2305 Turn Signal/Flashers not working - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-27-2010, 03:21 PM   post #1 of 3
whereditgo
MTF Junior Poster
MTF Member # 34420
Default 2305 Turn Signal/Flashers not working
I am having an issue with my turn/flashers. The lower red driving lights work, but the upper yellow turn/flashers do not. I have tried to replace the flasher relay LVU800247 ~$80, but that did not solve the problem. The bulbs are good and I am getting a clicking sound from the relay.
I traced the green/red and green/yellow from the lights/dash indicators. I am getting voltage out from the relay, but nothing when I connect a bulb. Is this a grounding issue, fuse or possible secondary relay?
I checked all four aux fuses under the hood and cleaned battery/frame ground connections to no avail.
Appreciate any assistance offered, thanks in advance.
Note: I have ordered the tech manual on CD, but thought I may be able to solve the issue while waiting for it to arrive ....
whereditgo is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-27-2010, 03:43 PM   post #2 of 3
Phoenix125
Proud Member of the 1K Club
Phoenix125's Avatar
MTF Member # 31145
Default Re: 2305 Turn Signal/Flashers not working
Hmmm. It sounds like you tried most of the more common causes. The ground is not likely the issue since the marker lights are working.
I was talking to our local JD mechanics and they said they've had problems with diodes blowing on the turn signals (but only when the customers were wiring a trailer harness).
Here's the page you're looking for:
Tech_Manual_p166.pdf
__________________
-William "Kim" - AKA: Phoenix125
2009 JD 2305, FEL w/ 53" Bucket & hooks, 54" MMM w/ Ind. Lift, Hydraulic Diverter, & JD Mulch Kit, 12v Port 1 & 2, (3) ROPS Lights, JD Ballast Box w/ Reese Hitch mod, JD 60" Back Blade, Harbor Freight Quick Hitch (27.5" due to old implement), Bro-Tek Skid Plate, Markham Welding Tooth Bar, Wallace 5' Box Blade, Frontier GM1060R Finish Mower, EZmover Hitch, Harbor Freight Winch, Clamp-On Pallet Forks from eBay, CountyLine Carry All, Agri-Fab Speader, Precision Dethatcher, County Line 5' Landscape Rake, Fimco 15gal 2.1 GPM Sprayer, TSC 48"x24" Roller, Precision Spreader, CountyLine 3pt Post Hole Digger
My 2305 & 200CX Maintenance Schedule Check List: PDF Excel
Phoenix125 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-27-2010, 03:45 PM   post #3 of 3
whereditgo
MTF Junior Poster
MTF Member # 34420
Thank you for your help ... Just found that info as well here :
http://www.mytractorforum.com/showth...=2305+flashers
Will order the four diodes LVU801851 and see if that works.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
