JD 425 3 pt hitch capabilities - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-19-2010, 12:25 AM   post #1 of 6
stfiacregapp
MTF Junior Poster
MTF Member # 39832
Cool JD 425 3 pt hitch capabilities
I just bought a JD 425 AWS w/ a 3 pt hitch. My ?? is how much weight is realistic to put on that hitch. Can I pull a disc harrow? I dont see many category 0 discs out there. If anyone knows of a place that sells one, let me know. My deere dealer has one on the lot ( he claims was "made for this tractor) but wants almost 700$ for the disc. Ouch.
THanx.
stfiacregapp is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-19-2010, 02:39 AM   post #2 of 6
crawler
Senior MTF Member
crawler's Avatar
MTF Member # 39696
Default Re: JD 425 3 pt hitch capabilities
brinly-hardy makes them. As for capabilities, quite a bit. My 318 lifts the front of my bolens 1250 without front weights.
__________________
'90 JD 318 - 50" deck, 54" blade, H3, 3pt, ALZ load lifter
'68 Bolens 1250-02 - next up
crawler is offline   Reply With Quote Quick reply to this message
Old 03-19-2010, 10:12 AM   post #3 of 6
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
Weight limit for lifting 450Lbs. Save your self some money and Buy a (A) frame 3point to sleeve Hitch adapter which is $99.00 avaliable directly from Brinly-Hardy Then you can use sleeve hitch implements on your 425. Cat 0 equipment has always been expensive That is why I was so happy when Deere came out with the LImited Cat 1 3point hitches Because the Cat 1 implements cost alot less than the cat 0 implements because there are so many Implement manufacturers who make cat 1 implements for tractors 25hp and under.
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is online now   Reply With Quote Quick reply to this message
Old 03-19-2010, 01:40 PM   post #4 of 6
stfiacregapp
MTF Junior Poster
MTF Member # 39832
Cool Re: JD 425 3 pt hitch capabilities
I'll have to look into the adapter idea- I kind of like it. I checked w/ Brinly about the cat 0 3 pt harrow, plow and cultivator on their website and they indicated they haven't made them for a couple years except for direct sales to Deere. Maybe I'll find something used..... Craigslist here I come
Old 03-19-2010, 01:45 PM   post #5 of 6
jwill1776
Senior MTF Member
jwill1776's Avatar
MTF Member # 33215
I bought a JD 425 last fall, recently installed a Ruegg 3 pt (combo CAT 0 / CAT1). Defiantly keep an eye on Craigslist.
In the last two weeks I bought a Brinly spring tooth cultivator and a 12 plow just like the ones they make for Deere, $80 each. Lightly used, slight rust.
Jeff
__________________
John Deere 425 54 Deck
Ruegg Cat 0 / Cat 1 Combo 3-Point Hitch
Brinly Cultivator
Brinly 12" Single Bottom Plow
Brinly 60" Rear Blade
jwill1776 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-19-2010, 01:46 PM   post #6 of 6
coldone
Proud Member of the 1K Club
coldone's Avatar
MTF Member # 24068
Images: 3
Some Cat 1 implements will just need the pins changed over to Cat 0 pins. TSC has a disk that will fit with the pins changed.
coldone is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
