Kohler CV15s not starting - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 04-17-2010, 09:06 PM   post #1 of 14
JakSuede
Jak
MTF Member # 29710
Default Kohler CV15s not starting
Turns over and tries to start but makes a back-fire sound. I checked the plug, new from last year, and it is fine. I dropped the carb bowl and cleaned it; not dirty but some water drops. I used all new fuel.
The short tube connecting the carb to the engine was torn and I rigged up my own, which may leak. Would that cause a prob?
JakSuede is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-17-2010, 09:37 PM   post #2 of 14
H-D
Senior MTF Member
MTF Member # 34425
Default Re: Kohler CV15s not starting
Yep!!! Vacuum leaks cause lean mixture & you need an over-rich mixture for starting. Not much use trying 'til you 'heal the leak'. Clearing the water from the bowl was a good start though! If you'll post the particulars (model & serial #s & type Kohler (Courage or Command), you'll find more help. Lotta Kohler specialists here!
H-D is offline   Reply With Quote Quick reply to this message
Old 04-23-2010, 08:27 AM   post #3 of 14
JakSuede
Jak
MTF Member # 29710
Ok, I fixed the hose. Same result. I know it isn't the choke since there is a diff when I pull it out (halfway or full).
Could it be a carb setting, or should I rebuild the carb?
Model: Kohler CV15s. (not sure what Courage or Command means)
Old 04-25-2010, 11:57 PM   post #4 of 14
DTLMG
Master Service Technician
MTF Member # 42277
Images: 2
Look at he valves for a broken valve keeper., If you spray carb cleaner in the carb will it run momenarily and stop?
DTLMG is offline   Reply With Quote Quick reply to this message
Old 05-03-2010, 09:19 AM   post #5 of 14
JakSuede
Jak
MTF Member # 29710
I will have to try the spray while I start it. How do I get to the valves, tear down the engine?
Old 05-03-2010, 10:43 PM   post #6 of 14
DTLMG
MTF Member # 42277
Images: 2
you simply remove the cover that is near the spark plug to see the valves. there are 4 or 5 bolts... the cover may be stamped OHV
__________________
DTLMG
Make sure your red wire goes to positive, and your black to ground
Master Senior Service Technician
30+yrs in Outdoor Power Equip Industry
Old 05-20-2010, 01:03 PM   post #7 of 14
JakSuede
Jak
MTF Member # 29710
Help Re: Kohler CV15s not starting
I couldn't get it to run with the carb spray, and the lil backfire (I think) may have caused the flames that shot out of the carb. Not kidding!
So I guess I am to the valves now. What is it I am looking for?
Old 05-20-2010, 03:14 PM   post #8 of 14
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
I'd look at the flywheel key first,sounds like its firing out of time,its probably broken or half sheared..a valve could be stuck open also too,intake most likely if flames shot out of the carb....at least you know it has spark now though!..
__________________
Tractor-Holic is offline   Reply With Quote Quick reply to this message
Old 05-20-2010, 07:01 PM   post #9 of 14
JakSuede
Jak
MTF Member # 29710
Ooooooh yeah, plenty of spark. Do you know where the shear pin is?
I will look at the valves, but how do I know if one is stuck open? Are they all supposed to be closed when the engine is off?
Nice pic, a real grabber
Old 06-24-2010, 09:04 AM   post #10 of 14
JakSuede
Jak
MTF Member # 29710
Cool Re: Kohler CV15s not starting
Oooooooookay. I just dropped some $$ in it to get the valves fixed. I cut my grass for about 45 min, ran out of gas, and found that it would start but then stall out.
While I wait for my mechanic guy to call me back, are there any thoughts on this?
I dont expect he tweaked the carb, but maybe that is needed now?
Old 06-24-2010, 08:30 PM   post #11 of 14
madmantrapper
All Fired Up
MTF Member # 26869
Depending on the year, it might not be a carb adjustment to tweak.
madmantrapper is offline   Reply With Quote Quick reply to this message
Old 03-25-2012, 07:06 PM   post #12 of 14
JakSuede
Jak
MTF Member # 29710
Help Re: Kohler CV15s not starting; Changing deck now
I can't figure out how to post a new thread so I'll piggy-back on here. I need to change out my deck. Kohler engine is on a Yardman body. I can't get under it, so I thought I would flip it onto its back wheels and prop it up.
Will this cause oil, etc. to flow to bad places?
Old 03-25-2012, 08:37 PM   post #13 of 14
flash5153
3K Poster!!!!
flash5153's Avatar
MTF Member # 62748
Default Re: Kohler CV15s not starting; Changing deck now
Lol!!
First of all,,,to post a new thread. Go to the forum you want to post under,,,and hit the button at the top left that says,,,"New Thread"
And yes,,it causes problems to flip a mower up vertical. To change a deck ,,there is no need to lift the tractor,,,just pull pins and slide it out.
flash5153 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-26-2012, 01:11 AM   post #14 of 14
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Oh man, Id break my back if I flipped a mower up to change the deck...
Pull pins, take loose any attachment points, slip off the belt...lift up the deck lift arm and slip that puppy out. 5-6 minutes tops depending on how many bent rusty nails are in place of where the hairpins should be...haha
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
