Re-lining brake band question (SS12) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-11-2010, 10:23 AM   post #1 of 21
ldlittsen
Senior MTF Member
MTF Member # 31741
Default Re-lining brake band question (SS12)
I got the material to re-line my brake band from McMaster Carr and am wondering what the best way to attach it to the band would be? Being a saddle maker I have several sizes of stainless rivets but I dont know if I should to rivit it on, or to use adheasive? Also if I use adheasive what would be the best to kind to use? Thanks, Litz
ldlittsen is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-11-2010, 10:48 AM   post #2 of 21
GT_80
Cranky Motorsports
GT_80's Avatar
MTF Member # 35886
Images: 32
Garage
Default Re: Re-lining brake band question (SS12)
Liquid Nails makes construction glue that i think would rival most of the strongest glues i have ever seen! Not sure how it would work-- some people have glued and riveted these on and if they have holes for rivets, i would follow suit
__________________
MTF Addict #35886
Hugh-SS/16 fan #0001
Tractors:
1968 Super12 "Miss Emma Lee"
1967 Suburban 12 "The 679"
1973 SS16/ 18/6 hybrid "Mighty Mongrel"
1976 SS18 "Trusty"
1978 GT18 with Hard cab - home again!
Attachments:As many as I can get
My YouTubeMy Ebay
Sears Manuals
GT_80 is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 01:49 PM   post #3 of 21
ldlittsen
Senior MTF Member
MTF Member # 31741
Thx for the reply GT 80. I'll go with the rivets, and probably use adheasive also. (I'd rather not have to pull the trans again anytime soon to replace the brakes!) haha. Thanks again, Litz
Old 05-11-2010, 01:56 PM   post #4 of 21
earth
Proud Member of the 1K Club
earth's Avatar
MTF Member # 10477
The original brake bands used brass rivets to minimize brake drum wear. Today you might consider aluminum rivets. After you punch or pop the rivets through from the brake liner side, you then peen or hammer them flat on the back side.
Note to self. Remember when peening or hammering rivet from backside. Place a socket, punch or something on the front side of the rivet so you have something to hammer against. This way avoid hammering rivet back through by mistake.
__________________
MAN'S PRAYER --
I'm a man...But I can change...If I have to...I guess.
If all else fails, use duct tape.
earth is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 02:10 PM   post #5 of 21
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
Yeap what he said.... Stainless would be hard on the drum.
Who needs brakes anyhow....This tractor needs a new lining but have not got to yet.
http://www.mytractorforum.com/showthread.php?t=127575
__________________
Small Fry is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 03:26 PM   post #6 of 21
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
I drilled and countersunk my original brake band lining..and used aluminum pop rivets and sonme "goop" stuff to glue it on--it was in perfect shape,other than having come unglued from the steel band..I didn't peen the rivets on the back side,didn't see a need too..the brake lining is fragile so use care when you drill it..
I just used a hand powered drill to do it,and all it took to countersink the holes was a larger bit just a bit bigger than the rivet heads,twisted by hand with NO drill,to remove just enough to let the rivets sit about halfway down into the lining..doubt I'll ever need to reline it or wear it down,to the point the rivets touch..
__________________
Tractor-Holic is online now   Reply With Quote Quick reply to this message
Old 05-11-2010, 06:39 PM   post #7 of 21
LilysDad
Just Have a Little Faith!
MTF Member # 7161
[QUOTE=Small Fry;1170300]Yeap what he said....
QUOTE]
Said just before pushing in the clutch on a steep grade.
LilysDad is offline   Reply With Quote Quick reply to this message
Old 05-11-2010, 07:08 PM   post #8 of 21
Small Fry
Small Fry's Avatar
MTF Member # 8155
Quote:
Originally Posted by LilysDad View Post
QUOTE]
You have to be a little smarter then what your working with.
I was only kidding though.
__________________
Old 05-11-2010, 08:19 PM   post #9 of 21
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
You want brass rivets nothing hard ...
__________________
Kbeitz is online now   Reply With Quote Quick reply to this message
Old 05-11-2010, 08:27 PM   post #10 of 21
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Brass like Kevin said and if you want to glue also, I would use Gorilla Glue! That stuff really holds!
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 05-11-2010, 08:41 PM   post #11 of 21
ldlittsen
Senior MTF Member
MTF Member # 31741
Thanks fopr the info Guys, I'll use either copper rivets, or aluminum rivets, and also "Monkey Snot" Gorrilla glue. Sorry for the bad punn.Thanks again, Litz
Old 05-12-2010, 03:02 AM   post #12 of 21
Kevin Whittemore
MTF Member
MTF Member # 32086
I have a gravely tractor and was told to use JB Weld by the owner of Richards...I tried Gorilla glue first but it did not work when the brake band heated up....then I used JB Weld....been over a year and works great....hope this helps....
Kevin Whittemore is offline   Reply With Quote Quick reply to this message
Old 05-12-2010, 04:21 PM   post #13 of 21
ldlittsen
Senior MTF Member
MTF Member # 31741
I got my band re-lined. Came out good. I used the same copper rivets that I use in my saddle shop for repair work and JB weld. (first I chucked the rivits in my drill press and turned down the head using an old horse shoeing rasp, drilled the new lining and countersunk the rivits into the lining a bit, applyed JB weld and rivited it together. It came out good.) Thank all you guys for your help/advice! Litz
Old 02-26-2011, 12:44 AM   post #14 of 21
dlis94
MTF senior member
dlis94's Avatar
MTF Member # 47982
Hey I am in the process of relining my tractors breaks when I found this thread, I have a few questions maybe you can help me with. I was wondering If you used the Non metallic brake material or the semimetal woven material from McMaster Carr, and were you able to easily bend it around the brake band, how Tough was it to drill through? Thanks.
__________________
Pretending I'm pleasant to be around is so exhausting.
dlis94 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-26-2011, 08:08 AM   post #15 of 21
69l46vert
That there's worth fixin'
69l46vert's Avatar
MTF Member # 17151
Old thread, I know but I used these rivets from mcmaster carr, worked great got em for my old DB stuff but they work on later Ropers too
mcmCarr number
97451A652
I first tried copper pop rivets but they leave the steel ball at the end of the shaft in, and I thought it would soon gouge the drum so I switched to these brass ones
dlis, I used semi metallic, don'r remember why, maybe that was all they had in the width, thickness that I needed.
I heated it up wound it around the hot hub and clamped it until it cooled, might be better ways, but that's what I did
69l46vert is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
