wiring for jd 111 lawn tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-21-2010, 04:18 PM   post #1 of 5
dodge man
MTF Junior Poster
MTF Member # 42229
Default wiring for jd 111 lawn tractor
I am having problems with the wiring for the selenoid. I can hot wire motor to start but not able to use the key .
I need to know the color of wires that go to the selenoid so I am able to start with the key
thanks
dodge man is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-21-2010, 04:30 PM   post #2 of 5
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
Default Re: wiring for jd 111 lawn tractor
when you say you hot wire it, do you mean by jumping 12v to the small terminal or jumping from 1 big terminal to the other? if you are not getting 12V to the small lug whe the key is in the start position, you may simply have a safety device tripped out.
__________________
Check out our new HOMEPAGE
davidg is online now   Reply With Quote Quick reply to this message
Old 04-21-2010, 05:26 PM   post #3 of 5
dodge man
MTF Junior Poster
MTF Member # 42229
where is the safety device located never heard of this?
Old 04-21-2010, 05:44 PM   post #4 of 5
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
there are numerous safeties on tractors, depending on age. seat/pto/brake/gear(neutral) are the common ones. if this one of the older 111's? one of the guys more familiar with the classic models will have to chime in to tell if there are even any on it if so.
another thing could just be a bad ignition switch or a fuse to the switch.
__________________
Sponsored Links
Advertisement
Old 04-21-2010, 05:51 PM   post #5 of 5
dodge man
MTF Junior Poster
MTF Member # 42229
on the selenoid there is two large red wires held on by nuts and on the red wire from the battery it is also connected to the male end of terminal on selenoid but I have no wire from the other male end connector .
I ran wire from starter tothis connectioon and it works when key is in "on" position.so I figure that there should be a wire from key switch to this terminal but not sure what color of wire ??
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
