JD 445 (Glow Plug Light) Question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-03-2010, 08:48 PM   post #1 of 10
fishybrad
King of Wishful Thinking
fishybrad's Avatar
MTF Member # 42075
Default JD 445 (Glow Plug Light) Question
Does anyone know why the glow plug light is on when the fuel pump is priming when I first turn the key on my '94 445? Also, I've seen it flash very specifically twice slow then twice fast continuously when the machine is running. It makes me think it's trying to give me a diagnostic code. My buddy 455 experience and the complete shop manual and we're still unsure to why my tractor does these things. We're both kinda surprised that Deere even powered or used the glow plug indicator light on a 445.
__________________
1971 JD112 Tecumseh w/Cab (Currently Locked-Up)
1978 JD316 Kohler w/33 Tiller (Pending B&S Repower)
1990 Deutz 1613
1996 Simplicity Conquest (27hp B&S Repower)
fishybrad is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-03-2010, 09:27 PM   post #2 of 10
Jim Waltrip
MTF Junior Poster
MTF Member # 37389
Default Re: JD 445 (Glow Plug Light) Question
If you have a manual it will tell you what the flashing means.
I traded my 445 this year or I would look it up for you, but one of the reasons for the flashing was trying to start the engine to soon after turning the key on?
Jim Waltrip is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 09:29 PM   post #3 of 10
fishybrad
fishybrad's Avatar
MTF Member # 42075
Quote:
Originally Posted by Jim Waltrip View Post
...but one of the reasons for the flashing was trying to start the engine to soon after turning the key on?
On a 445? I guess I can believe it. I always wait for the fuel pump to stop priming before I start it.
__________________
1990 Deutz 1613
Old 05-03-2010, 09:39 PM   post #4 of 10
Jim Waltrip
MTF Junior Poster
MTF Member # 37389
There is a couple differant codes I don't remember them, but I know I tried to start mine to soon a few times and I got that flashing, just turned it off and counted to 5 and started it again?
Old 05-03-2010, 09:58 PM   post #5 of 10
fishybrad
fishybrad's Avatar
MTF Member # 42075
Yeah well that might be a good explanation.
__________________
1990 Deutz 1613
Old 05-04-2010, 01:26 AM   post #6 of 10
RDorffer_JD445
Senior MTF Member
RDorffer_JD445's Avatar
MTF Member # 31731
Quote:
It isn't a glow plug light, it is the fuel injection diagnostic light. You are supposed to wait until it extinguishes before starting (allowing the fuel pump to fully energize/pressurize).
The light blinks a code to warn the operator which sensor may require service. When the light is blinking a code, the fuel injection module computer operates in a default mode for fuel injection to allow the engine to run until the unit can be serviced. The diagnostic light code is as follows:
• Long, short, short—air temperature sensor.
• Long, short, short, short—coolant temperature sensor.
• Long, long, short—air pressure sensor.
• Long, long, short, short—key switch turned to start position before light was off, or air pressure sensor.
• Short, long continuously—more than one sensor may require service.
More likely than not, you aren't waiting long enough before starting. If you are, then the air pressure sensor is suspect.
Regards,
Rich
RDorffer_JD445 is offline   Reply With Quote Quick reply to this message
Old 04-28-2012, 03:07 PM   post #7 of 10
Quads
Senior MTF Member
Quads's Avatar
MTF Member # 52420
I had this today. Searched the forum and found the issue.
long long short short.
Neighbor pulled up, started chatting, turned the key off, BS'd for a few, he drove off, and I rolled the key / didn't wait for the fuel pump to finish building fuel pressure before starting. Noticed it, turned it off, restarted after pump stopped, no lights.
Quads is offline   Reply With Quote Quick reply to this message
Old 04-28-2012, 06:16 PM   post #8 of 10
stoon boy
Proud Member of the 1K Club
stoon boy's Avatar
MTF Member # 9002
Images: 15
Always learning something new on this forum. Was going to jump in with, 455 diesel is the only tractor with glow plug, all others are gasoline fuel. appears the dash lights are for monitoring sensor problems.
__________________
JD Model 2720, 200 CX FEL, 62D Mower
JD Model 455,54" MMM, Model 47 Blower, Femco Cab
JD Z445 54 inch mower
JD Gator HPX
JD TRS 26, Snowblower
JD 17P Utility Cart
JD 10 Utility Cart
No Longer in the garage: 216,300,317,318,332,332,332,400,850,4100,Gator,JD Trail Buck 650EX
stoon boy is offline   Reply With Quote Quick reply to this message
Old 04-28-2012, 06:20 PM   post #9 of 10
Harryc
Diesel Power
Harryc's Avatar
MTF Member # 66572
Garage
Quote:
Same here, I always thought the wait time was for the glow plugs, not the fuel injection.
Harryc is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-30-2012, 11:44 AM   post #10 of 10
Quads
Senior MTF Member
Quads's Avatar
MTF Member # 52420
Yep, if you're quiet, you can hear the fuel pump run, until the light goes out.
Once it's out / fuel pump has stopped, the FI system has the pressure needed.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
