. I need to find another local mower shop. I do need to make 2 gaskets myself because they couldnt even find the part #s for them. Tommorw after school i will put it all back together.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
