Lauson carb leaks like crazy! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-08-2010, 07:43 AM   post #1 of 3
PDA1
MTF Junior Poster
MTF Member # 41286
Default Lauson carb leaks like crazy!
I was given a Troy Bilt Horse (I think it was made in 1973). The Lauson carb leaks out of the carb air inlet. It drips about 1 time per second. The more fuel in the tank the faster it drips.
The float (copper) is fine with no fuel or water in it.
I just replaced the needle and rubber seat attached to the float. With the bowl off I could easily shut off the fuel using the float.
The thing continues to drip.
Any ideas how to fix this problem?
PDA1 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-08-2010, 09:56 AM   post #2 of 3
mla2ofus
Old Stonebreaker
MTF Member # 138
Default Re: Lauson carb leaks like crazy!
I don't know what make of carb is on my Briggs powered horse, but I found the tab on the float was worn down enough the float was contacting the carb body which kept the needle from seating tight enough.
Mike
mla2ofus is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-09-2010, 03:34 PM   post #3 of 3
cnhyardtoys
Senior MTF Member
MTF Member # 18796
Float needs to be reset. It is set too high. or the seat is not set in all the way.
cnhyardtoys is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
