Oil in Air Cleaner-316-Onan - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-07-2010, 11:21 AM   post #1 of 4
Dave M
Senior MTF Member
MTF Member # 12053
Default Oil in Air Cleaner-316-Onan
I'm getting what I think is significant oil in the air cleaner compartment of my JD 316/Onan P218. Anybody know the fix for this situation? Thanks.
Dave M is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-07-2010, 01:18 PM   post #2 of 4
chudoc
MTF Member
chudoc's Avatar
MTF Member # 28149
Default Re: Oil in Air Cleaner-316-Onan
You could check "PCV" cover over the valve springs. It vents into your air cleaner housing. Not real sure if it vents from valve spring cover...been awhile since I looked at one. Anyway the small hose in the bottom of the air filter housing (about 3/4" dia) trace it back to the block. See if oil is coming up through there.
chudoc is offline   Reply With Quote Quick reply to this message
Old 05-07-2010, 02:24 PM   post #3 of 4
Stash
Senior MTF Member
Stash's Avatar
MTF Member # 20758
chudoc's idea may be the problem. There's a tube with a housing. Inside the housing if some filter media available from Deere. When the filter media is gone, oil can get pulled up into the air filter housing.
Another source of oil in the air filter housing is a rear main seal leak, valve cover leak, oil filter adapter plate leak, oil pressure sending unit leak - all sources for oil to get sucked up through a tube in the corner of the air filter housing, from the air flow into the carb.
__________________
http://zoyathehusky.webs.com/
Stash is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-07-2010, 02:47 PM   post #4 of 4
Dave M
Senior MTF Member
MTF Member # 12053
Stash and Chudoc, thanks for the quick replys. I was thinking the PCV was the culprit, too, but I didn't know about the filter media. I can see the clamps that hold the 3/4" tube to the bell-shaped part of the PCV housing, but I don't see how the housing itself is connected to the block. It looks like you have to get inside of this bell-shaped part to get into any type of valve. Any ideas as to how it is removed? Thanks again. I'll also inspect the other areas that Stash mentioned.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
