bolens ride master 1947 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-25-2010, 11:41 PM   post #1 of 23
stingrayzp
MTF Member
MTF Member # 16394
Default bolens ride master 1947
hi my dad has a bolens ridemaster 1947 looking to sell need total restroation can get pics if needed email me at stingrayzp@comcast.net
stingrayzp is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-25-2010, 11:49 PM   post #2 of 23
wilberj
Moved on....
wilberj's Avatar
MTF Member # 15653
Default Re: bolens ride master 1947
To bad your not in MI I would buy it.
__________________
My Bolens
Tube frame-600, 650, 850, G9, 1000, 1050, 1254, 1254, 1220, G14, 1556
Large frame-1250-0?, 1250-02, 1455-01, 1455-02, 1476-01, 1477-01, 1886-prototype, 1886-01, 1886-02, 1886-03 With FEL, 1886-04, 1886-04, 1886s-05 (HT18) Cat, 1886s-06 (HT18), 1886s-06 (HT18), HT-20, HT-20 With FEL and Backhoe,
5 Ridemasters, Bean Cutler, Ride a matic, 3 Power ho
26 Suburban, 510, 610, 775, Estate Keeper
You can find me here>>> www.gardentractortalk.com
wilberj is offline   Reply With Quote Quick reply to this message
Old 03-26-2010, 12:40 AM   post #3 of 23
LPBOLENS
Nine Year Site Sponsor
MTF Member # 857
Or near Illinois, or I would.
Why not post the pics here, anyway? We all like to see pics, especially of some of the really old stuff.
__________________
Doug
Bolens:1254, G14, H14, Whirly Rake, generator; 1250 (2), 1455, 1886, HT20, HT20D, HT23 (4), typical attachments, Danuser post hole digger, Haban Sickle-Mo, Johnson FEL,forklift, Brantly backhoe; Cozy Cab; GK (2) 72" decks, dozer blades, snowblower; Ridemaster 35AB01, sickle mower, disc harrow, grader, hitch; Power Ho (3), sulky, snowcaster, air compressor
Bush Hogs: D4-7, D4-10 (parts), D4-12, plow blades & MMM (Want the 42" trail mower!)
Massey Ferguson: MF12 (1967), MMM
LPBOLENS is online now   Reply With Quote Quick reply to this message
Old 03-26-2010, 11:49 AM   post #4 of 23
Bolens 1000
3K Poster!!!!
Bolens 1000's Avatar
MTF Member # 28563
Images: 14
Quote:
__________________
Bolens Collection: 800, 850, 2 900's,1000 and 2 1050's
Bolens 1000 is offline   Reply With Quote Quick reply to this message
Old 03-26-2010, 04:44 PM   post #5 of 23
ubber_gearhead99
Young Buck
ubber_gearhead99's Avatar
MTF Member # 19352
Images: 6
Im close but cant afford or need it. Want one though. they are an odd looking rig.
__________________
The 400's coming along, and we're both kicking and screaming!
1975 John deere 400 "Almost restored!"
1959' Bolens Ride-a-matic 230 w/ 39" deck,48"plow, 8" mold board plow,
Custom Snapper Hi-Vac with honda engine
ubber_gearhead99 is offline   Reply With Quote Quick reply to this message
Old 03-26-2010, 05:21 PM   post #6 of 23
stingrayzp
MTF Member
MTF Member # 16394
here is some pics of the ridemaster its a 1947 with a wisconsin motor
ID:	97865   Click image for larger version
ID:	97866   Click image for larger version
Old 03-26-2010, 05:54 PM   post #7 of 23
wilberj
Moved on....
wilberj's Avatar
MTF Member # 15653
Its tuff looking, how much were you looking to get out of it.
__________________
My Bolens
Old 03-26-2010, 06:02 PM   post #8 of 23
jdcrawler
Lindeman crawler fan
jdcrawler's Avatar
MTF Member # 10122
The part of the round tube frame where it attaches to the rear axle under the seat, is that connection welded or bolted together ?
__________________
Ray
1945 John Deere Lindeman ( modified )
1949 Agricat crawler
1947 FMC Bean Cutler ( flat belt drive )
1948 Bolens Ridemaster - 35AA01 Ser#230
1948 Bolens Ridemaster - 35AA01 Ser#457
1948 Bolens Ridemaster - 35AB01
1953 Bolens Ridemaster 35AB03 ( modified cart )
1937 Shaw Du-All tractor conversion
"R/T" home made tractor
http://www.youtube.com/watch?v=-1aD1wn7yNE
jdcrawler is online now   Reply With Quote Quick reply to this message
Old 03-26-2010, 10:09 PM   post #9 of 23
stingrayzp
MTF Member
MTF Member # 16394
ray it looks like it used to be bolted but over time looks like some one welded it togather serial number is under 800
Old 03-26-2010, 10:14 PM   post #10 of 23
stingrayzp
MTF Member
MTF Member # 16394
model number type 35ab01
Old 03-26-2010, 10:49 PM   post #11 of 23
jdcrawler
jdcrawler's Avatar
MTF Member # 10122
My engineering information shows a change on serial # R-651 on 3/8/49.
They show an engineering change for serial # R-4000 on 9/26/49. This changed the dust cover on the rear wheels from a screw on cap to a flat plate.
From what I can see on the photos, it looks like it has the flat plate on the rear wheels.
The rear hubs may have wore out and been changed to the later style at some time.
The AKS engine was changed to the AKN engine on 35AB02 - serial # R-4300 on 3/21/50.
So .. I would say the Type # 35AB01 with a AKS engine and a serial # under 800 is going to make this a 1949 model.
Figuring the years on these Ridemasters isn't 100% accurate as they used older stock piled parts on newer models and newer parts were put on older models as repairs and replacements were needed.
That it also assuming the engineering change information that I have is correct in the first place.
__________________
Ray
Old 04-02-2010, 06:02 PM   post #12 of 23
stingrayzp
MTF Member
MTF Member # 16394
if any one is intrested in this ridemaster dad is going to let go to the junk yard tired of looking at it 300.00 will probley take it thanks mike
Old 04-02-2010, 10:09 PM   post #13 of 23
LPBOLENS
MTF Member # 857
Instead of just taking it to the junkyard, why not remove any usable parts first, and list them on Craigslist or eBay? As an example, the fuel tank, if not leaking from rust-through, is an item that Ridemaster owners could well be interested in. Same for front rims, engine, etc.
__________________
Doug
Old 04-02-2010, 10:17 PM   post #14 of 23
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
okay wilber, just go and get it i wouldnt want that to end up in the scrap
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-02-2010, 10:43 PM   post #15 of 23
wilberj
Moved on....
wilberj's Avatar
MTF Member # 15653
Post Re: bolens ride master 1947
Quote:
Were do you think I got the one I got now.
Why so far.
__________________
My Bolens
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
