Does overseeding work? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Backyard Round Table - L & G Tractor Related Topics Lawn and Garden Tractor Related Topics General Discussion Board
Reply
Thread Tools Display Modes
Old 04-19-2010, 10:21 AM   post #1 of 13
Jig Stick
Tractor Jockey
Jig Stick's Avatar
MTF Member # 31687
Default Does overseeding work?
My yard is now 2 years old. I do have some spotty bar spots. I plan on overseeding in the fall. Does it actually work, to make the yard thicker and fill in the bare spots? Will the seeds actually get washed down to the soil? Im skeptical....
__________________
2005 GX345 with 48in deck
Carlisle HD Field Traxx
Brinly Core Aerator
Stihl 110 Kombisystem
Stihl Farmboss with 20in bar
Stihl Yardboss
Stihl Shredder Vac
Lawnboy Pushmower
Makita Powertools
Snap On hand tools
"Screw the Matrix.....Id take both pills"
Jig Stick is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-19-2010, 10:21 AM   post #2 of 13
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Default Re: Does overseeding work?
I do it after plug aerating and it seems to work.
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 10:31 AM   post #3 of 13
brubakes
The Missing Goonie
brubakes's Avatar
MTF Member # 18524
Images: 1
Garage
Quote:
I just did this in my yard. I'll see how it works. I am looking for just over all thicker lawn. I have been going back and forth about putting down a layer of topsoil. Nothing very thick, just a little covering to help.
brubakes is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 10:33 AM   post #4 of 13
diesel_nut
Proud Member of the 1K Club
diesel_nut's Avatar
MTF Member # 23678
How does the seed get spread in a natural setting?
__________________
Cub 1872....sold
Cub GT2554: '07(sold) and '08
..."yyup"
diesel_nut is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 12:07 PM   post #5 of 13
gcbailey
3K Poster!!!!
gcbailey's Avatar
MTF Member # 28727
Images: 10
I found if you overseed and don't de-thatch/plug aerate... it's somewhat pointless. The seed needs to get in contact with the ground itself, not leaves/dead grass/debris.
__________________
Cub Cadets - '62 Original,
'69 73 w/Haban sickle
'71 Cub Cadet 127
'76 Siprit of 76
'07 Cub LT1045 w/bagger
'09 Cub GT2544 lots of mods...
Farmall - '49 Cub
Exmark - '12 Metro 36"
'12 Turf Tracer 48"
Kubota - 'BX2360 w/FEL, 54"MM, 48" brush
MCSE, MCITP, A+, Net +, CCNA, CISA, ISACA
gcbailey is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 02:49 PM   post #6 of 13
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Quote:
Ground contact is the key. I overseeded dead spots in my front yard one year and didn't get much out of it because the dead thatch didn't let the seed through. Now in the fall I aerate and overseed and then I try to tease the seed into the soil by running a leaf rake over the grass upsidedown. My yard is improving every year.
One other point. Last fall I took the extra step of top dressing the lawn with 10 yds of loam. What a huge difference this spring.
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 02:57 PM   post #7 of 13
Windlake
Packer Backer
Windlake's Avatar
MTF Member # 39034
Quote:
I like to overseed when I see the grass go into seed itself. If you have actual bare spots they may require some "hand work" with a little top soil and extra watering.
__________________
Windlake is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 03:23 PM   post #8 of 13
Gray
MTF Member # 41016
Spot repair
Little seed plus a little soil to barely cover.
Large scale overseed
Put your nose into the grass and take a good look.
If you can see the soil, so can the seed.
If light thatch, etc - best to aerate and then seed - consider triple aerate, tear it up, leave the plugs, they will grow too, as well as offer a home for the seed.
If heavy insulating thatch = dethatch, aerate, overseed as above.
Contact with soil required from ground surface, or from adding topdress.
do spring and fall - seed requires moist for a month - consult germination times - these vary with your seed mix of species - range is from 1 week to 3 weeks + time to establish = approx a month of moist - keep it moist not soppy wet - that's why fall is better than spring = more dew in the morning, and less evaporation
you will eventually see more new grass plants later too.
if in doubt = overseed - grass looks after itself in response to environmental conditions whether natural or imposed
overseeding puts grass where weeds would love to be - weeds require a home to grow - deny them with overseeding
investing weed spraying is a useless investment
Mow taller than most people - shades soil, moisture loss reduced from evaporation, also shades out weeds - go for 4 inches - and occasionally lower the mow height cos weed down low don't like to be mowed; return to 4 inches.
Grass likes to be mowed, weeds don't.
Do this routine every few years or as required. Thick is it. And tall is like walking on a pillow.
Gray
Gray is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 05:24 PM   post #9 of 13
oldtimer
3K Poster!!!!
oldtimer's Avatar
MTF Member # 4355
Images: 1
How to you top dress ? Will a spreader be able to spread the topsoil, do you have to use a shovel ? By spreader I mean a tow behind rotary...
oldtimer is offline   Reply With Quote Quick reply to this message
Old 04-19-2010, 07:31 PM   post #10 of 13
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
I shoveled the loam into my trailer, drove to a spot, then spread it by hand from the shovel. I did two or three trailer loads a night until I was done. Great exercise!
I don't think there's any way that a fertilizer spreader will spread loam. A manure spreader would work, but they're expensive.
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Old 04-19-2010, 08:23 PM   post #11 of 13
oldtimer
3K Poster!!!!
oldtimer's Avatar
MTF Member # 4355
Images: 1
Thanks steve. Well, that leaves me out of overseeding then.
Old 04-19-2010, 08:34 PM   post #12 of 13
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
I dethatch and then spread the seed and then go over with my spike aerater and then pull a section of chain link fence around to make sure the seed is down. Bigger bare spots I put a littlesoil over the seed.
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-19-2010, 10:21 PM   post #13 of 13
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
Quote:
I think it rules out top dressing for you. If you can get the seed in contact with the ground, especially after aerating, overseeding is still valuable even without the top dressing.
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
