IH 424 3 Pt Won't Work after Hydraulic Filter Change - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-22-2010, 09:31 AM   post #1 of 4
dieselscout80
Senior MTF Member
MTF Member # 6955
Default IH 424 3 Pt Won't Work after Hydraulic Filter Change
I drained my hydraulic oil and cleaned the screen/filter on my 424, but after refilling it the 3 point hitch doesn't move. Moving the lift lever or the draft control levers have no control of the hitch. I can grab the 3 pt arms (while engine is running) and lift them all the way up its like some linkage is disconnected. The power steering works fine so the hydraulic pump is working.
Anyone have a good starting point on trouble shooting this?
__________________
IHC 424 Diesel
dieselscout80 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-23-2010, 10:59 PM   post #2 of 4
dieselscout80
Senior MTF Member
MTF Member # 6955
Default Re: IH 424 3 Pt Won't Work after Hydraulic Filter Change
I popped the cap off the pressure line tee where it connects into the flow divider that separates the power steering from the 3 pt hydraulics and it shot oil out after a second or so,
Can the flow divider that separates the power steering from the 3 pt hydraulics stick?
I had very little flow out the orifice valve screen port when running and none out the auxiliary port.
__________________
IHC 424 Diesel
Old 05-01-2010, 03:57 PM   post #3 of 4
dieselscout80
Senior MTF Member
MTF Member # 6955
Well today a bleed it somemore (more like took a hydraulics shower ) at the flow divider and it started working.
__________________
IHC 424 Diesel
Sponsored Links
Advertisement
Old 05-12-2010, 09:26 PM   post #4 of 4
TheLawnRanger
Senior MTF Member
TheLawnRanger's Avatar
MTF Member # 42568
Air in the hydraulics will do it everytime.
I have has similar issues on occasion with my IH404.
TheLawnRanger is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
