Hit a small stump, now engine wont start - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-02-2010, 06:59 PM   post #1 of 13
Bodine
MTF Junior Poster
MTF Member # 43245
Default Hit a small stump, now engine wont start
I went over a small bush stump (4" wide). The blade hit into it and the engine cut out. But now I can't even start the engine. Everything looks ok as far as I can see. Is there a safety mechanism that I can reset or something? I turn the key and get nothing at all.
Bodine is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-02-2010, 07:02 PM   post #2 of 13
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Default Re: Hit a small stump, now engine wont start
You don't say what model. Does it have a clutch interlock that prevents it from being started while engaged?
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 05-02-2010, 07:12 PM   post #3 of 13
Bodine
MTF Junior Poster
MTF Member # 43245
It is a GT-235. It has a button to press to engage the blades. I could see maybe the blades not engaging but why wont the engine even start?
Old 05-02-2010, 07:50 PM   post #4 of 13
LilysDad
Just Have a Little Faith!
MTF Member # 7161
It may have damaged the flywheel key which throws off the timing.
LilysDad is offline   Reply With Quote Quick reply to this message
Old 05-02-2010, 07:53 PM   post #5 of 13
Bodine
MTF Junior Poster
MTF Member # 43245
Quote:
Would that make it where I couldnt even start the engine?
Old 05-02-2010, 08:02 PM   post #6 of 13
LilysDad
MTF Member # 7161
Do you mean it won't turn over? It will make it so it fires at the wrong time. It may run badly or not run at all.
Old 05-02-2010, 08:04 PM   post #7 of 13
Bodine
MTF Junior Poster
MTF Member # 43245
I turn the key and nothing happens. The oil light comes on. But not a sound when I turn the key.
Old 05-02-2010, 08:09 PM   post #8 of 13
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Sounds like you have a wire that got knocked off or at least real loose someplace.
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 05-02-2010, 08:14 PM   post #9 of 13
deeretek
Senior MTF Member
deeretek's Avatar
MTF Member # 40561
did you remember to push in the yellow pto button after it died?If that is still pulled out it wont crank.
deeretek is offline   Reply With Quote Quick reply to this message
Old 05-02-2010, 08:56 PM   post #10 of 13
Bodine
MTF Junior Poster
MTF Member # 43245
Quote:
Tried that, no luck.
I was going slow too. Is there's a safty mechanism, like a pin or something, that breaks when the blade hits a solid object? Must not be too uncommon to hit something like that. Not sure why it would affect the engine.
Certainly the idea would be to role the tractor away from the object. But even if the blade mechanism was broke, I would think it would allow me to drive it.
It seems like there should be a reset button, like a breaker switch of some kind, that tripps to protect the cams or something, and allows you to inexpensively get it back running.
Old 05-02-2010, 09:01 PM   post #11 of 13
LLigetfa
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Again, I will ask, does it have a clutch interlock that prevents it from being started while engaged? Do you need to have it in neutral with the clutch disengaged?
__________________
Old 05-02-2010, 10:09 PM   post #12 of 13
Bodine
MTF Junior Poster
MTF Member # 43245
Quote:
There is a peddle that has to be pressed in order to start it. It's next to the forward and reverse pedels.
Sponsored Links
Advertisement
Old 05-02-2010, 10:26 PM   post #13 of 13
IRDEERE
Senior MTF Member
MTF Member # 35157
I had a neighbor that hit a large stump several years ago......he had to by a new short block. I'm not saying you have that much damage but it is possible.
IRDEERE is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
