hydraulic oil in the old fords - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-06-2010, 11:00 PM   #1
ky wonder
Senior MTF Member
ky wonder's Avatar
MTF Member # 19840
Images: 6
Default hydraulic oil in the old fords
i have a 961 and want to change the fluids will regular hyd fluid work in these systems, or do i need to mix olils??
ky wonder is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-07-2010, 09:34 AM   #2
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Default Re: hydraulic oil in the old fords
You should use either Ford spec 134-d or universal tractor fluid. I use UTF in all three compartments, transmission, hydraulic and differentials so that if the seals should decide to leak between compartments then it's not harm no foul. UTF is safe for all three.
JohnW is offline   Reply With Quote
Old 03-08-2010, 12:16 PM   #3
souNdguy
Proud Member of the 1K Club
souNdguy's Avatar
MTF Member # 94
Quote:
if you put hyd oil in your sumps you will soon need a transmission, differential, and final drives.. though the 3pt lift will be fine!
utf in all the sumps, or utf in the hyds, and gear oil in the rest.
soundguy
souNdguy is offline   Reply With Quote
Old 03-14-2010, 01:55 PM   #4
nti06
MTF Junior Poster
MTF Member # 39778
my question is unrelated to this model but is sort of on the same subject.
i am changing fluids in my neighbors 1974 ford 4000 model tractor. i am still trying to fill the rear differential. How much does this thing hold? I can't find anything on the internet about the fluid capacities of this tractor.
Am I suppose to fill it until the differential carrier is submerged in fluid?
I filled the transmission until fluid drained from the high point plug on the side of the transmission so I think I got that one right.
nti06 is offline   Reply With Quote
Old 03-14-2010, 05:47 PM   #5
TMM
Senior MTF Member
TMM's Avatar
MTF Member # 39078
i have an 801 series tractor which is essentially an older version of the 4000, and my manual states that the rear axle takes 11 quarts of mild extreme pressure lubricant, SAE 80. It also states that there is an "oil level plug on side of housing".
hope that helps
tmm
TMM is online now   Reply With Quote
Old 03-14-2010, 10:05 PM   #6
nti06
MTF Junior Poster
MTF Member # 39778
on this tractor, i cannot find an oil level plug anywhere on the side of the axle. this tractor is supposedly an industrial model. its painted construction yellow and seems to have more features than the average agricultural tractor.
when i drained it, it had way more than 11 quarts of fluid. its also one of those wet brake axles. im lost when it comes to servicing equipment like this.
Old 03-15-2010, 08:52 AM   #7
Nouveau Redneck
2000 Posts and climbing!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
The specs for my '73 4000 says 34 quarts for the rear end, which is 8.5 gallons. The 801 is essentially an older version of the '62-'64 4 cylinder 4000 tractor. the newer '65-'75 4000's were entirely different, with 3 cylinder engines and completely different rear ends and rear axles.
The fill plug is on top of the differential housing. You should have a level plug on the right side of the center housing in front of the axle.
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/Select-o-Speed & 60 inch Woods rotary mower
2008 John Deere X500 w/54c deck, 48" snow blade and 48" shovel
2010 John Deere X304 w/42" deck
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. You're "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is online now   Reply With Quote
Old 03-15-2010, 12:11 PM   #8
souNdguy
souNdguy's Avatar
MTF Member # 94
your 4 cyl 4000 shares almost nothing in common with a newer 3 cyl 4000, except the name of the manufacturer, and a few minor parts. It would share much with a 4 cyl 4000 from 63-64 though.. virtually same tractor.
the newer post 65 3 cyl's were just completely different animals.
soundguy
Quote:
hope that helps
tmm
Old 03-15-2010, 08:51 PM   #9
nti06
MTF Junior Poster
MTF Member # 39778
So filling the rear axle is a matter of measuring the fluid going in?
After thoroughly searching, the only level plug I have found is for the transmission.
Old 03-16-2010, 07:24 AM   #10
Nouveau Redneck
MTF Member # 19566
Images: 1
There should be a level check plug on the side of the differential housing in front of the rear axle. I'll try to scan a picture form my manual, but it won't be until I get home this evening. Which leads to the usual recommendation around here... You should purchase a manual.
__________________
Nouveau Redneck
Sean in PA
Old 03-18-2010, 06:49 AM   #11
Nouveau Redneck
MTF Member # 19566
Images: 1
Sorry I haven't had a chance to post any pics for you on the location of the rear end fluid level check plug. I've been swamped with work.
Anyway, I got a quick chance to look at my tractor this morning before I left for work (it was actually light out when I left for work finally). The level check plug for the rear end/differential/hydraulics is on the right side of the center housing, in front of the right axle, just behind & below your right heel when you're sitting on the tractor. If things slow down I might even get to post a picture for you soon.
__________________
Nouveau Redneck
Sean in PA
Old 03-19-2010, 12:14 AM   #12
nti06
MTF Junior Poster
MTF Member # 39778
that would be nice if u could!
maybe paint the plug with some pink nail polish for dramatic effect
Sponsored Links
Advertisement
Old 03-19-2010, 06:01 AM   #13
donimbimbo
1981 Ford 1100 4WD
donimbimbo's Avatar
MTF Member # 18958
A PINK fill / drain plug on a tractor? Where is Mr. Pinky when you need him? (just kidding)
__________________
Ford Mustang 1990
Ford 1100 Tractor 4WD 1981
Ford LGT14H Tractor 1988
Subaru Forester 2002 (Wife's car)
Honda 1100 Shadow Sabre 2000 (being restored)
Ford Ranger XLT 4wd 2004 (on the disabled list)
donimbimbo is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
