John Deere 870 3 point hitch question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-12-2010, 02:32 PM   post #1 of 5
Blueberry
MTF Junior Poster
Blueberry's Avatar
MTF Member # 41572
Default John Deere 870 3 point hitch question
Hello.
I recently acquired a JD 870 tractor and have been trying to use a back blade to scrape the top layer of sod off of an area of my property. The problem is that no matter how low I set the hitch down, the blade floats, is that the way it is supposed to work? I thought it would push into the ground and allow me to set the depth.
Thanks in advance for your responses.
Blueberry is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-12-2010, 02:53 PM   post #2 of 5
JDFANATIC
9K+ Poster
JDFANATIC's Avatar
MTF Member # 41
Images: 1
Garage
Default Re: John Deere 870 3 point hitch question
BB,
Welcome to the forum! A 3PH doesn't have downforce so a back blade will only dig to the extent it's weight will cause it to. Sometimes you can add weight, but this is a case where a box blade (with adjustable scarifiers) will dig much better.
__________________
Cheers
JDFANATIC
JD2210, loaded tires, 62C MMM, 210 Loader, 47" Snowblower, York Rake, PTO Spreader, Heated Cab, JD Plug Aerator, FIMCO Sprayer, Wheel Spacers, FEMCO Folding ROPS, JD Cart, Stihl MS170 and HT101, Wallenstein BX32 PTO Chipper
JDFANATIC is offline   Reply With Quote Quick reply to this message
Old 04-12-2010, 02:59 PM   post #3 of 5
Blueberry
MTF Junior Poster
Blueberry's Avatar
MTF Member # 41572
Thank you! That is exactly what I needed to know.
Old 04-12-2010, 09:28 PM   post #4 of 5
DJ in WV
I Love All Color Tractors
DJ in WV's Avatar
MTF Member # 10462
Images: 6
Garage
The only other option that you have besides trying to add weight to the blade, is to lengthen the top arm to make the blade angle into the ground more. Think of a wood chisel turned over from the way it is supposed to be. This will help some, but JD is correct. The best way is with a box blade with scarifiers.
__________________
MyTractorForum.com House Rules
Looking for a Technical Exchange Article? Here's an Index!
My YouTube Page
My Equipment:
1970 Gravely C10A
1972 Gravely 816
1973 Gravely Model C8
Eight other Gravely C's, L's, and LI's
1978 Massey Ferguson 1655
1981 Troy Bilt Horse, 7HP Kohler
1982 Gravely 8123
1983 Troy Bilt Junior
1988 JD 950, 75 Loader, 8A Backhoe
DJ in WV is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-13-2010, 11:38 AM   post #5 of 5
Phoenix125
Proud Member of the 1K Club
Phoenix125's Avatar
MTF Member # 31145
and congrats on your new tractor!
- When using the back blade, sometimes several passes over the same site helps.
- You could try to angle it (set it to 30 or 45 degrees), then shorten the top link allowing the front edge of the blade to dig to help break the surface.
But, of course, as JDFan and DJ have said, a box blade would work best. I purchased a back blade having the same hopes and you and ended up buying a box blade off Craigslist a couple weeks later.
__________________
-William "Kim" - AKA: Phoenix125
2009 JD 2305, FEL w/ 53" Bucket & hooks, 54" MMM w/ Ind. Lift, Hydraulic Diverter, & JD Mulch Kit, 12v Port 1 & 2, (3) ROPS Lights, JD Ballast Box w/ Reese Hitch mod, JD 60" Back Blade, Harbor Freight Quick Hitch (27.5" due to old implement), Bro-Tek Skid Plate, Markham Welding Tooth Bar, Wallace 5' Box Blade, Frontier GM1060R Finish Mower, EZmover Hitch, Harbor Freight Winch, Clamp-On Pallet Forks from eBay, CountyLine Carry All, Agri-Fab Speader, Precision Dethatcher, County Line 5' Landscape Rake, Fimco 15gal 2.1 GPM Sprayer, TSC 48"x24" Roller, Precision Spreader, CountyLine 3pt Post Hole Digger
My 2305 & 200CX Maintenance Schedule Check List: PDF Excel
Phoenix125 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
